What have you done to your GS or GS Adventure today?
Discussion in 'GS Boxers' started by PWarren4, Oct 26, 2012.
  1. Hikertrash
    Hikertrash Wasted Rock Ranger
    Aug 19, 2011
    4,457
    Arizona
    Middle Aged? Hardly!! Middle Aged would be 150,000 miles. Yours is almost at her prime.
  2. ClearwaterBMW
    ClearwaterBMW The Examiner Supporter
    Jul 17, 2005
    10,226
    Clearwater, FL USA
    well, maybe you will start selling some and I'll start buying.
  3. Daz the Aussie
    Daz the Aussie Hey, don't blame me, it's just who I am!
    Apr 16, 2008
    2,386
    Californicator
    +1! 50 K is just run in on one of these bikes. I have friends with 300 & 400 K miles on their bikes and they run just as good as new.
  4. Railgunn
    Railgunn Adventurer
    May 31, 2013
    16
    Winter Park, FL
    Refinished my System Case doors with a spray-on bedliner. The rough finish really hides the scars in the plastic well, and I prefer this finish to the shiny finish they had when I bought the bike. Also performed most of a major service myself; Alternator belt, air filter, oil, gearbox, and final drive fluid changes, and an oil sight glass replacement. Still have to check valve clearances, change the fuel filter, and do a carb sync. Had to wait until this weekend to do the valve adjustment, as I was waiting on a BMW spark plug wrench I ordered.
  5. bobinaustin
    bobinaustin planning for the adv
    Oct 22, 2008
    215
    Austin Texas
    i'd love to know how you did this?!
  6. ridin gaijin
    ridin gaijin riding > posting Supporter
    Nov 30, 2004
    1,116
    NM, AZ, but now, DC >.<
    Nice ride!
    It's a bit after the fact but you can pull them with a good zip tie and a pair of pliers. I think I learned that from JVB. Or the Hall o' Wisdom. Then just leave the zip tie on for next time. :thumb
  7. Y E T I
    Y E T I Unpossible
    Apr 26, 2007
    8,521
    San Diego
    I just use angled needlenose pliers to remove the plug wires. :dunno
  8. Railgunn
    Railgunn Adventurer
    May 31, 2013
    16
    Winter Park, FL
    Actually, I had the wire puller. I didn't have the long, deep socket necessary to reach the plug. Nobody in town had a socket that would work except my local BMW dealer.
    Can't say enough good things about my experience with Beemer Boneyard; ordering the service kit was easy, and delivery was prompt. :D
  9. a41capt
    a41capt Been here awhile
    Jul 15, 2011
    195
    Camp Verde, AZ USA
    Love it! She's my favorite date and knowing she'll be around that much longer only makes me happier!!!
  10. johnny80s
    johnny80s Been here awhile
    Jan 25, 2010
    368
    Fallbrook, CA
    I received my touratech handguard extensions.
  11. popscycle
    popscycle Fahren Away Super Supporter
    Apr 10, 2011
    15,858
    Central MA
    Put on a new CalSci XL windshield.
  12. I GS 1
    I GS 1 I 90S I
    Aug 18, 2009
    653
    SI, New Zealand
    It is mounted in a different cowl on the front of the lens. I'm not completely happy with the LED I am using and want to play around with that a bit more. When I get it right, I may make up some mounting kits which I could sell off.
    (legislation regarding motorcycle lighting gets very complicated and can be quite different in different countries, so which LED's can be used and how it is wired up may take some sorting out)
  13. I GS 1
    I GS 1 I 90S I
    Aug 18, 2009
    653
    SI, New Zealand
    I could do that. Give me some ideas as to what bits you might be interested in. We are still exploring the potential of the machine so wouldn't mind a couple more projects to play around with.
  14. JimVonBaden
    JimVonBaden "Cool" Aid!
    Feb 11, 2005
    101,524
    Alexandria, VA
    Odds are that the slack has been removed from the cable on the side you loosened the nut. Make sure you have 1mm slack then sync.
    Jim :brow
    PS Typically you rarely need to adjust the TB Sync on an R1200.
  15. Y E T I
    Y E T I Unpossible
    Apr 26, 2007
    8,521
    San Diego
    R1150GSA :deal :brow
    That's all good now. When I got home I re-balanced the TB's. Now, the only issue is rough idling when cold. Once it warm up it's fine.
    Got a GS911 today. Now I need to learn how to use it. First two things I want to do are make sure my O2 sensor is working and make sure my TPS is set correctly. I'm not sure I trust how well I did it with the voltmeter. Can anyone give me the basics of how to do those 2 things with the GS911?
  16. johnny80s
    Jan 25, 2010
    368
    Fallbrook, CA
    GSA side and center stands installed.
    Booster plug installed.
    Swapped black plastics for silver.
    Hung new chinese HID lights.
    New light switch installed.
    Touratech hanguard extenders installed.
    Todo:
    Mount fog PIAA 510 fogs
    Install HID in high and low beams
    Mount new Shinko 705 radials when I get them.
    Reinstall beak
    Take pictures for Clearwater as promised.
    Do write up on GS to GSA conversion and my experiences.
    Enjoy!
    I almost forgot I have to paint silver rox risers black because they be ugly!
  17. airspro
    airspro Been here awhile
    May 31, 2009
    136
    Mid Michigan
    Did my first oil and filter change on my new to me hack :) Pretty easy as you don't even have to put it up on the centerstand :lol3
    2001 1150GS
  18. MotoBoss
    MotoBoss Go Ahead
    Apr 15, 2009
    7,885
    USA
    xsf18cdf likes this.
  19. johnny80s
    Jan 25, 2010
    368
    Fallbrook, CA
    Had to ditch the shinkos. They are not going to get here on time.
    Got some Avon Distanzias coming tomorrow.
  20. VanIsland Rider
    VanIsland Rider Intrepid Adventurer
    Feb 25, 2011
    154
    Victoria BC Canada
    I also have suffered from a melted instrument cluster due to lensing by the adventure windscreen so I spent a couple of hours in the shop and fab'ed up a dash from scrap 0.125" aluminium to protect my melting tachometer!!
    <a href="http://www.flickr.com/photos/64257788@N08/9738608546/" title="Image 2013-09-13 at 2.21 PM by VanIsland_Rider, on Flickr"><img src="https://farm8.staticflickr.com/7376/9738608546_da86ff6b2f_b.jpg" width="1024" height="768" alt="Image 2013-09-13 at 2.21 PM"></a>
    <a href="http://www.flickr.com/photos/64257788@N08/9735369201/" title="Image 2013-09-13 at 2.20 PM by VanIsland_Rider, on Flickr"><img src="https://farm8.staticflickr.com/7428/9735369201_a098d9b522_b.jpg" width="768" height="1024" alt="Image 2013-09-13 at 2.20 PM"></a>
