Aluminium Welder ? South Denver ---> COSPGS
Discussion in 'The Rockies – It's all downhill from here...' started by aiMhi, Dec 22, 2013.
  1. aiMhi
    aiMhi Roostafarian
    Sep 9, 2010
    1,098
    SODE- Colorado
    I am doing some minor upgrades on my XR650R. This includes getting some additional reinforcements added to my aluminium sub frame since I like to ride long distance and load around 50lb on the back. I made a steel one a couple years back but it is bent - badly after a hard crash - it is very time consuming to make with around 12 or so precise connection points. I am looking to add some support triangles etc. (indicated by blue tape) to strengthen the notorious flimsy subframe. I will be adding the ManRacks brace that comes with the rack - this will add an additional bridge between the two sides of the subframe to prevent flex.
    Does anyone know of a recommended shop/ individual that could help me get this done?
    Appreciate the input!
  2. shiftymike
    shiftymike Hooligan Schmooligan Supporter
    Jul 27, 2008
    414
    Van down by the river!!
    Edgewater Jeep does some good welding on aluminum. 303-477-8766. 5038 W. 44th Ave.
  3. aiMhi
    aiMhi Roostafarian
    Sep 9, 2010
    1,098
    SODE- Colorado
    Thank you for the info shiftymike.
    B
  4. modette
    modette Rider
    Jan 10, 2007
    5,657
    Monument, CO
    Did you ask Wayne Demonja? He probably could do it.
  5. aiMhi
    aiMhi Roostafarian
    Sep 9, 2010
    1,098
    SODE- Colorado
    Yeah I should hit him up. Not sure if it's too small a job for him.
    Later,
    B
  6. Moto Beak
    Moto Beak Professional Amateur
    Feb 21, 2006
    335
    Pueblo, CO
    +1 for Edgewater Jeep. They did a good job on a swingarm for me.
  7. Merfman
    Merfman Cape truster... Supporter
    Sep 11, 2009
    2,213
    Colorado Springs
    Les Wagner at Wagner's Prop Shop here in Colo Spgs. I've had Les do much aluminum and mag welding.. he knows his job! :clap
    (719) 471-7767
