Highway Dirt Bike (HDB) top clamp and handguards
Discussion in 'Equipment' started by Chadx, Jan 23, 2010.
  1. rtadlock
    rtadlock Long timer
    Apr 21, 2010
    1,295
    Denver
    He is the shop that makes the parts.... :D
  2. SteveO
    SteveO scratched and bruised, but not out Supporter
    Jul 15, 2010
    1,571
    Land of ambivalence
    So, while I "REALLY, REALLY" enjoy Paul's parts, and think he is an excellent supplier of some highly desirable parts, I've come across an issue.
    After a few crashes, especially on the hard stuff, such as rocks, I found the brush-guards sliding in just a tad upon impact. Indeed, a quick adjustment will slide the brush-guard back out, but when on the trail, this has interfered with my throttle.
    So, to fix this, I ran down to the local Ace Hardware store and picked up a couple of small bolts.....
    This picture shows the diameter of the shoulder...
    This pic shows how the bolt slides through the gap in the brush-guard, ensuring that the guard will not slide in towards the center of the bike upon impact. On top of the brush-guard is an example of how it goes through.
    Here is the front side of the brush guard. I have spacers under the mounting bolt at this time due to my GPS mount being removed.
    This has been successfully tested with multiple wrecks, and is holding up great; i.e., the bars have not moved in towards the center of the top mount during the wrecks......
  3. everett
    everett Been here awhile
    Dec 13, 2009
    212
    St. Louis Missouri
    Perfect timing. I'd be inline for a group buy.:beer
    Everett.
  4. freetors
    freetors Long timer
    Feb 20, 2011
    1,115
    Collinsville, OK
    Are there any plans for making larger plastic guards to keep the bugs, rain, cold, etc off the hands better?
  5. fbj913
    fbj913 Adventure Aficionado
    Nov 16, 2007
    2,585
    Parker, CO
    x2
  6. Casejeep
    Casejeep Been here awhile
    May 22, 2011
    736
    Lake Powell or Flagstaff
    x3
  7. smoose
    smoose Adventurer
    Jan 7, 2012
    19
    Bedford, MA
    x4:D
  8. J.Johnson
    J.Johnson Adventurer
    Jul 22, 2011
    85
    So. Ca.
    [​IMG][​IMG][​IMG][​IMG]
    Got all of my new gear installed to ride last weekend. I love HDB products. I will be buying more from him. Well thought out product
    Sent with mind control...
  9. everett
    Dec 13, 2009
    212
    St. Louis Missouri
    Did you need longer cables?
  10. bodhizafa
    bodhizafa How hard can it be?
    Jan 6, 2010
    654
    Louisville, Co.
    Not sure if you got them yet........but I have them on my F800GS. REALLY, REALLY nice! Much nicer than the Barkbusters I had on there, love the little mirrors too. They just barely tap the stock windscreen. I also have the Scotts on there, no power outlets though. I'm REALLY happy with the setup. No drops yet to test them. :D
  11. Motoracer428
    Motoracer428 n00b
    Jan 25, 2012
    2
    FYI the website makes it sound like you cannot get Black guards with Black plastic shields but you can (at least it looks so from all the cool pics.) Enjoy!
  12. Wadester
    Wadester Rides a dirty bike
    Jun 21, 2008
    2,572
    'Cruces
    When I got mine a year or so ago - they came with a set of black and a set of white shields. I traded my blacks for another guy's whites, and now I've got spares that match. May have changed by now tho.
  13. AZ-Twin
    AZ-Twin Dusty and Thirsty
    Oct 20, 2007
    1,340
    Sierra Vista, AZ
    How does the black anodizing (or perhaps it is some other coating) on the top clamp hold up to the sun? I have bought other things and the anodizing either turned purple, or faded in some other way.
    [edit]
    I have not had other things from this vendor fade, just other aluminum things in general. Sorry if there was any confusion.
  14. freetors
    freetors Long timer
    Feb 20, 2011
    1,115
    Collinsville, OK
    I guess not....
  15. Dallara
    Dallara Creaks When Walks...
    Sep 14, 2006
    2,099
    South Texas
  16. Urbandrag
    Urbandrag KLiM Beotch!
    Oct 27, 2011
    528
    Motorcycle Heaven
    2006 650GS with OEM heated grips system...
    I promise better pics soon...
    :freaky:freaky:freaky:freaky
  17. Scott_PDX
    Scott_PDX Leisure Engineer
    Oct 18, 2010
    7,287
    Portland...the newer one on the left side.
    Just ordered and Adventure Plate, Bars, Risers, a couple of push button switches form HDB, 2 Powerlet sockets and some Hot Grips (Direct from hot Grips) for my WR250R.
    The hot grips comes with a 2 way toggle switch, does anybody know if that will fit in the "Switch" area's of the HDB top plate? As I want to run 2 powerlets so I don't want to use those holes for switches, and the push button swiches I ordered aren't two way (high and low). Or do you know a source for a two way switch that will fit in the "Switch holes" on the HDB set-up.
    Also not sure where to get LED's to fit in the indicator light holes anybody have a source for them? Never wired a diode directly, do they just wire up in series with a hot lead?
    Thanks.
  18. sailah
    sailah Lampin' it
    Aug 12, 2005
    7,804
    Turning expensive metal into scrap
    I got my leds from paul and he drills the holes and installs the leds and sends them. I did drill out a set of black guards and switched the leds to that set. Easier to have him do it imho.
    Regarding the two way switch, measure the hole diameter and check at radio shack I'm sure there is something that will fit. I decided to just wire mine high, off and keep the switches the same.
  19. Lima Tango
    Lima Tango Adventurer
    Oct 2, 2007
    75
    Morgan Hill, CA
    Typically, an LED will need a current limiting resistor in series with the LED. The value of this resistor will depend on the voltage of the source, the forward drop across the LED, and the LED's operating current. This is a generic answer; there may be some LEDs that have this resistor already integrated with the LED. Especially if the LED is packaged up for a specific application, for example to replace an existing incandescent bulb. You need to have information for the specific part you're using to avoid a mishap.
    LT
  20. Rapid Dog
    Rapid Dog bikes, booze, broads...
    Oct 28, 2003
    10,464
    Strangel Living West of Hell, SoCal
    ..anyone use these with FLEXX bars?
