Garmin Montana
Discussion in 'Mapping & Navigation' started by AugustFalcon, May 18, 2011.
  1. TravellingStrom
    TravellingStrom Been here awhile
    Jun 29, 2007
    397
    Rockhampton, Australia
    My routes don't have via points they are a to b
  2. Drif10
    Drif10 Accredited Jackass
    Jun 12, 2003
    53,585
    Gates of Moscow
    Bingo. Exactly that. Been messing with these things for 20 years now, always found the best way to 'get to know' a unit was to make it do things. Take you to the grocery store. Over to your buddy's place.
    I usually scan ahead once aroute is plotted by the unit, just to see if it's going what is, to me, the 'right' way. So damn tired on Friday, I didn't do it, mainly because I knew where I was going. Just happy that I caught this little issue, will be interested to see if your unit does the same thing. It's always been my impression that gps units are like snowflakes when it comes to routing.
  3. Drif10
    Jun 12, 2003
    53,585
    Gates of Moscow
    Could you not do this in route planner on the menu screen?
  4. dlh62c
    dlh62c Long timer
    Jan 11, 2006
    1,603
    A route will always contain at least two via points. In your route, Point A is via point 1 and Point B is via point 2. You can add more, but they can total no more than 50.
    daryl
  5. christian
    christian Long timer
    Jul 9, 2004
    3,329
    Redwood City, CA
    Agreed...
  6. ducnek
    ducnek Trying not to feel it too hard
    Apr 11, 2007
    1,074
    Rooster Poot Tennessee
    Got my new Montana, man have I got a lot to learn.
    I watched the tutorials and loaded a route to my 600, when it goes to calculate the preloaded route I get this:
    "Route Calculation Error:
    Maps do not have routable roads in this area"
    I have installed City Nav NA, I think I read what causes this in this thread but can't find it now. Please have mercy and help this noob out.:baldy
  7. Emoto
    Emoto Sure, why not?
    Feb 24, 2004
    21,446
    SE Mass
    You sure you have CN installed on your Montana? And enabled?
    View the map screen, touch the little 3 horizontal line icon, then setup map, then Map Information select map, then see if CN in on your list and enabled.
  8. ducnek
    Apr 11, 2007
    1,074
    Nope it's not on the list. How do I get it there?
  9. Emmbeedee
    Emmbeedee Procrastinators
    Mar 19, 2008
    11,564
    Near Ottawa, ON, Canada
    Well Jim, both my Montana and Nuvi 780 looked like they saw some kind of junction at Metcalf street but they didn't say to get off the 417 to get to it. I can see how it would be confusing, though.
    Sent using strings and tin cans and Tapatalk
  10. ducnek
    Apr 11, 2007
    1,074
    Nevermind I think I figured it out! D'oh!
  11. Emoto
    Feb 24, 2004
    21,446
    SE Mass
    :thumb
    One thing to bear in mind is that CN will tend to take precedence over all your other maps unless you disable it.
  12. Drif10
    Jun 12, 2003
    53,585
    Gates of Moscow
    Figures.
    Like I said, never found any two units routed the same. Any code geeks have any idea why? Not that it'll make any diff, my own curiosity more than anything.
  13. Drif10
    Jun 12, 2003
    53,585
    Gates of Moscow
    Yes. :nod
    This has always been the case in any garmin.
  14. BigOgre
    BigOgre Long timer
    Feb 13, 2012
    1,013
    Between sandy beaches and the sandhills
    Came across a very similar issue just this morning and figured if I searched enough I'd find an answer. But seeing as you all brought it up . . . :wink: CN loaded into internal memory. 100k Topo loaded onto SD card. Route developed in BC and sent over - all works fine but only if SD card is left out. Once I drop the card in, Montana tells me route doesn't match map. Check of map settings only shows Topo installed and enabled (along with factory loaded maps) and CN seems to have disappeared. Shut down, remove card, and CN shows back up as enabled. I'm doing something wrong, right?
  15. atlas cached
    atlas cached Long timer
    Jun 16, 2012
    1,060
    Sounds like your City Nav and Topo have similar FID numbers....
    Did you use MapSource to send them, or BaseCamp?
  16. Emmbeedee
    Mar 19, 2008
    11,564
    Sounds like a job for JaVaWa Device Manager. Download it, connect the gps and run JDM, and it'll likely tell you what's wrong and how to fix it.
  17. TravellingStrom
    Jun 29, 2007
    397
    Well to me they are not via points. I am going from a to b, if I go Via C then that is a via point, that is what the word means. Obviously Garmin use the word different but your point is taken
  18. cablebandit
    cablebandit Web Adventurer
    May 9, 2005
    864
    Stormstown PA
    I don't think the via points are via points in an A to B route. Like I said I routed 4100 miles to Alaska from Pennsylvania. It sounds like you are saying that each turn point is a via. It's not since the unit made the route. If I add a via point in basecamp it's announced as a via point on the turn by turn directions. There are well over 100 turns in the route I made (that the unit routed) and there is no issue with routing that way.
  19. Emmbeedee
    Mar 19, 2008
    11,564
    I think you're right - via points are things you've added to force a route to go a certain way. If the gps creates the route, the locations it selects for turns, etc, are not via points.
  20. Emmbeedee
    Mar 19, 2008
    11,564
    Only 8 posts left to make then I'll have posted more than DRTBYK! I'm in the final stretch, unless he comes back soon. :lol3
