KTM RFS Fuel screw issue
Discussion in 'Thumpers' started by HellSickle, Jun 12, 2014.
  1. HellSickle
    HellSickle Scone Rider
    Sep 19, 2005
    30,141
    Fort Collins
    450 RFS carb question.....
    Starting with a Baja trip in March, my air screw requires 4.5 turns out to idle and run without severe popping on decel. Last night I pulled the carb completely down and blasted carb cleaner and compressed air thru all the passages and jets. Put it back together and nothing changed.
    Fuel screw is aftermarket and inserted correctly (O-ring, washer, spring, screw). It runs great, but I worry about the screw falling out if I get too far out.
  2. HellSickle
    Sep 19, 2005
    30,141
    Fort Collins
  3. RideFreak
    RideFreak Torque Junky
    Apr 17, 2009
    19,992
    Out in the NM Dez somewhere
    If it does vibrate out somewhere in bfe plug the hole and you can finish your ride, won't run great but it'll run.
  4. HellSickle
    Sep 19, 2005
    30,141
    Fort Collins
    I carry a spare. During the rebuild I lost the spring, and you can only order the spring as a kit with the needle.
    I recall the slide surprising me by falling apart when I removed it. I scratched my head over the proper orientation to put the plate back on. Given a 50/50 chance, I guessed wrong. I'm 99% certain this will fix the problem. The description of the issue on TT matches my situation perfectly.
    IMO, it should be an engineering felony to release a design that allows critical parts like this to be mounted in multiple orientations.
  5. RideFreak
    Apr 17, 2009
    19,992
    All engineers are a bit felonious in that regard, too bad there wasn't a good technician handy to tell the designer how to make it idiot proof :rofl
  6. tirebiter
    tirebiter Been here awhile
    May 8, 2004
    528
    Crockett, Ca
    What year is your RFS, and are you the first owner?
    BTW, "Wisdom is knowing when to avoid perfection"
    Kilgore Trout
  7. davesupreme
    davesupreme grand poobah
    May 1, 2011
    5,366
    palm harbor, fla
    changing out the pilot jet is pretty easy.... 42's seem to work good on everyone i've seen.... 40's are a bit lean.... but i'm at sea level too, so.....
  8. clapped_r6
    clapped_r6 The Spoad Warrior
    Jan 3, 2006
    3,834
    Ridgefield, WA
    i put the slide in upside down once, and it did exactly as you described.
    #8
  9. tHEtREV
    tHEtREV Encouragement award recipient. tEAM iDIOT.
    Apr 14, 2007
    14,151
    Middle Park, Brisbane, Australia
    I put an FCR39 in my 640, put in a Dynojet kit and forgot to adjust the fuel screw to there suggested setting, and couldn't be bothered pulling it out again to change it.
    The thing ran pretty ordinary and would die at random times when idling and was a pain in the ass to start.
    I was doing some other work on it a few days ago and decided to adjust the fuel screw and got a bit of a surprise to see it was missing.:huh
    I fitted the fuel screw out of the old BST in it and she runs and starts great.:lol3
    #9
  10. HellSickle
    Sep 19, 2005
    30,141
    Fort Collins
    Bike is 2006 450.
    I flipped the slide plate last night and all is back to normal. The orientation is non-intuitive. The parts diagram shows the correct orientation. I can't believe that I've ridden 1k miles with it like that. Other than having the fuel screw way out, it ran just fine.
    #10
