A different Old Skool project - 1929 Ford Model A
Discussion in 'Old's Cool' started by crazydrummerdude, Jun 30, 2009.
  1. crazydrummerdude
    crazydrummerdude Wacky Bongo Boy
    Nov 28, 2006
    8,639
    Los Angeles, CA
    Seems to be catching on.. on the MOA forums. I'll share it with you all, too:
    The pictures and technical details will get better as the thread goes on.
    At the start of this project, I know/knew absolutely nothing about Ford's, Model A's, or "antique" cars. I am literally learning as I go.. and I am doing all the work by myself, and financing it all myself.
    History: This Model A was purchased by my grandfather some time around 1960.
    These are believed to be promotional shots for a family's friends car dealership. (Although it appears the car is dusty.. haha.)
    Sometime ~30+ years ago, it was stored in my grandfathers mothers shed. Work was being done on the house she lived at (floors?, roof?) and it is believed that one of the workers took an interest in it. Someone tied the Model A to their truck with a rope, and after stealing an old farm scale and a few other things, took off with it. They got a couple miles down the road before the rope snapped. The car crashed into a ditch where it rolled onto its side. As luck would have it, this ditch was in front of my grandmothers brothers house, I believe, and he yelled out to ask the guys where they got the car. They took off and it ended up back at my grandfathers house, or my uncle Dave's house next-door, until present day. Between then and now; 1) my uncle Rolla decided to start taking it apart to restore it. He got it about 1/3 disassembled. 2) My grandfather died in 1994, and the Model A was essentially given to my uncle Rolla. For as long as I can remember, it has sat in my grandfather/grandmother's shed in the following condition:
    [Dang it, where'd my "before" pic go?]
    Somewhere along the way, 2 extra engines and transmissions were acquired, along with lots of other extra piddly stuff.
    On November 6, 2006 Hours: ~2, Expenses: $69.50
    I decided to investigate into rebuilding one of the extra transmissions, to get my feet wet, so to speak. I soaked the whole thing in our parts washer liquid. Within a week, I had it rebuilt and looking good. I used chemicals and elbow grease to clean it up to prep for paint. I bought the appropriate bearings, gaskets, and correct Ford paint to make it authentic. It was a piece of cake.
    On November 7, 2006 Hours: ~2, Expenses: $0
    I decided to rebuild the other extra transmission. When taken down from "storage" above the small shop in our shed, it looked like this (you'll also notice a Model A bell housing in the background):
    It was nothing but ball of rust and dirt. I did the same process of letting it soak in our bucket of mystery liquid to loosen everything up. Upon popping it open (which was quite difficult), I was disappointed to see the toll rust had taken on the inside of a sealed piece of metal. Some of it is salvagable, but the gears are not. Winter came, and I ran out of money. Once May rolled around, I had enough spare time/money to start things back up again where I left off.
    Sandblasting everything didn't help the rust problem, but at least I was aware of the extent of the damage. I sand-blasted the case and everything as well, and it turned out nice. (..and yes, I know, I sand-blasted the mating surfaces. Those will be cleaned up with sandpaper or emery cloth.)
    After my first coat of paint, I was pleased. (..and yes, I realized I painted the mating surface for the clutch tension bearing on the output shaft cover. That will be fixed later.)
    On Saturday, May 19, 2007 Hours: ~3, Expenses: $0
    I came to the conclusion that if we were given a Model A at this point in time, we'd work on it. We've just been used to having one sit there, so we haven't worked on it.
    I decided to change that, and instead of practicing on all the extras, I might as well just go for it. I rounded up all of the Model A parts I could find. I cleaned out the small shop (mostly) to prepare for a Model A Restoration Factory... or something like that. On one side, I have an engine/clutch/transmission staging area. I have both spares mocked up so I can figure out how everything works and goes together. (Just ignore the 8hp Briggs.)
    On the other side I have a work bench where the stuff gets taken apart/cleaned up/rebuilt.
    I decided to take it slow and steady.. and careful. I removed/cleaned the carb. I removed intake/exhaust. I removed the side panel of the engine.
    Sunday, May 20, 2007 Hours: ~1, Expenses: $0
    I popped the top; removed the head/distributor. I did other little piddly stuff. Like I said, I am trying to take it easy so that I don't mess up more than my ignorance calls for.
    The cylinder walls felt better than I expected.
    Monday, May 21, 2007 Hours: ~3, Expenses: $0
    I removed the oil pan/pump. I removed all connections between the transmission and drive shaft. I removed all connections between the flywheel bell housing and engine. I changed out a shredded left read tire, so now I have a rolling vehicle. I only had to put Slime in 1 tire.. and these are at least 35+ years old. They also sat flat for at least a decade. I disconnected the wishbone suspension from under the flywheel, and strapped it to the frame almost in position, to prevent any tweaked metal. First problem: One of the two studs that the ball of the wishbone mounts to under the flywheel.. was spinning. The nut would not come off, and after consulting a spare shroud, I knew that this post that holds these two other posts in place was either broken, missing, or bent. Thankfully, after lots of work, it was successfully removed.
    Wednesday(?), May __, 2007 Hours: ~2, Expenses: $0
    I cleared out all our stuff from the shed. I put that baby in neutral and man-handled her around and around and around into position under the lift. I disconnected the shroud frame bolts, and the front engine mount. I hooked her up, and away went the entire power plant. Second problem I kept getting caught on something when I was trying to lift it out. I realized I never disconnected the starter, and I ended up cracking the flanged thin metal of the base of the floor starter button where it meets the starter. Thankfully this isn't that big of a problem, or an expensive repair.. about $15 for a new one.
    I separated the engine and everything else.
    It sure looks different now than it has in the past 4 decades.
    Thursday(?), May __, 2007 Hours: ~2, Expenses: $0
    I decided to get right to work rebuilding the thing I now know best; the transmission. I took off the shifter, and was very pleasantly surprised to find that the interior of this one is in damn near perfect shape. I cleared off the pounds and pounds of grease and dirt that also covered this one, cleaned up the surface, and masked it up to prepare for sand-blasting. In the process, I masked off Transmission #2 to prepare it for a second coat of paint. I figured this would be a good time to take a picture of the evolution of the process. On left is the first rebuilt transmission (#1) (ready to bolt up), in the middle is the one that's ready to be reassembled (#2), and on the right is the one fresh off the Model A (#3). Behind them are all the innards of Transmission #3
    I took the weekend off of Model A Resto for Memorial Day, but progress will begin again this week.
    June/July, 2007 Hours: ~3, Expenses: $0
    My uncle tried to locate the VIN which he claims is stamped onto the firewall. There is a plate stamped to the firewall with indecipherable stuff on it, but he claims that's not it. He gave me $100 towards the project and 2 books about restoring Model A's. School got in the way, so I didn't make much progress besides general learning about and cleaning up. Also, I got another project that is stealing my time.
    Saturday, August 11, 2007 Hours: ~2, Expenses: $0
    I finally decided that enough was enough, and it's time to work on this thing, even though I feel like crap because of this strep throat that's been going on since August 1.
    I wasn't sure how to get the flywheel off, but I managed. It's freakin' heavy.
    So, we (my brother and I) finally were able to put the engine up on an engine mount, and I disconnected all the pistons.
    Man, tolerances were not very tight on these machines. Physically, pieces look in good shape, so maybe it is meant to have a bit more play in places than I would expect.
    I know I could be making much faster progress, but it's kind of rough to convince myself to go on ahead when I don't have a secure source of funds. If necessary, I will fund this whole project, as it is my main intent on seeing this thing come back to life. But, in reality, my uncle is (more rich than I and) anxious to see me get some stuff done. It would be helpful to receive a little more financial encouragement, though.
    Sunday, August 19, 2007 Hours: ~2, Expenses: $0
    With some help from my brother, I removed spring retainers, springs, valves, lifters, crank, and cam. Not much is left on this block, and I'm about ready to ship it out for acid bath/etc.
    I organized a lot of the spare parts.
    Fall/Winter 2007, 2008, Spring 2009 Hours: ?, Expenses: $0
    Not much work has happened. No funds. I'm not exactly sure how interested my uncle is in helping.. financially/physically. Life marches on. Although, I organized all of the Model A related parts into different closed/lockable cabinets.
    In the mean time, my brother and I acquired 2 tractors, 7 antique stationary engines, and countless other projects.
    Personally, my BMW R90/6 (and school) took most of my time and money.
    Friday, June 26, 2009 Hours: ~0, Expenses: $0
    I considered my R90 near completion (except for something that just broke), and my summer school session completed. It was time to get back to work. We took the engine block and head to a local trusted machine shop to get dipped/fluxed and bored over (~60/1000ths over stock, 3.875 to 3.935) to compensate for excessive clearance and slight ovaling in cylinder #2.
    Monday, June 29, 2009 Hours: ~4, Expenses: $0
    With the engine at the shop, I figured it was time to focus on the next-in-line hurdle of the project; the brakes. Soon, it’ll go, but will it stop?
    Maybe at one time I knew it, but I was surprised to (re)learn that the rear had two sets of shoes, presumably for an emergency brake.
    ..and two grooves in the drum for them.. with big rollers.
    Front wheel has one set of shoes, and two (inner and outer) bearings.
    80 years of grease took a bit of work throughout the evening.
    I spent most of the night cleaning off the grease on the linkages and trying to figure out what a “spindle lock pin” is that I’m supposed to remove to get the brake actuator off. I just started taking it all apart, as it needs to anyway.
    By the end of the night, I just gave up on it. I don’t know how I’m going to get the actuator off.
    Work will continue tomorrow.. and next week.. and next month.
    Tuesday, June 30, 2009 Hours: ~3, Expenses: $75
    So, I got a call back from the shop. Seems there's a crack in the block. When I first heard this, I wasn't too concerned, based on my experience with other antique engines. But, upon investigating the crack first-hand, it might be a bigger problem. The crack runs from one exhaust seat almost to the bore of one cylinder. This will need to be welded up and machined down by someone who knows what they're doing. The machine shop recommended a shop far away in Illinois, but I'm going to look around the St Louis area first. I won't cut corners, though.
    Although, I have 2 more blocks to choose from in my shop. One block has everything but the pistons still in it, and the other is stripped all the way down.
    I'm going to take the other stripped-down block to the shop tomorrow and have them check it out. I noticed a crack running from part of the water jacket to where a head stud is. That's not as serious, and I've seen worse in running engines. So, if they recommend that it get repaired, I know there are shops around that can weld up part of a water jacket. I can grind it down, thread it back, etc. Assuming there are no other cracks/problems.
    On the plus side, after boil/flux, the head was deemed "good."
    Didn't have my camera with me today, sorry!
  2. mark1305
    mark1305 Old Enough To Know Better Supporter
    Feb 7, 2005
    6,776
    Merritt Island, FL
    Looking good! That's quite the project.
    My late neighbor and good friend across the street (passed away suddenly 3 years ago) had switched hobbies around 1998 from antique surfboards to a restored 1931 Model A truck very similar to what yours will look like. Cool old ride.
  3. Strong Bad
    Strong Bad Former World's Foremost Authority
    Oct 29, 2007
    17,734
    Omicron Persei 8
    45 years ago my dad bought my my brother and I our first car a 1932 Ford Model A 5 window coupe. Our's had been setting under a pepper tree for 30 something years before we started. There are tons of new parts still available for these cars. I remember that we tore it down to the bare frame which we carried out to the curb to hose off. I strongly recommend a brake upgrade kit and get rid of the stock mechanical rod actuated brakes.
  4. davorallyfan
    davorallyfan Commonist Supporter
    May 2, 2005
    19,557
    Capitalist
    With all due respect.
    Ain't there plenty of car websites on the interweb...
  5. jeep44
    jeep44 junk collector
    Mar 23, 2008
    2,611
    Canton,Michigan
    This is much more interesting than the 'restoration' of another 1995 airhead. I've always wanted a Model A.:clap
  6. bpeckm
    bpeckm Grin!
    Apr 2, 2008
    8,035
    Portugal
    :thumb
    Yea, man, keep it up.... fun to switch chapters in the same book... and I suspect that most of us airhead-types just like old school stuff anyway.... I vote to keep you here:thumb
  7. 2speed
    2speed Puching adventurer
    Mar 29, 2006
    954
    State of Maximum Density
    I strongly recommend keeping the brakes just as they are, and just make sure that they are done properly. They will stop the car just fine for a Sunday drive. The safety of steel from wheel to wheel.
  8. crazydrummerdude
    Nov 28, 2006
    8,639
    Los Angeles, CA
    Sorry?
    Mods can move this wherever they want, or delete it. I didn't know the world would come crashing down because of one car thread.. and I didn't feel like joining yet another forum.
    The plan is to keep it as close to original as possible, without being ridiculous. For instance, the show quality spark plugs are like $30 a piece. I think I'll just buy the $2 replacements. I don't plan any "upgrades" or anything. I'll try to keep the original paint and patina on most of it, it'll stay 6 volt, etc..
    #8
  9. jellycow
    jellycow out there without a clue, now on a '99 640 AVD
    May 29, 2005
    1,516
    South side of the Netherlands
    That's the way I like it, running as smooth as possible yet looking its age. :clap
    #9
  10. Wirespokes
    Wirespokes Beemerholics Anonymous
    Jul 26, 2002
    9,677
    Jackson's Bottom Oregon
    When it hit the ditch and fell on it's side, how much damage was causesd? It's hard to tell, but it looks to be in fairly decent shape - relatively undamaged.
    #10
  11. crazydrummerdude
    Nov 28, 2006
    8,639
    Los Angeles, CA
    Who knows the extent of how much it was minutely tweaked?
    But, of the evidence one can readily see, it appears that it hit on the lower right front, as the bumper mounts are totally fubar. That fender though (going off memory, it's "in storage") doesn't have much damage.
    We think we have the expertise "in house" to repair this ourselves. One uncle (former race car driver) told me to just beat it into shape. The other uncle (commercial pilot) thinks I should strip it down and take it to a frame shop.
    As seen in a generic-internet-pic of a Tudor 1929 Model A, it looks like the fender's height saved it.
    But, the steeting isn't messed up at all, and the running board/mounts are all fine, too. I guess the bumper/mounts did their job!
    The rear fender is cracked, and the rear bumper is bent a little bit.
    #11
  12. BubbaZanetti
    BubbaZanetti for a corrector life
    Jun 8, 2005
    13,187
    DC Metro
    wtf you dick, way to destroy the internet as we know it.:flip
    #12
  13. crazydrummerdude
    Nov 28, 2006
    8,639
    Los Angeles, CA
    :fyyff
    :lol3
    I'm gonna go take the other block to the shop.
    Edit: Because we've rubbed our grimey fingers all over it, you can't see the small crack in block#1 any more, but it's here somewhere:
    Wednesday, July 1, 2009 Hours: ~0, Expenses: $0
    So, here's block#2, that I just took to the shop.
    ..and here's the crack in the water jacket.
    When I handed it over to the guy at the shop, he said that's not a problem at all, as I was anticipating.
    ..and if all the crap hits all the fans, I'll tear down block#3 and take it to the shop.
    I will work on it a little more tonight, but will be out of town from Thursday to Monday. Tuesday night, I will go to a local Model A club general meeting. I've been meaning to do that for years now.
    #13
  14. Brewtus
    Brewtus Buffoonery, Inc.
    Jul 30, 2008
    8,098
    Portales, New Mexico
    Pretty nifty. You've convinced me to POSSIBLY start on my 1929 Model A Sport Coupe.
    Maybe.
    #14
  15. crazydrummerdude
    Nov 28, 2006
    8,639
    Los Angeles, CA
    Do it!
    So, today, I spent about 2 more hours cleaning and tearing apart and thinking and looking in parts magazines.
    Got the spindle lock pin out:
    So, I took it apart:
    ..and cleaned it up a bit more.
    My brother and I whipped up another batch of parts cleaner fluid, and dipped the parts. Then, we got to talking about what this is. I knew at one time, but forgot by now. I suppose I could look it up somewhere.
    I think something goes from that round piece down to a perch on the spring/linkage/whatever.
    #15
  16. bomberdave
    bomberdave Long timer
    Dec 9, 2002
    1,390
    assholia
    model a fords are about the only 4 wheeled things that still have my interest.
    those brakes are fine.
    rebuild it! drive it!
    best of luck-
    #16
  17. exhaust_nut
    exhaust_nut Been here awhile
    Sep 4, 2005
    194
    San Diego, CA
    Cool project. I had the fun of taking out my father-in-law's Model A truck a while back when visiting him. It is neat to drive and feel the past first hand. Reminded me of the feeling I get with my sidecar, slow and relaxing. + everybody waves as you go by.
    http://www.youtube.com/watch?v=W7iWNslX3hs
    (A short vid of my wife drivin the truck if you wana see)
    - Pete
    #17
  18. crazydrummerdude
    Nov 28, 2006
    8,639
    Los Angeles, CA
    Don't have speakers on my computer, but I enjoyed the video.
    :freaky
    #18
  19. ADK
    ADK .
    Dec 5, 2005
    9,691
    Did they have turn signals and brake lights by '29?
    #19
  20. Putts
    Putts Gettin' there.
    Aug 22, 2007
    11,875
    Bozoman, Montana
    :nah We're gonna keep it here while you wrench ... we all love that shit and it's good cross training.
    Then when you're all done and have gotten the grime off his hands, we'll all have our last says, and then I'll punt it to "Shiny Things" and let the rest of the FFs have a go at it.
    But for the moment, it's Old School wrenching at it's finest.
    :lurk
    #20
