Where do you set tracking on, record? check/uncheck button for tracking, what screen? Where (what folder) is the .gpx file off this track? 1.8.3
My tracks show up in the OSMand/tracks/rec folder. Mine always creates tracks when it is running. Go to settings - logging services & sleep mode - log track to GPX file.
edit: Settings - Plugins - Logging service & sleepmode, check to enable You must see it in the mapscreen (rightpanel), GPX, hit it and start, stop, save, if needed. if not on the mapscreen, then map left bottom corner, hit button , configure screen, rightpanel, GPX recordings, check to enable. GPX file in: OSMand/tracks/rec folder Thanks.
The pics. After check, Settings - Plugins - Logging service & sleepmode, check to enable. Hit GPX, right panel.
