Chain Oilers? Use or Not if so what system
Discussion in 'Equipment' started by rotten, Mar 8, 2012.
  1. rotten
    rotten LOST AGAIN
    Jan 14, 2008
    670
    Soquel, CA
    I have noticed that several riders make reference to chain oilers are these suggested or just another gimmick? I have seen the products like scottoiler and Tutoro are there preferences here? Or is this just another way to add oil to the road?
  2. 0ldhippie
    0ldhippie Been here awhile
    Nov 29, 2010
    578
    Sacramento
    I had a scottoiler on my zx9r. I makes a little mess but the chain went 40,000+ miles. The newer o-ring chains need little maintenance and I don't ride as much as I used to, so I've never put on any of my other bikes.
  3. BadKarma
    BadKarma Long timer Supporter
    Dec 29, 2011
    10,091
    Rocky Mountains, USA
    I used to have a 1979 Electra Glide. It had an auto oiler of sorts...I had to park it on a cookie baking pan and nobody ever wanted to ride behind me. :wink:
  4. rotten
    rotten LOST AGAIN
    Jan 14, 2008
    670
    Soquel, CA
    Thats great add engine oil as chain requires!
  5. 0ldhippie
    Nov 29, 2010
    578
    Sacramento
    My old triumph actually came from the factory with a chain oiler that would drip engine oil out a tube onto the chain. It kinda worked??? The motor blew before the chain went. Oh for the good old days????
  6. rotten
    rotten LOST AGAIN
    Jan 14, 2008
    670
    Soquel, CA
    LOL was it due to loss of engine oil? Or British design, best parts in the world fall off of Triumphs :D
  7. 10/10ths
    10/10ths Road Trip Fool Supporter
    Aug 26, 2007
    1,690
    Bayou country
    I own the Scottoiler Esystem. It is spectacular. All you have to do with this Esystem is wire it to the battery for power and install the reservoir and tubing.
    I have it mounted on my V-Strom. The chain stays clean and lubed with no adjustment needed for a lot of miles. It has a little LCD screen that you mount on the dash and you can control the drip rate of the oil and other parameters.
    It is a truly easy to install and use system.
    I love it.
    Good Luck.
  8. R59
    R59 they call me Rocker
    Mar 24, 2004
    16,696
    Aux Arcs
    My old Sportster XLCH had something similar.
    #8
  9. rotten
    rotten LOST AGAIN
    Jan 14, 2008
    670
    Soquel, CA
    Great feedback Thanks! Do you use the proprietary oil or something else 10-30 or ATF?
    #9
  10. 10/10ths
    Aug 26, 2007
    1,690
    Bayou country
    ...the ScottOiler Oil. Blue in winter, red in summer. They have two weights of oil for different temps.
    I really love the eSystem.
    Here's the link to the Aerostich Catalog page for the Scottoiler eSystem:
    http://www.aerostich.com/scottoiler-esystem.html
    Cheers.
    #10
  11. Ensey
    Ensey KLR Combat Touring
    Oct 4, 2004
    739
    Duncan, Ok
    WD-40 at the end of each day on a trip............. Otherwise, every couple of gas refills....... 16-20kmiles on a KLR chain
    #11
  12. OaklandStrom
    OaklandStrom Long timer
    Sep 17, 2005
    1,624
    East Bay
    I have the vacuum version of the ScottOiler on a 650 Strom.
    It was a bitch to hook up, mostly due to the pain of getting to the nipple on the throttle body. Other than that, it's great. I don't deal with chain maintenance very often. I know when I get home from work, and it's raining and cold, the last thing I want to do is oil a chain.
    It costs about as much as a set of sprockets and a chain. So if it increases chain life by a significant amount, it's "free". Obviously, it will depend on how many miles you ride.
    I mounted it under the seat, and ran the hose down the chain guard. It's barely visible. The container has never leaked oil into my under seat storage area. It's not as trick as the electronic version, but it puts out a drop of oil every minute or so. Flow is user adjustable.
    #12
  13. M Singer
    M Singer Been here awhile
    Feb 5, 2008
    204
    Greenback, Tennessee
    I have the same set up on my V Strom and love it!
    #13
  14. ultrachrome
    ultrachrome Poser
    Jun 14, 2007
    274
    Madrona, Seattle, WA
    I'm using the vacuum system Very easy to install. I cut a vacuum line, inserted a T connector and the rest was simple.
    Mine's mounted in plain view so I can give it a quick flow adjustment based on the ambient temp. For example, if it's a particularly brisk morning, I'll increase flow by 25% otherwise I keep set to 50%. I don't have the patience to time the drops.
    I've had it on for about 3-4 months, commuting daily, and I've only adjusted my chain maybe once.
    Yes, there is some oil fling but IMO it's minor. My bike is filthy as it is from riding in the rain. It washes or wipes right off. The best part is that if the chain starts to look a little dirty, a quick wipe with a clean paper towel will make it look new again.
    #14
  15. levain
    levain STILL Jim Williams Supporter
    Oct 29, 2005
    13,437
    vermont
    Thanks for pushing me over the edge. Really. I appreciate it. The simplicity of the Esystem has always outweighed the cost. I've wanted one, but I didn't buy one. I'm one of those riders that just can't be bothered to do the chain maintenance. It's not that big of a deal. I just can't be bothered. "Oh yeah. I forgot. I need to get down there and spend the couple seconds and take care of that. I'll do it next time...." Consequently, it doesn't get done, and my chain/sprockets don't last as long as they should.
    Soooooo, I was fully prepared, CC in hand to pay full price. Go to the Scottoiler.com site. Oh, free shipping. Very nice. Poke around a little more. Oh, 10% off when entering V10 in the coupon code at checkout. That seals the deal! Order placed. $251.95 shipped. Couldn't be happier. Can't wait to install and not think about not oiling my chain:lol3:lol3
    Thanks again!
    #15
  16. bmwktmbill
    bmwktmbill Traveler
    Jul 16, 2005
    5,996
    Traveler
    When you get tired of messing with the Scott try this one.
    http://www.pro-oiler.net/
    RTW, one chain.
    It works with any oil at any temp.
    Set it and forget it.
    bill
    #16
  17. bluesman
    bluesman Long timer
    Feb 13, 2007
    3,898
    Hoegaarden, Belgium
    All of those so overpriced.
    There is a bunch of bikers in UK who making oiler professionally.
    I installed it on 4 bikes including mine and it is perfect. And cheap. And VERY well made. And quite sophisticated too.
    Highly recommend.
    http://www.pdoiler.co.uk/
    works as good as 200 Euro Scottoiler.
    #17
  18. sanjaya_sugiarto
    sanjaya_sugiarto Been here awhile
    Jan 6, 2008
    209
    #18
  19. PeterW
    PeterW Long timer
    Nov 11, 2005
    7,302
    Gold Coast
    I make my own oilers using the primer bulbs from small petrol engines (~$12 new from a mower store) an inline petrol filter (~$2) - add some Tygon tubing (~$10) add some sort of oil bottle ($0) and you are done for < $25.
    NO oil on the back tire, no leaking on the floor, just push the bulb to pump a little oil from a bottle into a surge chamber (inline filter) and let it trickle on to the chain. Good for about 100k/tickle.
    Yeah, chain oilers work, but most 'automatic' ones dump far too much oil and it gets on the rear tire. Mine keeps the chain lubed for about 20,000k's on < 200ml of oil.
    Pete
    #19
  20. 10/10ths
    Aug 26, 2007
    1,690
    Bayou country
    ..Great!
    You will love it. It is soooooooooo easy to install.
    The eSystem is a no brainer, worth every penny. It stops the oil flow when you come to a stop, you can set the drops per minute rate, once it is installed, you do NOTHING to it. It just works, with no mess, no muss, no fuss. It's like having a shaft drive without the weight and handling penalty.
    Let us know your thoughts after install and usage.
    Cheers.
    #20
