Center of Gravity
Discussion in 'The Perfect Line and Other Riding Myths' started by henryroten, Dec 20, 2012.
  1. henryroten
    henryroten Been here awhile
    Sep 15, 2011
    397
    Back in sunny So. Cal!
    I am considering lowering the suspension on my 990R and was wondering if by doing so the COG is effectively lowered? Or is the COG a relationship between the weight distribution of the motorcycle in relation to the sitting position of the rider (does that make sense?)?
    Thanks just curious.
  2. anotherguy
    anotherguy Long timer
    Jun 18, 2009
    18,967
    the hills
    There4's the vehicle COG and the bike/rider COG. Generally when a bike is lowered both follow. There are variables and unusual situations but they are exceptions.
  3. LuciferMutt
    LuciferMutt Rides slow bike slow
    Aug 19, 2008
    20,589
    New(er) Mexico
    In before the huge argument about if standing on the pegs raises or lowers the CG. :deal
  4. Yossarian™
    Yossarian™ Deputy Cultural Attaché
    Jul 9, 2007
    14,142
    the 'Ha
    Me too. I want to get a good seat. :lol3
  5. slide
    slide A nation with a future
    Jul 20, 2003
    21,410
    NM, USA
    What do you hope this will accomplish? Better handling? Or what?
  6. pretbek
    pretbek Long timer
    Oct 7, 2008
    3,213
    South East PA
    Yes the COG is lowered.
    But effectively? As in: with noticable effect on handling? I doubt it.
    The effect of any geometry change (rear lower than front, mess with the fork to change rake/trail) will be much greater.
    Oh, and lowering will very effectively reduce your ground clearance.
  7. SRG
    SRG Long timer
    Nov 18, 2004
    4,610
    Central Va.
    Pretbeck - I think you are right, the actual distance that the CG would be lowered is not a large amount (wouldn't it be equal to amount of lowering? i.e. if you drop the rear 1" and drop the front 1" then the CG drops 1").
    However, lowering the CG a seemingly small amount may have larger effects that one might suppose. I know my Husaberg is quite sensitive to changes in the amount of rear sag and position of forks in the tripleclamp.
    The only bike I ever tried lowering links on was a 640 Adv. I don't think it effected the handling much, but it did allow the underside of the rear fender to contact the tire under full compression of the shock. Made a cool barking noise when it did :rofl.
  8. DAKEZ
    DAKEZ Long timer
    Mar 18, 2007
    19,879
    Begin Op Zoom
    The lower the mass the lower the COG period. Thread over. :1drink
    #8
  9. HH
    HH Dahlonega GA Supporter
    Dec 3, 2010
    3,072
    Dahlonega GA
    wait, what? :scratch
    #9
  10. randyo
    randyo Long timer
    Nov 17, 2007
    3,000
    Northern NewEngland
    it does both
    lowers COG of bike but raises COG of rider
    what does it do to the combination bike rider COG
    depends on the bike and the rider
    an average rider on a GS, it will lower the COG
    a 6'4" 265lb rider on a Rebel, it will raise the COG
    #10
  11. pretbek
    pretbek Long timer
    Oct 7, 2008
    3,213
    South East PA
    Yay! Here we go. :clap
    How does standing on the pegs lower the COG of the bike?
    In my opinion (and that of physics in this universe), it makes no change to the COG of the bike.
    #11
  12. Yossarian™
    Jul 9, 2007
    14,142
    the 'Ha
    We've got a live one!
    #12
  13. randyo
    randyo Long timer
    Nov 17, 2007
    3,000
    Northern NewEngland
    weight that was on the seat is now on the pegs, doh ! but as I said, your body COG is higher
    #13
  14. slide
    Jul 20, 2003
    21,410
    NM, USA
    How about I stand on the pegs but in a sitting posture with my ass is only .0001 mm off the seat.
    Now what?
    #14
  15. High Country Herb
    High Country Herb Adventure Connoiseur
    Apr 5, 2011
    32,137
    Knoxville, TN
    The COG (actually center of mass, to be exact) of the bike is unchanged by standing on the pegs (or getting off and walking away for that matter). The COM of the bike+rider raises a bit, because some of the mass (the rider) has moved up. If you stood on a 10 foot tall (weightless) ladder attached to your bike, it would be raised significantly. It doesn't matter where/how the two bodies of mass are attached, the issue is simply the center.
    Along those lines, lowering the bike lowers the seat, which also lowers the rider. COM has been lowered. This doesn't mean the bike will be less likley to fall over, though, because now the COM is closer to the point of rotation (where the tires meet the road) and will rotate faster. (more flickable?)
    I think the only major benefit to lowering the bike would be making it easier to get your feet flat on the ground when stopped. That will make it less likely to fall over.
    #15
  16. High Country Herb
    Apr 5, 2011
    32,137
    Knoxville, TN
    Almost no change then.
    #16
  17. crofrog
    crofrog Long timer
    Sep 26, 2007
    1,482
    Annapolis Maryland
    Something we completely agree on.
    #17
  18. BanjoBoy
    BanjoBoy I like pussy
    Mar 18, 2009
    1,401
    Northern CA
    Not sure how much yer talk'in 'bout "lowering" butt I crank up the preload (At both ends) in summer, (Cuz I needz all the ground clearance I can get) 'n take it out in winter (When I ain't lean'in as far) effectively lowering mah FJR.
    The 660 lb pig flicks back 'n forth better when it's "lowered." You should try it, ya might like it? :dunno
    And I only stand on the pegs when I wanta stretch mah legs. :wink:
    #18
  19. little foot
    little foot seriously not serious
    Jul 21, 2008
    15,435
    The Springs, Oklahoma
    what happens when you extend the swing arm? Do you just looks stupid or has the COG been changed?
    #19
  20. Yossarian™
    Jul 9, 2007
    14,142
    the 'Ha
    This one should be obvious. The COG moves rearward in respect to where it was before the extension, if that is the only change.
    By pushing more mass aft, you move the COG aft.
    #20
