Old 12-07-2006, 10:49 AM   #1
Motomech OP
Adventurer in Latin Amer.
Oddometer: 337
Dual disc frt. brk., would this work?
Ok, I've been looking at the two parts bikes in my carport and wondering if I couldn't use two stock right fork legs, two stock rotors and two stock calipers to make a dual disc frt. brk. Everything is symetical and looks like it would bolt up ok, the lower fork leg on the left side being turned around to have a trailing caliper, as opposed to the original leading caliper. But there is the problem of the master cyl., master cyl.s for dual disc set-ups have a different hydraulic ratio. Any sugestions for a BMW dual disc master cyl. that would be suitable to use on a GS?
Motomech "One modification a day"
'92 BMW R100GS Bumblebee
'91 Suzuki TS 200R
'96 KTM 300EXC
Playas del Locos
"The BMW Airheads, riding yesterday's technology the day after tomorrow".
Motomech is offline   Reply With Quote
Old 12-07-2006, 01:40 PM   #2
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
There was someone in a thread a few months ago that showed pictures of having done that very thing.
http://www.advrider.com/forums/showt...=brake+upgrade
*edit* Found it!
datchew is offline   Reply With Quote
Old 12-07-2006, 01:52 PM   #3
R-dubb
Dubbious Adventurer
R-dubb's Avatar
Oddometer: 5,016
Having recently wrestled with the same issue, I decided against it. One very simple issue is you will have a hard time finding a caliper. They are not reversible. The similar dual disk, Brembo calipers that BMW used during this period have a smaller piston. (I have a pair, and a pair of matching rotors with four holes that fit the GS hub if you are interested.)
The primary reason I decided against it is unsprung weight. It adds quite a bit. It is more efficient (and easier)to upgrade to a four (or six) pot caliper and a larger rotor. I actually could have pulled off the dual disk set-up more easily since my HPN forks have mounting tabs already on both sides! Still decided to go the upgraded single disk route.
R-dubb is offline   Reply With Quote
Old 12-08-2006, 06:04 AM   #4
Motomech OP
Oddometer: 337
Thanks for link. I can see I could only use the lower fork legs and would have to scrounge everything else. Yes I agree, better to use one of the more common brk. up-grades.
'91 Suzuki TS 200R
'96 KTM 300EXC
Playas del Locos
Times are GMT -7.   It's 04:24 AM.
