Can you ID this Fighter Jet
Discussion in 'Shiny Things' started by slideways, Nov 2, 2007.
  1. Heymarz
    Heymarz Gaily Retarded
    Jan 3, 2005
    3,236
  2. LowandSlo
    LowandSlo YMMV
    Jul 21, 2005
    361
    out there somewhere
    Came across this rare bird:
    :evil
  3. Klay
    Klay dreaming adventurer
    Nov 19, 2005
    124,325
    right here on my thermarest
    Cessna 210-5(205)
    :rofl
  4. EvilGenius
    EvilGenius 1.5 Finger Discount
    Apr 7, 2007
    20,337
    DFW, Texas
    Bigass 210?
    Maybe modded for sky diving?
  5. LowandSlo
    LowandSlo YMMV
    Jul 21, 2005
    361
    out there somewhere
    Well technically it's a 210-5, but called a C-205, N205CL and probably 205.
    Now back to the regular broadcast.:D
  6. Klay
    Nov 19, 2005
    124,325
    Shouldn't this be in Shiny Things?
  7. Heymarz
    Jan 3, 2005
    3,236
    What if it's camouflaged, does that count as a "shiny thing"? :dunno
  8. Klay
    Nov 19, 2005
    124,325
  9. EvilGenius
    Apr 7, 2007
    20,337
    DFW, Texas
    Got one out in our hangar.
    I want to fly it badly.
  10. AK Bear
    AK Bear Long timer
    Feb 22, 2003
    1,633
    Anchorage
    Don't know if I 've seen one of those before, it doesn't look like a 210. My 206 has aft doors on the right side, but it's a U206. I know they made a 205 that was configured differently with two doors up front but haden't known of aft doors on the left.
  11. EvilGenius
    Apr 7, 2007
    20,337
    DFW, Texas
    We have a turbo'd 210 out in the hangar. Looks almost exactly like that except the cowling maybe a little bigger.
  12. nofate
    nofate what blackflies?
    Nov 3, 2005
    2,899
    Chapleau, ON
    A C210 has a cantilever wing (no struts) and retractable gear. Hard to confuse with a 206.
  13. Klay
    Nov 19, 2005
    124,325
  14. nofate
    Nov 3, 2005
    2,899
    Chapleau, ON
    Apparently its a C205 which was built for only two years and was derived from the 210 although it bears much more resemblance to the 206 and 207 Stationaires. It had the 260 hp Continental IO-470 motor.
  15. AK Bear
    AK Bear Long timer
    Feb 22, 2003
    1,633
    Anchorage
    Here is my 206. http://www.airport-data.com/aircraft/photo/110896.html
    I searched for it on the site and the photo came up. I have no idea how it came to be photographed or who Doug Robinson is. Kind of wonder what's up. Maybe some kind of plane spotting, like train spotting was like in the 50's.
    Notice the length of the flaps and that the alerons are extended as well. This is part of the Robertson kit that allow it to take off at below at 40 mph and climb like a mother! The radical leading edge palys a part as well. I've really only put it through max climb once just to see what the book stats looked like in reality. Pretty fn scary/amazing. 300 ft take off in calm wind with a clilmb over a 50 foot object at 54mph, not knots, mph. Clears the 50 ft object in 589 ft. Now that's a nose up position,but absolutely stablewith a leg of right rudder pushed in. It's a real climber but it looks pretty reckless when you do it. We put a set of GAMIs in and an instrument that reads each cylender head temp and exhost gas temp so we can lean below peak. We've been consistantly runnng at 11 gallens/hour where as befor the GAMIs we used 15 and tried to be rich of peak. We have way coller engine temps and save about fifteen or twenty dollars per hour on fuel.
    We can, and have, carried 4 large adults, a 100lb golden retrevier. a zodic raft and motor, all our gear and 3 ice chests filled with food and drink for 4 days. That sucker can hold a ton in the floats which are in the perfect weight and ballance place for heavy items leaving the rest for sleeping bags, dogs, gourmet food and a boat. Try putting all that in your jessies!
    nofate, you have some very nice radios in that panal, but did you really pull the mixture during the runup? What's up with that? We usually just check the mags, fuel flow and cycle the prop. Pull the the rudders up clear left and right and go, of course after Hood Tower lets us go.
  16. nofate
    Nov 3, 2005
    2,899
    Chapleau, ON
    Thats a nice 206 you got there with the Robertson STOL.
    I confirm function of the mixture control during runup by pulling it briefly until the motor just starts to die. After a long warm up taxi to my takeoff area I think it also helps to clear the plugs of any carbon buildup during extended low rpm, rich mixture operation. Taxi at 1,000 rpm unless the prop is picking up water. This proceedure is taught at the flight schools around here.
  17. flanga
    flanga Delusions of Adequacy
    Sep 19, 2005
    2,806
    New Hampsha
    Why wouldn't you want to fly it well?
  18. Klay
    Nov 19, 2005
    124,325
    :lol3
    Mitsubishi Mu-2
  19. Photog
    Photog Charismatic Megafauna
    Oct 13, 2003
    46,323
    Cackalacky
    Damn. MU-2. :thumb
    Back when I was flying, I wanted one of these old Rockwells:
    Actually, if it had wings and an engine I wanted it, but you know what I mean. There was an old 500 or 520 that sat for a long time at our local FBO, and I used to scheme and scheme to find a way to snag it. As usual, purchase price wasn't the issue...it was the "what's next" that was adding the dollars to the project. :lol3
    anyway...remember Bob Hoover in the Shrike?
  20. Klay
    Nov 19, 2005
    124,325
    Someone posted this one here somewhere a while back.
    <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/tOZEgKXJMCE&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/tOZEgKXJMCE&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
