Stripped Allen Head. Now what?
Discussion in 'The Garage' started by motomike14, Jan 6, 2014.
  1. motomike14
    motomike14 Thumper Crusader Supporter
    Jan 2, 2010
    4,007
    Florida
    I have a 2000 XR600R. Developed a bad oil leak 2 months ago coming from the stator plug on the stator case. One of the bolt heads subsequently stripped. Here is what I have tried, to no avail;
    1) Larger allen head. Also tried a hex head. Just made the inside worse.
    2) Borrowed extractor from neighbor. No go.
    3) Impact with regular head. Tried to tap it in. Got it on, but would not bite. Tried taping it in more, still no go.
    4) Just today tried to drill the head off. Enlarged it quite a bit. Head still won't break off. Drill subsequently broke after drill bit got stuck (15+ year old electric drill, RIP :cry)
    So, I'm in a rock and a hard place. I could probably keep drilling, but now I'm worried the next size drill bit will drill into the case of either the crankcase or stator. I've already knicked the case up trying to hammer the bit in.
    I don't have a welder or dremmel tool, and not really inclined to buy one at the moment. Any other options?
    Thinking about trying to use JB weld with another extractor as I read a few people on here with that success (trouble is, colder than nuts outside right now).
  2. ZEmann
    ZEmann want to be riding
    Jul 19, 2013
    664
    Arizona
    question if you got the head off can u pull a cover off and then have access to the shoulder of the bolt with vice grips
    or does this not apply tho this situation ?
  3. motomike14
    Jan 2, 2010
    4,007
    Florida
    That's what my plan was (is). But I still haven't got the head off. And seems like I drilled through the already as large as a bit I last used.
  4. ZEmann
    Jul 19, 2013
    664
    Arizona
    I think that is your only option now unless you want to drill it and try an extractor again
    what happened the first time you tried the neighbors extractor ? no bite
    wrong size bit ? old extractor ??
  5. sailah
    sailah Lampin' it
    Aug 12, 2005
    7,804
    Turning expensive metal into scrap
    First off, any one in Florida claiming cold as nuts right now is crazy...:lol3
    Secondly let's see a picture of the offending bolt. Both macro of the head and a larger neighborhood shot to allow for tool suggestions.
  6. Yinzer Moto
    Yinzer Moto Long timer
    Jun 13, 2008
    55,899
    Pittsburgh PA
    If the bolt is 5mm (very common for motorcycle covers) I would pick a drill bit that is about 2.5-3mm and drill about 5mm in. Then using a 6mm or 7mm size drill, drill the head till the head pops loose and comes off. At that point, all the preload on the bolt will be released. You might be able to stick the smaller drill in the already created hole and with some slight side pressure, reverse the drill and screw the bolt out. Or use the proper tool, a screw extractor, and it should come right out. With the head still on the bolt, it will not want to break loose easily.
  7. Academy
    Academy Been here awhile
    Sep 11, 2012
    616
    North of Some, South of a Few
    I guess it is too late to cut a slot across what is left of the bolt head and use a screw driver to back the bolt out?
  8. lnewqban
    lnewqban Ninjetter
    Jan 22, 2012
    1,277
    Florida
    The bit may have broken from grabbing the last portion of the head; you are almost there.
    If you don't have more drill bits, you may wait until going out and buy some.
    As you know, a bit that is too big may damage the cover.
    Which one is?
    #8
  9. foxtrapper
    foxtrapper Long timer
    Sep 6, 2011
    8,686
    Drilling is all you've left. I suspect you're not using a large enough bit to sever the head from the shank. Then, remove the cover and use vice grips to remove the remaining shaft.
    #9
  10. kenstone
    kenstone worn out
    Mar 3, 2013
    2,043
    Boysee
    Drill it with a bigger bit, the head will spin when it breaks off...stop drilling:huh
    Remove the cover, hold a soldering gun (or mini-pencel torch) against the remaining screw to soften any locking fluid/loctite, and the screw should unscrew out with visegrips.
    I used left hand bits, but not required.
    jmo
    #10
  11. motomike14
    Jan 2, 2010
    4,007
    Florida
    Goes through the #23 dowel pin
    #11
  12. sailah
    sailah Lampin' it
    Aug 12, 2005
    7,804
    you can't get a pair of vice grips on that?
    #12
  13. Stop_Watch
    Stop_Watch Gruntled
    Sep 12, 2013
    302
    West Coast, USA, Earth, Sol
    I've had great luck with Craftsman bolt extractors and an impact driver.
    http://www.sears.com/craftsman-10-p...p-00952166000P?prdNo=2&blockNo=2&blockType=G2
    These grab the head of the bolt rather than trying the drill-though-the-bolt, break-the-bit-off, try-not-to-wreck-the-case, loud-cursing, machine-shop-visit routine anyone who's spent any time wielding a wrench will have gone though.
    Their success rests on having enough of the bolt head left to grab. I'm not sure from your description how much you've got left.
    #13
  14. motomike14
    Jan 2, 2010
    4,007
    Florida
    Tried that. Even with a point pair. Just spins. The head is some crappy soft aluminum. And, not much room between the case either.
    I'll get a photo tomorrow afternoon.
    #14
  15. hillbillypolack
    hillbillypolack Grumpy Old Goat
    Jul 29, 2005
    16,251
    Lidsville
    Seems everyone's trying to be a mechanic on Hondas this month.
    Post a pic, it might not be as bad as it appears. . .
    #15
  16. kenstone
    kenstone worn out
    Mar 3, 2013
    2,043
    Boysee
    Soft maybe...but not aluminum:D
    #16
  17. Motopsychoman
    Motopsychoman Not a total poseur Supporter
    Jun 2, 2013
    10,811
    Oaklandish
    Is this an original bolt or some aftermarket bolt? Could be aluminum if some PO changed it. Might be permanently seized in the case.
    You may end up drilling the whole bolt out and have to restore the threads with a Heli-coil.
    If this is a 6mm bolt, a 3/8" drill bit should chew the head right off the bolt and miss the case if you have a steady hand. 5/16" bit if it is 5mm. You need sharp drill bits and a steady hand.
    When you are done, replace all the case bolts with stainless steel. Even 18-8 alloy (also called A2) is probably stronger than what was in there.
    #17
  18. Kommando
    Kommando Long timer
    Nov 28, 2006
    12,492
    By the Great Lakes
    Are you near the Spacecoast?
    #18
  19. Bump Stop
    Bump Stop 2 Wheeled Drifter
    Aug 17, 2009
    8,371
    finding Jesus
    What you should have done before you totally destroyed the internal hex is to give the head a couple good raps with a hammer, this will usually shock the threads loose.
    #19
  20. motomike14
    Jan 2, 2010
    4,007
    Florida
    Did that, too. I actually did that to all the heads when I first started taking it apart as an older XR6 with the same problem had some rather testy bolts to remove.
    Found a backup drill this morning in the house, might give it one more go tonight when I get home. If that doesn't work, might just suck it up and buy a dremel tool and grind the head off. Will give more updates tonight.
    #20
