KTM 640 Adventure-17/42T gearing question
Discussion in 'Thumpers' started by bmwktmbill, Jan 5, 2011.
  1. timolgra1
    timolgra1 Been here awhile
    Mar 8, 2009
    659
    No fixed abode
    It's generally reckoned to have your sprockets in an ODD/EVEN ratio or EVEN/ODD for that matter, to get better life.
    #41
  2. gunnerbuck
    gunnerbuck Island Hopper
    Nov 19, 2005
    6,722
    N.V.I, B.C.
    I'm thinking more along the lines of the chain having a larger radius at the bends which is less stress full... Also with 17/45 the chain ends up farther away from the swingarm pivot point and therefore has less contact with the rub blocks...
    #42
  3. timolgra1
    Mar 8, 2009
    659
    No fixed abode
    Very true.
    #43
  4. Tonicu
    Tonicu Been here awhile
    Dec 9, 2011
    186
    Spain
    After seeing my 47 teeth r/s has lost 7 teeth this last week :eek1, I followed your advice and ordered a rear steel KTM sprocket finally with 45 teeth. At 29€ it's half the price of the powerparts one, and I wouldn't say the latter would last as much. As for the c/s, as wasn't sure what to choose, I ordered a set of 15, 16 and 17 teeth to try different options. For my offroad use I think I'll stay with the 15/45, and when planning longer onroad trips I can quickly change it for a taller one. As for the chain, I decided to go for the DID Z-ring, not too expensive at 90€ and apparently giving fairly good results.
    #44
  5. Tonicu
    Dec 9, 2011
    186
    Spain
    . At last I found time to get the new oem 17 c/s, 45 steel rear and RK chain fitted. The 17 c/s does fit without any issue, I didn't even have to remove the case guard, a straight-on fit. Well advised - thanks - I changed the nut/washer as well.
    My previous ratio was 16/48, which wasn't bad offroad but clearly too short on pavement, even on twisty roads I seldom used anything else than 5th gear. First gear seems enough to get into trouble and out of it when on my usual playground :evil and for the real tight single track I can fit the 15 c/s. Great for the 80% off 20% on I normally do.
    I'm happy to have found a street friendly bike -er ... those vibrations .. -:eek1, without apparently losing too much of the real offroad fun
    #45
  6. nfranco
    nfranco over macho grande?
    Jan 29, 2006
    1,123
    la ca
    I ran 17/42 for while as my street setup but have switched to 17/38 as my freeway and commuter setup, between that and bar end weights the bike has smoothed out on the road.
    15/42 is for dirt, going to try 15/45 soon.
    #46
  7. WIsixfitty
    WIsixfitty rock and roll the bones
    Aug 7, 2006
    5,505
    west of road america
    A question to confirm before I order a 15t.
    I'm currently running stock 16/42 but have a 45 laying around that I want to throw on for some woods work/fun this fall.
    It seems the 16/45 will not work.
    Will a 15/45 work with standard chain length?
    :1drink
    #47
  8. Queen of Spades
    Queen of Spades tall drink of water
    Mar 20, 2009
    1,972
    Decatur, GA
    I replaced the drive chain & sprockets last week with a 14/40 combo (steel). It was pretty nice off road, but buzzed at 55mph down the freeway. I put my stock 16T on the front to match what came with the bike. 16/40 works okay for dirt with no added load. I'd like to try a 17T up front but I don't have the chain length.
    #48
  9. bmwktmbill
    bmwktmbill Traveler
    Jul 16, 2005
    5,996
    Traveler
    Get some masterlinks and add a link.
    b
    #49
  10. MSH
    MSH The Salt
    Mar 17, 2007
    3,306
    Utah
    #50
  11. bmwktmbill
    bmwktmbill Traveler
    Jul 16, 2005
    5,996
    Traveler
    #51
  12. MSH
    MSH The Salt
    Mar 17, 2007
    3,306
    Utah
    Factory issued 42.
    #52
  13. dirty_sanchez
    dirty_sanchez Dirty_Sanchez
    May 8, 2006
    4,161
    Louisiana, Baton Rouge
    This sprocket. No, stick with OEM for the front sprockets. You can pick any flavor for the rears though.
    The front OEM sprockets are a slight bit thicker than the aftermarket brands. Why is this important you may wonder? The way the front sprocket is mounted, coupled with the counter shaft sleeve with the machined inside lip and O-Ring compresses and seals against oil leaks on the counter shaft.
    As the countershaft sprocket nut is tightened that little O-Ring which fits over the counter shaft is compressed against the inner race of the countershaft bearing.
    The proper amount of compression on that little O-Ring is influenced by the correct thickness of counter sprocket. Aftermarket CS's are 0.015" (if I remember correctly) thinner than OEM. Since they are thinner that little O-Ring doesn't get compressed enough to create a proper seal and oil leaks will rear their ugly head.
    I did like the 17/42 combinado on my 640A for general roadwork. Too tall for single and two-track IMHO.
    Dirty
    #53
  14. MSH
    MSH The Salt
    Mar 17, 2007
    3,306
    Utah
    Thank you very much. :thumb
    #54
  15. MSH
    MSH The Salt
    Mar 17, 2007
    3,306
    Utah
    I searched but couldnt find a part number for the OEM sprocket. Called my local KTM parts guy and he couldnt find one either. Any one know what the part # is?
    #55
  16. bmwktmbill
    bmwktmbill Traveler
    Jul 16, 2005
    5,996
    Traveler
    This is all true in my experience, worn out couple of 17T sprockets. In the woods stay in the power band.
    b
    #56
  17. slackmeyer
    slackmeyer Don't mean sheeit. .
    Jul 23, 2007
    4,385
    Berzerkeley, CA
    Have him look up the OEM sprocket for the Duke or Duke II, that should be the one you're looking for.
    Agree with the others, 16/45 is what I run for dual sport gearing. 17/42 is just street, in my opinion.
    #57
  18. gunnerbuck
    Nov 19, 2005
    6,722
    N.V.I, B.C.
    Counter Shaft sprocket
    17 tooth -580 33 029 017
    16 tooth- 580 33 029 016
    15 tooth- 580 33 029 015
    Rear Wheel sprocket steel
    42 tooth- 582 10 051 042
    45 tooth- 582 10 051 045
    I usually run 17/45 in the KTM steel sprockets, these give the longest life coupled with a DID chain...
    At the moment I am running 17/44 with a JT rear sprocket which has given ok service life...
    fixed
    #58
  19. J Dupuis
    J Dupuis Adventurer
    Apr 27, 2005
    34
    KTM Engine Sprocket 17 T #58033029017
    Save some grinding KTM Chain Dampersheet 17 T #58730047100
    #59
  20. MSH
    MSH The Salt
    Mar 17, 2007
    3,306
    Utah
    Much obliged gentlemen. :thumb
    #60
