Sand safe chain lube
Discussion in 'Australia' started by thumper-darryl, Aug 15, 2013.
  1. thumper-darryl
    thumper-darryl Been here awhile
    Dec 24, 2006
    315
    So. I have a ton of sand riding coming up soon and need sound advise on what lube to use for this. Most chain lubes I know of are sticky, and sand will stick to the chain. There must be something that experienced sand riders use for this application.
  2. What's his Face
    What's his Face lost as
    Jul 28, 2006
    3,747
    bundaberg australia
    where you riding without me :ear
  3. searchin oz
    searchin oz Sand, Gimme more sand
    Apr 17, 2007
    1,393
    Buronga, SW NSW
    I very rarely lube my chain. Most of my riding is in Sunset/Wyperfield, it doesnt get any sandier!!!!
    When I do give it spray I use Motorex, its light and does not leave a big build up of tacky crap for the sand to stick to.
  4. stormsearcher
    stormsearcher Long timer
    Mar 17, 2008
    1,132
    Victoria, australia
    Just clean the chain with kerosene once in a while.wipe it clean.
  5. Brute
    Brute Melbourne , outer east .
    Dec 6, 2007
    1,769
    I don`t lube my chain when riding in sand .
  6. thumper-darryl
    Dec 24, 2006
    315
    Derek. Some local rides coming up next month for the pure dirt bike where I will be using the KTM. I will keep you posted. Some of the Maryborough gang are talking about Fraser Island late September.
  7. What's his Face
    Jul 28, 2006
    3,747
    bundaberg australia
    local dirt action sounds like fun :D
    it's lookin like i got some brissy lads coming up for a kroombit ride at the end of sept ..
  8. pneumatic
    pneumatic Adventurer
    Sep 18, 2010
    19
    Brisbane, Australia
    Graphite powder lubricates but isn't sticky.
    #8
  9. DR Ozzy
    DR Ozzy Suzuki scum
    Feb 21, 2012
    862
    Adelaide
    No lube is better than a 50/50 lube / sand mix.
    #9
  10. Sean-0
    Sean-0 straya carnt
    Oct 19, 2010
    4,934
    Mumblebum Northern NSW
    Why do you lube an Oring chain?
    #10
  11. searchin oz
    Apr 17, 2007
    1,393
    Buronga, SW NSW
    The lube stops the noise associated with direct metal on metal contact. :D
    I know where you're coming from, the o-rings, or x-rings in some chains, keep the factory lube inside and pretty much prevent outside applied lube getting in.
    I wouldn't was my chain in kero as I think that would get through the o-rings and break down the lube. You would find it hard to get lube back in there.
    FWIW, I get many many kms from my DID X-ring chains running on steel sprockets. By memory I think it was around 15,000 km on my 640 in mostly off road riding. I raced a whole season (around 10,000km) without changing the chain or rear sprocket.
    #11
  12. tmotten
    tmotten Lefthand ride Dutchy
    Jun 28, 2006
    2,705
    Calgary
    The lube stops the rings from drying out. Which leaves them doing their job longer and better.
    I find ATF to work really well, even with sand. It doesn't stick, so provide more protection than dry from sand. I only apply it in the evening after a ride to let the rings soak it up overnight.
    #12
  13. Sean-0
    Sean-0 straya carnt
    Oct 19, 2010
    4,934
    So why after a chain change my orings still hold the grease in ?
    I did do a chain with lube last chain change ,,,it made no difference same wear on sprockets same on the chain ....im no expert but I think the only change I seen was my wallet thickness ...I am talking oring chains here ....quality chains last longer and IMO no need to lube .....I do wash them ...IE water and a sponge ....that's it
    #13
  14. willows
    willows Been here awhile
    Jul 30, 2007
    337
    Grafton, NSW. Australia
    I have been using a ScottOiler, filled with Auto Trans Fluid.
    When going into sand, just increase the flow rate to the chain. Result= Lubed chain with no sand on it.
    #14
  15. jacksonracingcomau
    jacksonracingcomau Been here awhile
    Apr 21, 2009
    546
    Sand MX track here in Rosebud
    Chain wax, put on hot after ride, allow to set before using it.
    Also good for fine dust, doesn't pick it up at all. but lubes chain / sprocket contact. Sprockets / chains last far longer lubed IMHE, O/X ring included.
    Dry chains will also rust, esp near salt water.
    Another good use for it is preserving metal parts, spray and store, stops corrosion but not sticky.
    Various brands of it available
    #15
  16. searchin oz
    Apr 17, 2007
    1,393
    Buronga, SW NSW
    I used to use chain wax when I had roadbikes. If left to set for a few hours or overnight I got no crap flinging off onto my nice shiny rims!
    #16
  17. GodSilla
    GodSilla I did that.
    Sep 21, 2006
    15,943
    GodSowncountry Australia
    Wash bike.
    Spray chain and moving links (footpegs, levers, etc) with CRC (not WD-40!) to dewater and lubricate.
    My chains last 20,000 k's. I never use any of that wallet-emptying canned shit on my bike, all it does is leave black residue and pick up dust and grit to halve the chain and sprocket life.
    #17
  18. Knackers
    Knackers Ubique
    Sep 18, 2006
    13,466
    Lower Eyre Peninsula, South Australia
    I have found that centrifugal force flings any solid, including sand, off the chain regardless of any oiling/lube. Graphite would last 2 seconds.
    That being said, I lube to stop rust and chattering, just don't bother too much before sand trips. After my sand trips I find the chain is beautifully polished, no crap or rust on it at all and ready for a lube after normal washing.
    #18
  19. davorallyfan
    davorallyfan Commonist Supporter
    May 2, 2005
    19,557
    Capitalist
    Tom. Tom. Has it really come to this? Contributing to a chain lube thread.:nono Junior members do this.
    #19
  20. ME 109
    ME 109 Long timer
    Jun 25, 2009
    9,192
    Albury Australia
    Hang a pair of decoy budgie smugglers off the mudguard, they'll attract all the sand. :wink:
    #20
