One Battery Tender Per Bike?
Discussion in 'Equipment' started by big_weight, Apr 26, 2008.
  1. big_weight
    big_weight Adventurer
    Aug 1, 2004
    74
    Vancouver, WA
    Have a R1150GS that keep connected to Battery Tender when it is in garage. Just bought a KTM 450 EXC and want to connect to BT when it is in garage. Do I need another BT so that one is connected to each bike, or can I switch connections between bikes on a "scheduled" basis? What would be a good schedule? (Before someone responds "why spend $$,$$$ on bikes and worry about ~$50 on a BT?", I can afford another BT):D
    Thanks.
  2. BobbyC
    BobbyC n00b
    Feb 9, 2006
    1,355
    NJ
    I had 5 bikes that had batteries at one time and 2 BTs. I would rotate them once a week but they rarely needed it for more than 30 mins. Now I only have 2 bikes, 950 and 450 and I put a BT on the 450 a week or 2 before I ride it and it still has a full charge. I don't put one on the 950 b/c I ride it a lot more.
  3. flanga
    flanga Delusions of Adequacy
    Sep 19, 2005
    2,806
    New Hampsha
    I had two Schumacher float chargers ("Battery Tender" is just one specific brand of float charger) die in a power surge recently.
    I have two left and am rotating them among the four batteries I'm maintaining.
  4. justJeff
    justJeff Banned
    Dec 18, 2005
    2,666
    Eastern Washington
    Battery Tender makes a couple of multiple chargers. For the price per bike though it's less expensive to buy a BT Jr. or something for each bike, which is what I've done.
  5. Uwe
    Uwe n00b
    Apr 13, 2005
    847
    Montco PA
    A battery does not need to be on a tender constantly. It just needs to be kept at a reasonable level of charge -- i.e. not be left sitting around in a discharged state. The self dischargerate of a lead-acid battery depends on its construction and ranges from a low of 1-2% per month (for an an AGM battery Lead-Calcium plates in goodition) to as much as 1% per day for an old-school flooded battery in poor condition. So even in the worst case, rotating the tender between the bikes once a week will keep the batteries at or above a 93% state of charge, which is fine.
    -Uwe-
  6. big_weight
    Aug 1, 2004
    74
    Vancouver, WA
    Thanks to all who responded. Once again, members of this forum save the day. Appreciate it.
    Bill
  7. byron555
    byron555 Lame Duck Adventurer
    Oct 30, 2007
    1,144
    Central Wisconsin
    I use a harbor freight tender/float charger on my xr650l, worked great this past winter here in WI. I think they are on sale right now for $4.99. I changed the allagator clips to a Tamiya type battery connector and wired a tail directly off the battery. Total cost of maybe $8. The tail is wired into the tool kit bag. Left the battery in the bike over the winter, started every time I wanted it to.
  8. FALSTEN
    FALSTEN Don't listen to me...
    Oct 28, 2006
    19
    Huntsville AL
    I spoke with a guy who runs a local discount battery store (batteries are their entire business). He was very much against leaving the automated float chargers on a battery. He said that none of them were "smart" enough to avoid overcharging a battery as it ages and starts taking less peak voltage. He recommended putting the charger on the bike once every couple of weeks for 4 or 5 hours. I guess that some of the charger manufacturers would argue the point, and I've heard multiple folks on the forums say they leave them hooked up all the time and it really helps the longevity of their battery, but, I guess the option of hooking it up on occasion for a few hours is probably a pretty safe one, too.
    #8
  9. byron555
    Oct 30, 2007
    1,144
    Central Wisconsin
    If the amp output is too high it will eventually "boil" off some liquid, car battery tenders are generally way to large. The one I purchased puts out a very low current. My stator charges the battery at a much faster rate. I should also note that in warmer seasons I do not attach it after every ride. I ride enough in the summer months that a tender is not needed. Wisconsin is very cold in winter and discharge rates seem to speed up in the cold. I have had batteries freeze solid in my garage.
    #9
