Is my telelever bent? look at the pics....
Discussion in 'GS Boxers' started by 99p38a, Oct 29, 2011.
  1. 99p38a
    99p38a Been here awhile
    Oct 6, 2009
    321
    Michigan
    I've searched the forum and browsed pics, but I can't tell. It doesn't look bent when I look at the pics on the net, but what would cause the paint to come off? I haven't been in any accidents. I can only remember 1 good jolt to the front (felt like I hit a half buried cynderblock in a water crossing). My paint is peeling up and I am thinking maybe because the telelever is bending there? Other side doesn't have the paint coming off... If it's not bent, all i can figure to the paint coming off could be from brake fluid drips from when swapping lines a year ago, but it is a bubble like a bend or corrosion below (which I am not seeing), not a wearing off from the top. ideas?
    thanks.
  2. rtank
    rtank Adventurer
    Jan 15, 2008
    52
    HOG Capitol Kewanee IL
    I run a body shop n looks like its bent to me . shock bottomed out hard and the front continued to collapse .
    had to be a huge hit i think.. sorry but you need a new telelever
  3. A. T. T-W
    A. T. T-W Can't be bothered.
    Aug 24, 2004
    4,422
    Centre of my universe
    The finish is powder-coat and unfortunately it's very thin on the underside, made worse by the fact that the welds on the underside are not cleaned very well before the powder-coat was applied.
    If you run your fingers under the arm, back towards the rear, you'll feel what seems like grit stuck to the underside. It's not grit it's spatter from the weld that's not cleaned off in the lazy build process.
    The weld-spatter provides a starting point for corrosion that worms its way along under the powder-coat and finally splits the coating.
    Mine (despite regular cleaning underneath) was starting to do the same so I whipped it off and stripped it back to bare metal.
    I took pains to clean the weld-spatter off with a grinding tool before re-painting it (rather than powder-coat).
    I wish I'd taken photos of the little worm trails of rust that were spreading all over the surface but had not yet burst through the coating. That's a downside of powder-coat, it's strong enough to prevent corrosion appearing until its got a good hold and finally burst through like something in a Sci-Fi film.
    Every 1100/1150 I've worked on has the same rough finish on the underside of the Tele-lever wishbone.
  4. A. T. T-W
    Aug 24, 2004
    4,422
    Ohlins fit "upside down" compared to the OE unit.
  5. Dan Cãta
    Dan Cãta Long timer Supporter
    Jun 5, 2008
    2,569
    Cluj-Napoca, Romania
    If that A-arm would have to be bent, the first thing to have broken is the ball joint, so see if you have any play in that part. Put the bike on the centerstand and have someone lift and let down severall times, the rear end of the bike. If there is play in the joint you will see/hear it...
    Dan.
  6. bemiiten
    bemiiten League of Adventures
    Jul 10, 2003
    5,860
    Hamilton NJ.
    Hard to tell from the pics but I don't think it's bent. You would have a ripple on the side where the paint is flakeing. All the Telelevers I've seen posted that have deformed from the suspension bottoming have done so at the point around the balljoint itself.
  7. dave_faria
    dave_faria Adventurer
    Jan 22, 2006
    16
  8. yxome
    yxome Adventurer
    Jul 30, 2007
    98
    Colorado Springs, COLORADO, USA
    I'll give you $100 for the bike, Oh wait, it's an 1150. Make that $50.00 since the bike is obsolete'
    #8
  9. 99p38a
    Oct 6, 2009
    321
    Michigan
    thank you for your valuable input...
    #9
  10. OoPEZoO
    OoPEZoO Dirtball Extraordinaire
    Feb 23, 2008
    261
    Amish Country, PA
    If you decide its bent and want to replace it, I have the one sitting here off of my old RT. The bike wasn't wrecked. It was retired due to stripped input splines and high mileage. Its black, not silver, but its straight and in good shape. Good luck with whatever you figure out.
    #10
  11. REALGRAVEROBBER
    REALGRAVEROBBER LEAVING GRAVES EMPTY
    Nov 1, 2008
    916
    GFY, Montana
    My guess is that it's just coating flaking. Removing, paintstripping, and some measuring should give you an answer.
    As mentioned earlier, it is true that the R1150GS is obsolete and basically not even ridable. -- (I ride an 02 with 160,000 miles on it, and it runs/rides like new)
    #11
