my winter build
Discussion in 'Hacks' started by zipper421, Dec 31, 2012.
  1. zipper421
    zipper421 Been here awhile
    Aug 28, 2012
    206
    space
    i was just wondering what it was 56 is fine
    i have talked to claude
    was just wondering
  2. davebig
    davebig Another Angry Hun !
    Jan 19, 2004
    13,530
    Minnesota
    Ok
  3. Bobmws
    Bobmws Curmudgeon At Large
    Jun 6, 2005
    5,920
    Same trailer, different park, FL
    I have a question on the swaybar, perhaps better directed to Claude.
    Are the arm lengths equal, and the attachment points equidistant from the axle center on each wheel, or can the preload be adjusted to create a 'balance' in the actual travel?
    Additionally, will camber adjustment affect the swaybar settings?
  4. davebig
    Jan 19, 2004
    13,530
    Minnesota
    Yes Claude has the real handle, but arms are equal length, they are attached buy multiple hiem joints so I don't believe they affect camber.Since you have a Hannigan chair I don't believe theirs has equal length arms, I don't know as mine is equal length to wheel centerlines, Good reading here http://www.hpsidecar.com/sidecararticles/sidecararticles.html DB
  5. zipper421
    Aug 28, 2012
    206
    space
    i have drawn up a body but im not sure what im doing yet
    i started with a 24 inch wide car
    im down to 22 inches
    the length is stock ural 70 something
  6. davebig
    Jan 19, 2004
    13,530
    Minnesota
    You got me sorta measuring 76" long 23"wide big box trunk,seat 22" at cockpit opening , Ural like nose 18" at narrowest.I guess you got to figure how you'll use it.Will wife,children or dog go along? Are you going camping ? MInes way bigger than I needed but I liked the idea of being able to haul allot of stuff. Your an enigma to us all out here in Adv hack land
    Enigma :1: an obscure speech or writing
    2: something hard to understand or explain
    3: an inscrutable or mysterious person
    More idea's ? https://canadagsa.smugmug.com/Motorcycles/BMW/27402423_W5qLMb#!i=2304444828&k=6RQ5wGJ
    There's allot to consider, you still need trail reduction and a different final drive for that R1150 the bigger it gets the more difficult it is to get moving with that 31/11 final drive and 6th will be down hill only.DB
  7. claude
    claude Sidecar Jockey
    Mar 17, 2002
    5,756
    Middleburg, Pa. (Snyder County)
    If you are planning on a swaybar for a hannigan it is a little different deal than what has been pictured here. We have done ouur swaybars on them and have used hannigan's type also. Our swaybar on a hannigan requires the sidecar body to be jacked up or have the swaybar run through the body. The arms do not have to be equal. The arm position (angle of the arm) is crtical as is the placement of the heim end linkcage. This is more critical with a rea rmount swaybar...and then things do change a little more on a hannigan as they do not use a front pivot swingarm on the sidecar except for their high performance sidecars. Lots of variables need to be addressed. Feel free to call me if you wish,
  8. Bobmws
    Jun 6, 2005
    5,920
    Thanks Claude.
  9. zipper421
    Aug 28, 2012
    206
    space
    has anyone here done a diff swap with the 850
    what years will work
    any info would be appreciated
  10. davebig
    Jan 19, 2004
    13,530
    Minnesota
    Zipper
    Since they are actually not differentials the bmw folk call them final drives, any r850r oilheads will work but there's lots to consider.Doe's your bike have ABS ? If so you'll need a ABS final drive or remove your ABS which isn't that hard.
    The 850 used a 37/11 there are some early 1100rs that had 34/11 all the r1100gs and r had 33/11(gears stamped in top by the breather) anything is a step in the right direction. If your not going to the mountains or around the world and your easy on clutches you may not need the 37/11, they are a pain to shim if one buys the gears and builds one. I maybe able to help you out in the future as I have 3 extra final drives.If only it where as easy as slapping a chair on and living happily ever after.DB
    http://www.ebay.com/itm/110974721419?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2648 He wants too much.
    You'll eventually want one of these: http://www.ebay.com/itm/BMW-R-1150-...Parts_Accessories&hash=item35c432eeb3&vxp=mtr
  11. zipper421
    Aug 28, 2012
    206
    space
    im watching that final drive
    you think its to much
    i made my own y pipe
    i only buy what i cant make
  12. zipper421
    Aug 28, 2012
    206
    space
    today was a good day
    so tempted to put it on the ground but i still have the sway bar to build
    every thing els is done
    almost time to powder coat:clap
  13. davebig
    Jan 19, 2004
    13,530
    Minnesota
  14. zipper421
    Aug 28, 2012
    206
    space
    not sure what you sent me
    hiems are off ebay
  15. davebig
    Jan 19, 2004
    13,530
    Minnesota
  16. zipper421
    Aug 28, 2012
    206
    space
    past couple days spent on sway bar
    progress is slow but hopefully well thought out
    rework sucks
  17. AceRph
    AceRph Retired slacker
    Jan 12, 2003
    24,914
    Kingdom of Gav
    Nice work. :clap
  18. zipper421
    Aug 28, 2012
    206
    space
    thanks
  19. davebig
    Jan 19, 2004
    13,530
    Minnesota
    Zipper
    We've grown accustomed to pretty nice work, but that's really a standout! Only one question is that bar solid ? Who did you consult on how much bar is enough ?DB
    I think you owe yourself a present a liquid cooled torch and a cooler or something !
  20. zipper421
    Aug 28, 2012
    206
    space
    thanks dave
    google miller syncrowave 350
    o its liquid cooled
    the lights in the neighborhood go dim and all the tvs go black when i fire up my welder:rofl
