DR350 Thread
Discussion in 'Thumpers' started by leonphelps, May 16, 2007.
  1. kaukasion
    kaukasion Adventurer
    Sep 26, 2012
    24
    still lost i pulled the carb back off my 96se today and cleaned it good
    carefully reassembled everything
    and still the same problem
    just no top end power
    it literally even in neutral feels like its got a rev limiter keeping it at 6-6.5 k u can pin the throttle and thats all it will rev to
    i tried with tank cap removed, installed a clear fuel filter to check fuel flow and its staying full and flowing good, i tried without air filter no change, choke on or off same thing, only with it on get exhaust popping on top of it
    brand new iridium ngk plug
    carb cleanered everything completely removed everything and cleaned and sprayed out with compressed air
    i thought it was my slide diaprahgm but i know its seated correctly used some shallac on it to be sure it stayed in place this time
    im lost guys any idea's? its a totally stock bike with the stock jet sizes (both jets brand new)
    hadnt ran in 3 years, and will only do 50mph grrrrrrr
  2. RuggedExposure
    RuggedExposure Now with more rugged
    Apr 5, 2011
    1,343
    NM desert wasteland
    It has to be something with your carb. What elevation are you running at?
  3. slartidbartfast
    slartidbartfast Life is for good friends and great adventures Supporter
    Dec 23, 2003
    17,747
    Southern Louisiana or Southern England or ...
    Are you sure the slide diaphragm doesn't have any holes or splits in it?
  4. Bonnie & Clyde
    Bonnie & Clyde Wishing I was riding RTW
    Jan 10, 2006
    4,601
    Gardnerville NV
  5. kaukasion
    Sep 26, 2012
    24
    no holes or rips in the diaphragm i look at it over a light to see and took my time and made sure it was mounted with a good seal
    it never bogs out if i ride at wide open so im thinking its not running way rich or anything, and it doesnt appear to be running lean because i dont get surging
    also how many turns out should the idle mix screw be? i have it at two and it starts and idles fine till it warms up then it wants to drop and bog till it dies and im thinking i have it too rich maybe?
    this is frustrating the crap outta me because this is the third time ive had this thing apart and im running out of idea's on what it could be and im relying on this bike as my only means of transportation to get to work right now :( ive hit a tough spot financially and dumping money into this thing like a pit is killing my savings for a car as well
    elevation is around 100 above sea level
  6. MrPulldown
    MrPulldown Long timer
    Aug 18, 2009
    10,734
    Truckee
    DR350 carbs are either BST33 or TM33's. 33 is 33millimeters. Where?
    THere was a write up, on here, max or TT, I can't remember or find it now. It compared the two carbs and had measurements of the bores and outside of the intake side, etc. Anyone have a link.
    I have a BST (CV) carb that I hope is a 31mm, for a DR250. Don't know how to check unless I pull my carb which I DO NOT want to do jsut to take a measurement .
    If anyone has a link to that write up that would be AWESOME!!
  7. motolab
    motolab Long timer
    Feb 16, 2006
    7,905
    What is (are) the exact throttle position(s) during which the symptoms occur?
    Regards,
    Derek
  8. Klay
    Klay dreaming adventurer
    Nov 19, 2005
    124,325
    right here on my thermarest
    I don't have a manual. Does anybody have information on quantity and weight for fork oil for a '97 DR350SE?
  9. kaukasion
    Sep 26, 2012
    24
    wide open throttle, bike seems to run great in all midrange and pulls well, just will not rev past 6k and in 5th 6th gear doesnt have the power to even pull them out to 6k and im having some idle issues but im sure i just have mixture screw wrong but i have the extended one so i need to tweak it
  10. tonusmaximus
    tonusmaximus maximus Supporter
    Jun 18, 2011
    1,115
    N KY
    front fork oil type Fork Oil SS05
    front fork oil capacity (each leg) *495 ml (16.7/17.4 US/Imp oz)
    Sent from my SPH-D700 using Tapatalk 2
  11. motolab
    motolab Long timer
    Feb 16, 2006
    7,905
    In a previous post you said that "it never bogs out if i ride at wide open". Which is it?
    Regards,
    Derek
  12. tonusmaximus
    Jun 18, 2011
    1,115
    N KY
    10 weight is what manual calls for
  13. Klay
    Nov 19, 2005
    124,325
    Thanks for the information.
  14. kaukasion
    Sep 26, 2012
    24
    i mean that it doesnt feel like its running rich and going to foul the plug at wot
    but it doesnt seem to be running lean either it just seems to have no more power at wot as it does at high mid throttle
    its the strangest thing but with this being stock and a brand new main jet that is stock size im just scratching my head at this point, im missing 20mph and cant find it, it really feels like maybe the slide cannot come all the way up or something, but when i look it over it appears nothing is wrong with it
  15. kenaroo
    kenaroo I am because i ride
    Nov 30, 2005
    946
    Austin Tejas
    Hey guys.. I have a. Boxed in swing arm and a race tech shock that I never installed on my dr350 before I sold it.. If anyone is interested pm me.
  16. motolab
    motolab Long timer
    Feb 16, 2006
    7,905
    Does the problem change relative to engine temperature?
    Regards,
    Derek
  17. nickgindy
    nickgindy Lover of the KLR
    Jun 30, 2011
    3,306
    Indianapolis, Indiana
    Pick this up tomorrow.
    Comes with parts bike and extra parts.
  18. nickgindy
    Jun 30, 2011
    3,306
  19. MrPulldown
    Aug 18, 2009
    10,734
    Truckee
    Down load the manual from Greg bender's website. It states the oil level shoudl be 5.7 inches from the top.
  20. kaukasion
    Sep 26, 2012
    24
    the wot problem does not matter to engine temp
    the idle gets worse when warm (just figured this problem out, i have the extended idle mix screw and for some reason its backing itself out with the vibration of the motor running it was wayyyyyyy rich and when i blip the throttle i can watch it slowly turn out... hmmmm )
