Old 02-21-2009, 08:53 PM   #1
Hodakaguy OP
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,103
The "Tanker Brace"...XR650R - Acerbis Sahara/Clark Tank Brace and Radiator Guard
The "Tanker Brace" is a brace/guard designed for XR650R's that are running a Acerbis Sahara Desert Tank (Also works great with the Clark, IMS, and OEM tanks). After installing a Sahara onto my XRR I found a few problems with the lower braces that are supplied with the tanks. I designed/built the Tanker Brace to solve these problems. After building one for myself a few other people wanted them so I decided to produce some for sale.
* First I found the Sahara tank will flex inward quite a bit when full, enough that it contacted/rubbed my radiator and KTM fan that I had installed. The Tanker Brace adds a small amount of pre-load (you pull the tank outward a bit to slide the brace in) that keeps the tank from rubbing the radiators/fan setups when full. Check the inside of your Sahara tank, you might find that yours has been rubbing the radiators also.
* I didn't feel that the provided Acerbis lower braces would provide enough protection for the radiators in a crash. The Sahara tank itself adds a good amount of radiator protection since it covers the sides of the radiators, but I've read where the tank can still flex enough to damage the radiators in a crash. The Tanker Brace ties both sides of the tank together and then into the upper motor mount that the Acerbis mounts used. Even if you crash hard enough to bend the Tanker Brace the extra space cushion between the tank and radiators provided by the pre-load of the Tanker Brace should keep the radiators damage free.
* I installed Unabiker radiator guards on my XRR. (This was the step that started the Tanker Brace build) After installing the guards I found that the Acerbis lower braces wouldn't fit any more with the Unabikers installed. The Tanker Brace allows the Unabikers to be used with the Sahara tank. (I believe the Sahara/Tanker Brace combo will protect the radiators sufficiently without need for extra radiator braces.....ie. Unabikers ect)
The Tanker Brace is fully TIG welded and parts are CNC cut. The braces come painted satin black with a fine textured finish . They are pre-threaded to accept the factory Acerbis hardware.
** Makes swapping between tanks a quick job as the tanks line up every time!, if you've dealt with the stock Acerbis lower brackets you know how flimsy they are and how they don't want to line up correctly.**
Cost: $65 + $10 shipping (Cont USA). PM me for payment details if you are interested in a brace.
Thanks.
Just out of the Jig.
Here's a shot of the Tanker Brace installed on my XRR. You can see how it attaches into the front engine bolt and both sides of the tank.
Misc.
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy screwed with this post 02-07-2015 at 05:56 PM
Hodakaguy is offline   Reply With Quote
Times are GMT -7.   It's 11:24 AM.
