Go Back   ADVrider > Riding > Layin' down tracks > GPS Tracks - Oz and Kiwi Land
Old 04-09-2009, 02:59 AM   #16
BurnieM
Nipple boy
BurnieM's Avatar
Oddometer: 4,101
Originally Posted by tbirdsp
It doesn't matter how you create the route, by linking waypoints or by creating via points with the route tool - when you transfer it to a 60CSx all that transfers are the points. As soon as you hit "navigate" the unit will recalc the route based on these points and whatever your routing preferences are set at - no way around it.
It doesn't "keep the first and last points and recalculate the rest of the route".
This is NOT the case with some other Garmin units (like the 276C types and even my old GPS V). With them somehow the exact route you created in Mapsource is retained.
Not all units support hidden via points
You can chose to transfer both waypoints and the route and I recommend that you do.
BurnieM is offline   Reply With Quote
Old 04-09-2009, 11:23 AM   #17
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,546
Not sure what units you are talking about, but the 60CSx most certainly does...
Mike S.
'09 Bonneville Black
AMA MSTA STOC
http://autos.groups.yahoo.com/group/...orcycleriders/
tbirdsp is offline   Reply With Quote
Old 04-09-2009, 12:22 PM   #18
GodSilla
I did that.
GodSilla's Avatar
Oddometer: 6,438
GodSilla is offline   Reply With Quote
Old 04-09-2009, 04:31 PM   #19
DR. Rock
Part of the problem
DR. Rock's Avatar
Oddometer: 5,342
It may be too late
(Yes, I'm quoting myself... don't ask. )
Originally Posted by DR. Rock
I'm not sure if the OP has already left, but I am 99% certain I know what the problem is, and how to fix it. The same thing was happening to me using RoadTrip and the Mac, so I tried my neighbor's PC with a very old version of Mapsource, and it worked fine. Then I updated his Mapsource version, and the via points (and routes) got all screwed up again on the transfer to the 60csx.
The fix is to save the route from Mapsource or Roadtrip as a .gpx file, then to open the .gpx file with a text editor, and find/delete each "gpxx:Subclass" line of .XML code associated with the via points (easily done in one step). When the file is then re-opened in Mapsource (or RoadTrip), the "gpxx:Subclass" lines are rewritten with a generic string of code which allows the route to be read and navigated on the 60csx as it was intended.
More details of the problem I was having here, with the description of the fix starting with this post.
DR. Rock screwed with this post 04-09-2009 at 04:43 PM
Old 04-10-2009, 01:33 PM   #20
DR. Rock
Part of the problem
DR. Rock's Avatar
Oddometer: 5,342
Ok
Here you go.
Old 04-10-2009, 02:01 PM   #21
b0mb3r
Old Git
b0mb3r's Avatar
Oddometer: 1,632
Send a message via Skype™ to b0mb3r
White pig
b0mb3r is offline   Reply With Quote
Old 04-10-2009, 04:13 PM   #22
BurnieM
Nipple boy
BurnieM's Avatar
Oddometer: 4,101
Getting back to basics;
If you have an auto-routing map product, such as City Navigator Australia, but want to lock down the route on the PC then;
1. first create a series of waypoints
2. then use the route tool to join these waypoints together into a route
3. then transfer both the waypoints and route to your GPS
This will give you a route similar to your PC created route and consistent routing behaviour across a range of different Garmin GPS units.
ie do not use the route tool on its own to create your route.
To DR Rock;
Your observations on the routing behaviour of both MapSource and GPSmap 60CSx while true have created a lot of confusion.
Most people simply want a basic route that behaves consistently
Old 04-13-2009, 02:18 AM   #23
GodSilla
I did that.
GodSilla's Avatar
Oddometer: 6,438
Thumb
To DR Rock;
I wasn't confused. I thought it was pretty creative and a neat solution. Not for everyone, granted, but innovative for sure.
Times are GMT -7.   It's 07:45 PM.
