2009 KLR650 Main Fuse Blows Instantly
Discussion in 'Thumpers' started by Liberia, Aug 17, 2010.
  1. Liberia
    Liberia Fortunate
    Mar 22, 2010
    564
    Murfreesboro, TN
    I just returned from a 1,500 mile trip from Massachusetts to Tennessee with absolutely not problems. A few days after returning I blew the main (20 amp) fuse. I replaced it and rode about 100 yards and it blew again. Again and it blew instantly. Now as soon as you turn the key on the fuse blows. My son has been tracing all the wires down looking for a place where a wire grounds out, is unplugged,etc. Nothing so far.
    Any ideas? Thanks.
  2. DirtDriven
    DirtDriven Not Cheap,Thrifty
    Mar 11, 2009
    299
    True North, GA
    Have you checked your wiring harness. Their was a recall on the wiring harness from rubbing the frame. One place I know is right under the gas tank and I know their are a couple of places that was mentioned in the recall. If you have not had it done may be a good place to start
  3. concours
    concours WFO for 50 years
    Dec 2, 2008
    9,696
    USA
    unplug everything.... put a fuse in it. start plugging things back in... listen for the pop
  4. Doorguy1979
    Doorguy1979 Dreamridin'
    May 14, 2009
    627
    Parachute, Colorado, USA
    This exact thing happenned to me on my "08, there was a recall after it was done under warranty. 1st time it happened the Dealer couldn't find anything, the fuse didn't blow anymore ect. Rode it home, and another 150 miles. It died at 75 on the highway.........total electrical failure, Kawasaki replaced my entire wiring harness...under warranty.
  5. Liberia
    Liberia Fortunate
    Mar 22, 2010
    564
    Murfreesboro, TN
    Thanks for the suggestions so far. I'll pull the tank off plus call the dealership and inquire about the recall. Just bought it so not sure if it's still under warranty.
  6. Trooper
    Trooper Been here awhile
    Oct 20, 2009
    245
    Left Coast
    Assuming the original owner did not do the recall, it is a Federal safety recall on all 08/09 models. It should be covered even if you are not the original owner. The recall also covered the muffler mounting bolts.
    Greg
  7. K7MDL
    K7MDL 2015 Tiger 800XCx
    Aug 14, 2008
    1,749
    Maltby (near Woodinville), WA
    Ignition switch harness shorting out on the ignition coil bracket on the left side of frame under the tank. Recall replaces that and sheaths it. There are several more rub areas such as under the rear tank mount and behind the headlight. I sheathed all the rub spots myself and had the recall work checked off as done, I did not want them reversing my fine handywork :-).
    Check out http://www.klr650.net/forums/showthread.php?t=58585
    I have a post with marked up pics on that forum, but cannot find it for some reason. This link above builds on that.
  8. XDragRacer
    XDragRacer Long timer Supporter
    Mar 25, 2009
    5,518
  9. Liberia
    Liberia Fortunate
    Mar 22, 2010
    564
    Murfreesboro, TN
    My son called the local Kawasaki shop and, of course, the warranty ran out in June (wouldn't you know it). They checked and it showed that the wiring harness recall had been done on the bike. So my son took off the gas tank and found one spot where the wiring harness was pressed but no rub through or anything that looked like a potential ground situation. He then put in a new fuse and it worked. So he is going to do a closer exam on the harness at that point, move it to help avoid pinching and then we'll ride it for a while to make sure the problem is solv - eded as Inspector Clouseau would say.
    Thanks to everyone for your help. Perhaps one day I'll know enough to pass it forward.
    By the way, there's a ride report in my signature from the Boston area back to Nashville on this bike 2 up with a full load of luggage. That's about as far as I want to travel in that condition. I'm thankful the problem didn't occur during the trip.
    #9
  10. DirtDriven
    Mar 11, 2009
    299
    True North, GA
    I would check the harness out yourself for sure. After I had the recall done. I still found a couple of places that had potential for wear through problems later on. So it's a good thing to check it out yourself. Besides if you see the recall kit itself is kind of funny anyway. Well to me I guess. Good Luck
    #10
