Triumph Scrambler
Discussion in 'Triumph Tigers' started by danger_dave, May 29, 2006.
  1. nofate
    nofate what blackflies?
    Nov 3, 2005
    2,899
    Chapleau, ON
    From what I can see of your chain it looks pretty dry and not 'over oiled'. If your chain is too tight maybe it caused the seal behind the sprocket to leak. Shouldn't be too hard to replace the seal, but check your chain tension.
  2. FoothillRyder
    FoothillRyder Tiger Cub
    Oct 8, 2010
    406
    Biker Heaven
    Both of my Hinckley twins had that symptom just after a service. Clean the area and keep an eye on it. I agree, the chain doesn't look over-oiled; but that looks very much like oil 'leaking' from the sprocket cover rather than anything serious.
  3. Blinky03
    Blinky03 Adventurer
    May 20, 2011
    22
    Nelson - New Zealand
    Hi - new to the thread - recently picked up a tidy 06 (blue and white) and after removing the seat I noticed that there is a signature "C L Smith" (or similar) hand painted on the base of the tank - it is painted in gold the same as the pin stripes on the sides of the tank - I'm guessing it was done by the paint guy at the factory - quiet a cool touch - has anyone else come across this ? - will try to attach a pic
    Am enjoying the tread and have learned a great deal about scramblers
  4. milkman
    milkman can't find my screwdriver
    Jun 4, 2007
    137
    Steak and Kidney Inmate
    Any information on the wide tyre conversion or the mag wheels? Haven't seen that done before.
    Would it make the scram feel too "floaty"?
  5. gk ryder
    gk ryder is this thing on?
    Aug 13, 2009
    64
    Great Southern Land
    yeah since the pin stripe is 'hand painted' then the painter initials it.
    At least your one makes sense, my one was done by a guy call Nail! the picture in my mind is pretty crazy....
    Nail: "Nail hungry. Nail finish blue bike..."
    Supervisor: "good job Nail. you can go to lunch now....err leave the fuel tank please!"
    :rofl
  6. Blinky03
    Blinky03 Adventurer
    May 20, 2011
    22
    Thanks gk ryder - was this only done on the early UK manufactured bikes ?
    And where ever you are CA SMITH, you did a nice job painting the tank
  7. gk ryder
    Aug 13, 2009
    64
    Great Southern Land
  8. satcen
    satcen Been here awhile
    Feb 9, 2010
    251
    Czech Republic/Greece/Turkey/Macedonia
    Thanks for all your replies. The chain lubrication is w/out suspicion - I´ve got Scottoiler. But my guess would be some dirt under the sprocket seal because I use the bike quiet often off-road. In that case a thin needle could save the game ...
  9. ChrisLX200
    ChrisLX200 Been here awhile
    Feb 8, 2010
    165
    Macclesfield, UK
    I have a Scottoiler on both Scrambler and Tiger1050 and are certainly the cause of lube leaking out from behind the front sprocket cover(s). Hot weather causes a bit more lube than anticipated being be fed to the chain but I can't be arsed adjusting it (we don't get that much hot weather!)
  10. goodcat8
    goodcat8 Long timer Supporter
    Feb 19, 2008
    3,432
    Topanga CA
  11. phil37
    phil37 n00b
    Sep 21, 2011
    4
    I watched a recent documentary about the making of the 2010/2011 Thunderbird where they show a guy in the factory handpainting the "coach line" as they called it. Then he signed the tank in the same area as in your pic . They said he's been pinstriping tanks for over 30 years! The CEO said they still handpaint the lines is to show their attention to detail and pride the builders have in their workmanship.
  12. Blinky03
    Blinky03 Adventurer
    May 20, 2011
    22
    Hi phil37 - Do you recall the name of th Doco ? - I woud like to see it if possible
  13. phil37
    phil37 n00b
    Sep 21, 2011
    4
  14. Blinky03
    Blinky03 Adventurer
    May 20, 2011
    22
    I'm looking at fitting a Scott Oiler but cant seem to find a good location to mount it, any suggestions ? ..... does anyone have pic's of a tidy fit ? - thanks
  15. trustme
    trustme Long timer
    Jun 11, 2007
    3,896
    Auckland , New Zealand
    If you are Auckland based you could have a look at mine, it's mounted in behind the mufflers so it is unobtrusive but a bit fiddly to refill.
    Welcome to the mad house:evil:evil:evil
  16. Farside13
    Farside13 Adventurer
    Sep 20, 2010
    78
    Jo'burg South Africa
    I visited the factory a few years ago and we found CR Smith who had signed the tank on our 2006 Bonnie. This the man in action...
  17. Blinky03
    Blinky03 Adventurer
    May 20, 2011
    22
    Thanks trustme, not in Auckland sorry, other Island. Do you have any pic's of your fitted Scott and does it get hot next to the mufflers & what model Scott ?
    Yeah your right, this is a mad thread..... crazy yanks and crazier kiwi's, heaps of knowledge about a great bike
    Is Rhodie human ?
  18. Cooper-Clubman
    Cooper-Clubman Adventurer
    Jul 23, 2011
    60
    Germany, Rösrath
    I think you are right. Same issue my Thruxton. The gasket has been worn out for my chain has been too tight. Piece of cake to repair. If you 've got the skills, you can do it on your own. (I had it repaired at my local Honda dealer ;) ). You don't loose a lot of oil there. Looks worse than it is.
  19. alskee750
    alskee750 Been here awhile
    Jan 7, 2011
    564
    NYC
    Does anyone have a set of Peg Extensions lying around that there not using and would like to sell me? If so PM me..
    Alex
  20. Maxacceleration
    Maxacceleration Off the grid
    Oct 9, 2009
    4,081
    Wa
    I have the Mas cs cover which leaves the sprocket mostly exposed.
    Chain goo drips down to the frame and looks unsightly.
    Chain lube does not clean off easily.
    Without the stock cs cover you really notice it.
    A thought when you think to change covers.
