Old 06-04-2013, 11:04 AM   #61
sarathmenon
Oddometer: 793
Brilliant stuff . Did you weigh her after all the changes? I am curious to see whether you got it under 170 kilos.
sarathmenon is offline   Reply With Quote
Old 06-04-2013, 12:40 PM   #62
gpmucci OP
gpmucci
Oddometer: 233
No, impossible.:)
Inviato dal mio HTC EVO 3D X515m con Tapatalk 2
gpmucci is offline   Reply With Quote
Old 06-04-2013, 01:08 PM   #63
toro618
toro618's Avatar
Oddometer: 959
Highly unlikely.
Take a showroom F8, chop the passenger pegs, remove the upper rear grab bar, chop off the entire rear light bracket and plate bracket, gut the cat, replace the can with a lighter piece, eliminate the right side front rotor/caliper, replace the entire headlight cluster/wind screen with a single light/ktm shell, go tubeless and you will have dropped 45 lbs at most.
toro618 is offline   Reply With Quote
Old 06-04-2013, 03:25 PM   #64
sarathmenon
Oddometer: 793
Originally Posted by gpmucci View Post
No, impossible.:)
Man, you have a way of spoiling my hopes. I was thinking that with all the changes out there, you might have squeezed out 10kg or so.
I agree that this bike is actually reasonably light weight when you factor in all the stuff that is on there. In fact, I can't actually think of any two cylinder bikes on the market that is 50 state road legal and lighter than the F800 or rather the F658.
Old 06-04-2013, 05:08 PM   #65
gpmucci OP
gpmucci
Oddometer: 233
Tomorrow I will weight it.
But the standard one I measure at 204 kg real.
This bike is
260 kilos real!
170 is 34 kgs minus! Than standard.
Old 06-04-2013, 05:13 PM   #66
sarathmenon
Oddometer: 793
My bad, I meant 170 kg dry, which was supposed to be 5 lesser than stock, from what I recalled. If you managed to pull off 30 lesser, well, you should be the person building bikes for BMW
Old 06-06-2013, 04:15 PM   #67
gpmucci OP
gpmucci
Oddometer: 233
Ok. Tomorrow I will weight it.
For now I got a friend weighting his standard with 5 lt gasoline. 204 kg. Tomorrow I will see mine with 10 lt.
Old 11-16-2013, 05:34 PM   #68
RCTID
RCTID's Avatar
Oddometer: 60
what was the final verdict on the weight of this monster?
RCTID is offline   Reply With Quote
Old 11-19-2013, 01:51 PM   #69
MotoRod700
MotoRod700's Avatar
Oddometer: 39
Where in Bella Italia are you ??
MotoRod700 is offline   Reply With Quote
Old 01-19-2014, 05:16 PM   #70
gpmucci OP
gpmucci
Oddometer: 233
In Bologna
Inviato dal mio iPad utilizzando Tapatalk
Old 01-19-2014, 05:41 PM   #71
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,462
2 month later.. loving this
Keep the smile on your face!
Originally Posted by Reaver View Post
You can be imitated but not replaced. You're such a special blend the recipe is guarded like KFC's 11 herbs and spices.
Loutre is offline   Reply With Quote
Old 01-20-2014, 03:32 PM   #72
OZZY-GS
OZZY-GS's Avatar
Oddometer: 396
2 months later I presume it weighs more
Riding
BMW F800GS
OZZY-GS is offline   Reply With Quote
Old 01-20-2014, 03:34 PM   #73
gpmucci OP
gpmucci
Oddometer: 233
Ah ah. I deliver the bike without info on the weight.
Old 02-17-2014, 12:30 PM   #74
Mika_AT
Mika_AT's Avatar
Oddometer: 68
lovely
Mika_AT is offline   Reply With Quote
Times are GMT -7.   It's 07:33 PM.
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
