KTM rear brake locked on ??
Discussion in 'Thumpers' started by Milehi, Sep 7, 2013.
  1. Milehi
    Milehi Been here awhile
    Jan 19, 2011
    209
    Thin air
    I recently changed the brake fluid in my 450 EXC, twice now during moderate off road riding the rear brake starts to drag and heat up. When I notice and pull the clutch in to stop the rear brake slides the rear wheel to a stop with the rear brake smoking hot. Both times I backed off the pedal stop to let the brake pedal up and cured the problem on the trail. I don't think I drag the rear brake, and the reservoir does not look to be overfilled. Any Ideas? Thanks..
  2. Tbone675
    Tbone675 Been here awhile
    Feb 25, 2010
    144
    Hoosick Falls, NY
    Air in line?
  3. Dolly Sod
    Dolly Sod I want to do right, but not right now Supporter
    Aug 18, 2003
    19,426
    Richmond, Va
    I had a similar thing happen on my 640. Tweaked the pedal stop and fixed it (mine was also missing the pedal return spring)
    . Maybe the pistons in the caliper are gunked up and causing the pads to drag. Clean and grease the caliper slides and pistons (very light grease) for a start.
  4. drdave_2006
    drdave_2006 Been here awhile
    Jul 9, 2005
    470
    Geraldton Western Australia
    The dust seal can get squashed between the cylinder and piston and not let piston return. Happened on my DR 650 front brake.
  5. Navin
    Navin Long timer
    Sep 22, 2009
    40,163
    Adjust more free play at the pedal.
    darmst6829 and Bitingdog like this.
  6. Milehi
    Jan 19, 2011
    209
    Thin air
    I will look at those areas today, when I stopped the pedal was rock solid with line pressure, when I back off the pedal stop a quarter turn, pressure released and the pedal gets all the original free play back and works fine for the rest of the day. I know this is not doing my rotor any favors....
  7. bmwktmbill
    bmwktmbill Traveler
    Jul 16, 2005
    5,996
    Traveler
    No grease/oil/gas on brakes, use brake fluid only for cleaning or a brake-kleen spray type product.
    Keep brake fluid off paint and plastics.
    No dino oil products around brakes brothers.
    http://en.wikipedia.org/wiki/Brake_fluid
    Bleed the system, check the linkage.
    Dot 4 only!
    bill
  8. joexr
    joexr Banned
    Jan 4, 2011
    5,020
    They DO makes caliper grease for the pins .
    #8
  9. dezrat57
    dezrat57 New River, Arizona
    Jun 12, 2004
    171
    don't over think the prob....ur dragging the rear brake...lower the pedal below the level of the foot peg....even to a point of having to "search for it",,,that will prove it :)....i at any one time have at least 5 ktm' s of my own in my garage... and most have race numbers below the number of 3
    best of luck
    dave
    #9
  10. tkent02
    tkent02 Long timer
    Dec 6, 2008
    3,391
    Littleton, CO
    You didn't mention if it's a newer bike or an older one... There should be a return port or compensation port in the master cylinder, it's a tiny hole. If it gets clogged, the fluid can't return from the caliper to the master cylinder, the brake will do exactly as you are saying, it will just come on and drag. This makes heat, so the fluid expands and the brake comes on harder, which makes more heat. Eventually it just locks up.
    Very common on old bikes that have not had the brake fluid changed regularly.
    #10
  11. Milehi
    Jan 19, 2011
    209
    Thin air
    Is that port visible inside the master ? I will check it , and already lowered the pedal. Thanks for the input.
    #11
  12. tkent02
    tkent02 Long timer
    Dec 6, 2008
    3,391
    Littleton, CO
    To be truthful I haven't looked inside a KTM master cylinder, so I don't know.
    On other systems this port is less than a mm in diameter, so it is easy to clog with loose rust particles in there.
    #12
  13. spartanman
    spartanman regret minimizer
    Oct 17, 2009
    2,707
    Land of High Hopes & Low Taxes
    As noted above, check the brake pedal stop adjuster.
    #13
  14. Motopsychoman
    Motopsychoman Not a total poseur Supporter
    Jun 2, 2013
    10,811
    Oaklandish
    All of these things are possible.
    But, since it doesn't happen until it gets hot from use, very likely that the reservoir is too full. This is a pretty common problem.
    When the rear brake is cold, reduce the fluid level to the lower mark. You might want to go ahead and change out the fluid too.
    Does the wheel start to roll again after sitting a few minutes? If so, it is probably hydraulic lock up from fluid expansion.
    #14
  15. leanin
    leanin Been here awhile
    Jun 19, 2006
    188
    Have you adjusted the rod that goes into the rear master cylinder? If it doesn't have enough "slack", it won't let the brake fluid back into the master cylinder quick enough after releasing the brake. In effect, it is dragging the brake for you, the fluid gets hot, expands and it'll eventually lock the rear brake.
    #15
  16. joexr
    joexr Banned
    Jan 4, 2011
    5,020
    This is MOST likely the problem.
    #16
  17. atomicalex
    atomicalex silly aluminium boxes Super Moderator
    May 21, 2012
    16,592
    Detroit mostly
    #17
  18. Milehi
    Jan 19, 2011
    209
    Thin air
    Checked the areas that were discussed, bled it again, normal pedal freeplay and feel. After sitting overnight the pedal has almost no resistance and will barely pump up with about ten cycles. I made no adjustments to the pushrod or pedal stop, no fluid anywhere and normal level in reservoir. I must be getting air in when I bleed it...???
    #18
  19. HeadintheClouds
    HeadintheClouds Adventurer
    Apr 28, 2012
    70
    West Carolina
    I am having a similar issue with my 2015 350 XCF-W. During a day of technical riding, my rear brake would bind up. I would crack the bleeder screw, release the pressure and continue for a while, repeat. Got home, cleaned up the caliper, and had 4 straight days of riding with no issues. The last time I went riding, the problem returned.
    I have the back wheel off, and with the bike cold, I'm unable to push the brake piston back into the caliper with a C clamp, even with the reservoir cap off! If I crack the bleeder or loosen the bolt holding the line to the top of the master cylinder, the pressure is released.
    tkent02 mentioned a return/compensation port. Does anyone know where it is? Also, what is the small, dark, torx head bolt right under the site glass of the master cylinder?
    #19
  20. Yinzer Moto
    Yinzer Moto Long timer
    Jun 13, 2008
    55,899
    Pittsburgh PA
    Make sure all the pressure on the master cyl piston has been released. If the pedal is keeping the piston slightly depressed, the fluid can not get back to the master.
    The hole you are looking for will be at the bottom of the master cyl. I doubt it is clogged, a c-clamp would have pushed past any clog.
    #20
