Reverse bleeding brakes
Discussion in 'Trials' started by BEEF706, Oct 8, 2014.
  1. BEEF706
    BEEF706 King of the dumb dab
    Sep 29, 2006
    1,416
    Rio Rancho NM
    So I have yet another question that confirms my noobness :D. My 04 Rev 3 developed a hole in the rear brake line from rubbing on the chain (I know, i really should have caught that). I got a replacement, and installed it but could not get it to bleed at all. The consensus was that with these brakes it is better to reverse bleed. I got a syringe, and attached it to the nipple with hose, opened the valve pressed and nothing. I can't get any of it to go into the line, What is the most likely place i went wrong? I have bled brakes before, and while I am a ham fist, I have never had this kind of issue. suggestions? I am finally getting to where i want to use my rear brake to turn and am learning to hop a bit, and i REALLY need to work on off camber downhill turns (which are kind of sketchy front brake only).
  2. jonnyc21
    jonnyc21 Trials Ninja
    Feb 8, 2011
    4,467
    Boise aria
    Works best if you have a friend to help...
    Have them put the pressure on the line and then crack each fitting tell you get a little fluid out, then move to the next starting with the one at the caliper, then the one at the pump, then you should get enough pressure to push past the bubble and get the flow your looking for.
    I found on one of my bikes that I ended up needing to do a top down pressure cycle to get enough air out of the system for a good reverse flow...
    Hope this helps.
  3. lineaway
    lineaway Long timer
    Oct 1, 2011
    16,466
    Edgewood, New Mexico
    Nope won`t work like that. I`m the last one to bleed that bitch.:1drink
  4. Little R
    Little R Been here awhile
    Feb 23, 2012
    139
    SLV Colorado
    Buy beer take to lineaway and pay attention
  5. anonny
    anonny What could go wrong?
    Mar 20, 2007
    7,400
    Beautiful Revelstoke BC
    I'd pull the bleed nipple and try pushing through it to see if it's plugged, if not I would reinstall and move down the line until I found where it is plugged.
  6. jonnyc21
    Feb 8, 2011
    4,467
    Boise aria
    . :ear
  7. motobene
    motobene Motoing for 51 years
    Mar 9, 2013
    8,863
    ABQ NM & Wichita Mountains OK
    A bleeder must be opened up to pass fluid in reverse. The tapered ends of the typical bleeders suck for mounting hoses, and the fitting is loose when open so it will leak. To pressure bleed you need something that goes in snug and holds the bleeder hose on securely.
    I use mountain bike brake line fittings that are barb ended and have the same M6X1.0 thread as the AJP brake bleeders. Maybe the fittings I have are rare? I'll try to remember to measure the specific thread for AJP bleeders.
    Maybe something in here might work?
    http://www.jensonusa.com/Hydraulic-Brake-Lines-and-Fittings
  8. lineaway
    lineaway Long timer
    Oct 1, 2011
    16,466
    #8
  9. thegraydog
    thegraydog 2 wheels X 6 ways
    Aug 29, 2004
    894
    the Coconino
    This works for a wide range of problems. Mechanical ones, at least...
    #9
  10. BEEF706
    Sep 29, 2006
    1,416
    Rio Rancho NM
    Definitely, more like a case :D
    #10
  11. lineaway
    lineaway Long timer
    Oct 1, 2011
    16,466
    So 8 am tomorrow?:D At your place.:ear
    #11
  12. BEEF706
    Sep 29, 2006
    1,416
    Rio Rancho NM
    We should be down by 10 or so, but I'll probably have to put it off till after fiesta, but the case offer stands :1drink
    #12
  13. lineaway
    lineaway Long timer
    Oct 1, 2011
    16,466
    Sounds good, Don`t forget next weekend is the vintage at Roswell!:clap
    #13
  14. BEEF706
    Sep 29, 2006
    1,416
    Rio Rancho NM
    Working on my kitchen pass
    #14
  15. motobene
    Mar 9, 2013
    8,863
    The specific AJP bleeder thread is the common M6 X 1.0 (standard metric coarse) and the barb end of the mountain bike fitting is for 4mm hose.
    A person could make a pressure bleeding fitting from a 6mm fastener if need be by drilling a hole through the center a pushing hose on. If you lack a lathe, putting the fastener in a drill and turning slowly against the side of a bench grinder wheel works as a lather substitute to finish the outsides of things well.
    #15
  16. batoutoflahonda
    batoutoflahonda Long timer
    Aug 8, 2007
    1,462
    Zhoushan China, for now.
    To get a tight seal I use surgical tubing. Most hard wear stores have it but some hide it and you have to ask for it. Guess to keep the druggies away. Any way, then I use thin safety wire, but any will do. Wrap it and give it a good twist. Be patient as it can take a while for it to get moving. Assuming the nipple isn't plugged.
    #16
  17. wilto
    wilto Adventurer
    Nov 23, 2009
    54
    Albion Park NSW Australia
    Have you taken the cover off the top master cylinder, have you opened the bleed nipple while trying to squeeze fluid through line and remember to close it while you are refilling the syringe. I find it easier also if the lever adjustment is backed all the way out lots of free play on lever works best. Have someone watch top resivior for bubbles and overflow. G'luck!
    #17
  18. Sting32
    Sting32 Trials Evangelist
    Oct 27, 2009
    2,377
    Minneapolis, Ks
    Dont forget, just a tiny "seen it" for you. the rubber boot on the master cylinder is to keep dirt out, but dirt can get in there, and the main "pushrod" could have dirt keeping it from resting against the circlip, if not clear up against the circlip, which is at rest position, the tiny orfice that lets oil into the line or out of the line into the tank, doesnt line up, aka is closed... make sure you have free play, you can always do it the old way, pump oil from resivior to the slave cylinders, it just takes longer and can again only happen if the master cylinder plunger is aligning the hole up when lever is released fully... Be patient, grasshopper it should go...
    #18
  19. BEEF706
    Sep 29, 2006
    1,416
    Rio Rancho NM
    This may be the issue Sting. I took the line and banjo bolts off to check for obastruction after talking it over with NMTrailboss at San Yo yesterday, and they were clear. So i put the bottom banjo bolt back on adn opened the nipple and put fluid up through it with the syringe, and that was fine, fluid came out the top. so I re-attached the top line to the master cylinder and re installed the pushrod and now there is no way to get fluid up through the bottom. I think I have the pushrod lined up right, I ran out of time last night. I think it is definitely an issue with the master cylinder. will the lever still travel if the pushrod is not lined up right? There is no fluid entering the cylinder form the reservoir either as far as I can tell. :ear
    #19
  20. lineaway
    lineaway Long timer
    Oct 1, 2011
    16,466
    Told you all the experts,:huh:cry:rofl:puke1:lol3. :1drinkBack bleeding blows.
    #20
