Oil light on at idle okay?
Discussion in 'Old's Cool' started by andmoon, Aug 25, 2006.
  1. andmoon
    andmoon Long timer
    Oct 28, 2004
    3,235
    NJ exit 10
    The manual says the light should be off when bike is running.
  2. sharkey
    sharkey XLV750R
    Apr 30, 2003
    876
    Melbourne, Australia
    NOT OKAY.
    Could be low oil, or bad oil, or a worn-out oil pump or a clogged filter, but any way it's no good and you need to address it ASAP. If the oil pressure is too low to light that light at idle, it's very likely lower than it should be at operating RPM.
    You've been asking about oil changing ... if you've just changed the filter, note that it is easy to assemble incorrectly ... what they call the $2000 O-ring. The filter element stays mostly the same, but which O-rings you need and which O-rings you must not use depends on the exact model of Airhead you're talking about.
    -----sharks
  3. jtwind
    jtwind Wisconsin Airhead
    Nov 19, 2004
    3,501
    Madison WI
    Sharks has got it right. The oil light should never be on when the bike is running. Shut it off immeadiately and figure out the problem. If you just changed oil it's probably there. They don't call it the $2000 o ring for nothing. The orientation of the gaskets, o rings and seals on different airhead models is confusing and the way it came out of your bike doesn't mean that way it's supposed to be. Lots of articles about this on the web, and in the books and manuals, do some searching. Here's one.
    http://www.airheads.org/content/view/189/49/
    JT
  4. sharkey
    sharkey XLV750R
    Apr 30, 2003
    876
    Thanks JT, I went looking for that so I could add a $2000 O-ring link, but got distracted and never did find it ...
    Andmoon, if you need any encouragement to park that bike until it's sorted, read this thread about a guy whose DR650 was sounding a little tappety and running a bit hot but he rode it home anyway:
    http://www.advrider.com/forums/showthread.php?t=160617
    Taxi to work starts to sound pretty cheap, eh?
    -----sharks
  5. Stagehand
    Stagehand Imperfectionist
    Oct 6, 2004
    33,745
    Küsnacht, slum of Zürich
    could it be a oil pressure switch on its way out?
  6. andmoon
    andmoon Long timer
    Oct 28, 2004
    3,235
    NJ exit 10
    I am not starting off well on this forum....It's the generator light I thought was the oil light.:shog :shog :shog
  7. Stagehand
    Oct 6, 2004
    33,745
    (heh, join club!)
    Still shouldnt be on when bike is running, but the potential penalties arent nearly so high. It should glow at idle, but should definitley be out by 1500 or 2k rpm or so.
  8. lkchris
    lkchris Albuquerque
    Feb 23, 2005
    1,130
    Very normal to mistake charge light for oil light on BMWs.
    Very normal for it to glow at idle.
    But, it must go out.
    And, if it's burned out the charging system does nothing.
    #8
  9. andmoon
    andmoon Long timer
    Oct 28, 2004
    3,235
    NJ exit 10
    Yup. Light on/flicker below 800 rpms...goes off anything above.
    #9
  10. datchew
    datchew Don't buy from Brad
    Aug 1, 2005
    7,601
    Remember the Alamo!
    You're not the first.
    Just glad it's not your oil light. For your sake. :-)
    #10
  11. Mugwest
    Mugwest "You mean this is the REAL world!?"
    Oct 18, 2005
    21,600
    3rd Ring of Buzztopia
    don't feel bad &moon-- it happens to more than just cycle afficianados:
    years ago i was tooling along in my aircooled VW Vanagon, and there was a hell-crunching racket from the engine room, followed instantly by the oil light on the dash jumping into my face. I just knew my motor (well-known for throwing rods, catching fire, etc at high mileage) was toast so like a good airhead i killed the ign instantly and coasted dead-stick into a parklot. Had the Bus towed to my parents garage, and began making plans for a full motor rebuild.
    Next week i had had all the new motor parts and wrestled the dead engine out. Put it on the engine stand and started tearing it down. When i got to the huge rear fan hub (Datchew will appreciate this), i noticed the bolt holes were cracked. :huh I then realized the fan had started separating from its hub, and that it had thrown the rubber v-belt off itself in all this wobble. I then realized that the red dash light that had popped on when the motor died was actually the alternator light. Yep-- fan belt jumped its pulley slot and the charge light dutifully told me there was no more charge. It was not the oil light at all.
    I proceeded with the rebuild and got to learn a helluva lot about aircooled VW engines.
    Ahh learning curve
    #11
  12. Joerg
    Joerg Long timer
    Jul 10, 2001
    1,361
    St-George, Switzerland
    Perfect.
    #12
  13. datchew
    Aug 1, 2005
    7,601
    Remember the Alamo!
    First specialty tool I ever bought: 36mm socket
    First spare part i learned to start carrying: fan belt. Never needed it. Stopped and donated to others on the side of the road twice though.
    he he he.
    don't you wish all engines came out with only 4 bolts, a red and black wire, a fuel line and a throttle cable?
    #13
  14. andmoon
    andmoon Long timer
    Oct 28, 2004
    3,235
    NJ exit 10
    The tin man the tin....I always bent the tin and rear apron for some reason.
    #14
