6.6 gallon tank on a KTM 250 2 stroke
Discussion in 'Thumpers' started by gameyogi, May 10, 2014.
  1. gameyogi
    gameyogi Been here awhile
    Jun 22, 2010
    348
    Snohomish Washington
    Here's the deal, I have an Acerbis 6.6 gallon tank that I bought for my 525, but I want to put it on my 2004 250 exc for the tour of Idaho this summer (I could use the 525 but I enjoy riding the 250 so much more)
    I dropped the tank on the 250 and it fits perfectly except in one crucial spot where it touches the expansion chamber :eek1 The chamber I have on there is the FMF Gnarly, I've seen pics of other KTM 2 strokes fitted with this tank and they didn't have this issue, so it may be a pipe thing, but in lieu of buying a new expansion chamber I was wondering if putting some heat shielding between the tank and the pipe would work? Also, can this tank be heated and re-shaped?
    here are a few pics of the issue:
    any input appreciated
  2. jwdub
    jwdub Long timer Supporter
    Oct 2, 2005
    1,691
    SW Washington
    Count me as interested in what you find out. I ruled out a two stroke because of the lack of range. It would be nice to have an alternative.
  3. gameyogi
    Jun 22, 2010
    348
  4. Dogbone
    Dogbone More machine than man at this point
    Oct 2, 2005
    152
    Central TN
    Why not mount a couple 1/2" spacers between the tank and frame?
    Easy, non permanent, and it should solve the problem...
  5. Grreatdog
    Grreatdog Long timer Supporter
    Apr 6, 2007
    38,748
    Annapolis, MD
    You can't get a bit of rotation out of the expansion chamber mounts? My 200 can be varied some.
  6. WIsixfitty
    WIsixfitty rock and roll the bones
    Aug 7, 2006
    5,505
    west of road america
    just put a "performance" dent into the pipe in that area.
  7. OrangeYZ
    OrangeYZ Long timer
    Feb 11, 2008
    2,685
    Southern Oregon
    Agreed. That's the biggest part of the pipe and it probably won't make any difference.
  8. gameyogi
    Jun 22, 2010
    348
    I have a few performance dents already, guess 1 more won't hurt. I think I'll try shifting it around and look for other options first though.:D
    #8
  9. gameyogi
    Jun 22, 2010
    348
    oh, and I tried spacers, didn't work.
    #9
  10. jaredisaac
    jaredisaac Adventurer
    Apr 23, 2010
    15
    Eagle, Idaho
    I'm doing T1 on my 300 xc this year. 2 stroke fever.
    #10
  11. WIsixfitty
    Aug 7, 2006
    5,505
    this.
    #11
  12. 8gv
    8gv Long timer
    Nov 22, 2009
    4,519
    CT exile now in NH
    Get out the
    B F H
    #12
  13. RideFreak
    RideFreak Torque Junky
    Apr 17, 2009
    19,992
    Out in the NM Dez somewhere
    Just tale a heat gun and mold the tank inward in that location about 1/2'. I did it before to make a fan fit on one, it's pretty easy, use a blunt piece of wood to push it in and hold it in as you pour some cool water on the area.
    #13
  14. gameyogi
    Jun 22, 2010
    348
    I think I'll try ridefreaks solution first and keep the bfh to the pipe solution as a back up. Thanks for the input.
    #14
  15. gameyogi
    Jun 22, 2010
    348
    For those who are interested, I used a heat gun and carefully molded the tank, I also adjusted the fit of the pipe a bit and now have about 3/4 of an inch clearance. I will probabe add some heat shielding to the pipe as well but it looks like it's good to go, I'll just have to chack it if I dump the bike.
    thanks for the input, I'll post pics when I get it all mounted and finalized.
    #15
  16. RideFreak
    Apr 17, 2009
    19,992
    Glad it worked out :clap BTW, 2T pipes don't get near as hot as their 4T brethren.
    #16
  17. RussellM
    RussellM Been here awhile
    Apr 17, 2011
    409
    Brisbane(ish), QLD, Australia
    I'm going to re-animate this old thread rather than starting a new one.
    I am attempting to fit the same tank onto a 2000 250 2T EXC. I had the tank fitted to a 2001 520 EXC for a while with no issues, it is out of action for a while, so I am moving all the good gear over to the smoker.
    The pipe doesn't interfere, but I appear to have two other fitment issues;
    1. No way are the standard support brackets that bolt onto the front engine mount going to clear the pipe
    2. Clearance around back of radiators seems a bit tight, and I can't seem to get it seated, so it still moves around a bit.
    @gameyogi did you use the front supports, or just the single bolt in the frame spine, from your pictures I don't see the supports.
    #17
  18. Droptarotter
    Droptarotter Long timer
    Jul 11, 2007
    2,622
    Creston,BC
    I can't help you with the 2st question, but I'm trying to install the 6.6 gal tank on my 2000 520..........so what seat do you guys use and do you have a part number?
    #18
  19. Bucho
    Bucho DAMNrider Supporter
    Dec 10, 2006
    5,183
    Maryland
    Interesting old thread.
    I was looking at putting a larger tank on my ktm 300exc. I wanted a 100 mile range. It looks like ims makes a 4 gallon tank. I think that will be relatively safe.
    A 6+ gallon would be overkill for me...
    #19
