Bed Buddy....anyone use one of these?
Discussion in 'Equipment' started by TheBigLebowski, Mar 28, 2013.
  1. TheBigLebowski
    TheBigLebowski It's true, mistakes were made.
    May 17, 2010
    99
    Bloomington, IN
    Thinking about buying/manufacturing one of these to attach to a 5x8 trailer. Anyone have or use one of these?
  2. SATEX
    SATEX Long timer
    Nov 1, 2002
    4,896
    San Antonio, TX USA
    I use one that is similar.... basically a knockoff... from RockyMountainmc.com
    Mounted in my truck. Works great. The tie down points are well placed and my bike(s) always stay stable.
  3. BillUA
    BillUA Las Vegas, NV Supporter
    Mar 24, 2013
    853
    Las Vegas Nevada
    X2 Those things work great!
  4. TheBigLebowski
    May 17, 2010
    99
    Bloomington, IN
    I like the bed buddy because it has the three slots for bikes.......If I haul two, I'm set.....if I only haul one, I could center it on the trailer.
  5. Weekend_warrior
    Weekend_warrior Been here awhile
    Feb 18, 2006
    539
    E-track bolted to the front of the bed works great. Spray it match your truck. Use tie down anchors for the chaulks to keep the bikes tire from turning. I know 3 folks that have this setup. Works well for dirtbikes. Can be had cheaply. Search around Northern tool. I think a section of E-track is only about 15 bucks or so. The hook anchors are a couple bucks a peice.
    I have a GMC with that came with the cargo management system. Works fairly well after moving some tie down blocks to the front to use a chaulks for a single bike and tie down locations for muliple ones. I can get 3 bikes in the back.
  6. Oshiat
    Oshiat Been here awhile
    Feb 2, 2012
    157
    Land of Fruits & Nuts
    I have a bed buddy in my 05 2500HD and it works great. To help prevent the front to the bed from flexing, I put a piece of 1/4" x 2" plate as a backing plate between the bed and cab. Bolts go through the bed buddy, bed, plate and then are lock-nutted.
