Bl**dy Good Job There, Ural 2014
Discussion in 'Hacks' started by outfit, Jan 26, 2014.
  1. outfit
    outfit Been here awhile
    Jul 23, 2008
    731
    Orkney Isles
  2. JustKip
    JustKip Long timer
    Apr 28, 2007
    9,600
    Fresno, CA
    Old news, spread rather thin :deal
  3. rivercreep
    rivercreep Banned
    Feb 27, 2007
    3,243
    S.E. Pennsylvania (Reading)
    ...and I'm waiting for NikaSil plated bores instead of iron liners for better heat dispersion.
    (wish in one hand, shit in the other; see which one fills up faster.):wink:
  4. Qwik
    Qwik Adrenaline Addict Supporter
    Apr 27, 2008
    10,806
    Aspen Colorado
    Pull the cylinders and send em off.
  5. rivercreep
    rivercreep Banned
    Feb 27, 2007
    3,243
    Something tells me, that there might be something in the design of the Urals boxer engine, that might not work with that concept. (why else would Ural keep the iron lined jugs and not take advantage of the improved technology themselves?):ear
    ...although I am curious, how many CC's could one gain by removing the iron liners (if what you suggest is possible) and plating the cylinders?
    I also have never seen any company offer straight NikaSil plated alloy jugs for ANY straight air cooled Boxer out there.
  6. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    20,243
    Orange County, CA
    BMW has nikasil bores.
    My 86 r80 had em, as did my 92 r100gs
  7. rivercreep
    rivercreep Banned
    Feb 27, 2007
    3,243
    I did not know that...thank you!
    Come the day I can afford a Ural, I should be able to afford the plating then = something to look forward to.
  8. villageidiot
    Apr 29, 2010
    20,243
    Orange County, CA
    i don't know what good plating nikasil over a steel/iron liner would be.
    all of the nikasil jugs ive used/seen have been aluminum bores, plated in nikasil, jaguar v8's are alloy block with nikasil bores, as are MBZ alloy block engines.
    #8
  9. rivercreep
    rivercreep Banned
    Feb 27, 2007
    3,243
    What you describe is exactly what I want...(for superior heat management and longevity)
    Can one remove the iron liners in a Urals jugs, refinish them and NikaSil plate them?
    I know the DRZ and DR650's use the plating instead of steel liners and have no problems at all.
    ...looks like I'll have to join soviet steeds and ask over there.:ear
    #9
  10. villageidiot
    Apr 29, 2010
    20,243
    Orange County, CA
    to my knowlege, no, nikasil is most effective on aluminum jugs.
    i think nikasil would kind of defeat the purpose of an iron liner.
    iron liners definitely do have their place, they expand less, and can be honed and bored, where as nikasil cant. chip the nikasil, its bad news bears. gotta send out to replate,
    #10
  11. rivercreep
    rivercreep Banned
    Feb 27, 2007
    3,243
    I think you missed my question/point...I was talking about being able to have a Ural with NikaSikl plated all alloy jugs. (hence the comment about removing the iron liners, refinishing the jugs and having them plated with NikaSil for more efficient cooling)
    #11
  12. villageidiot
    Apr 29, 2010
    20,243
    Orange County, CA
    the liners are much thicker than just the nikasil coating.
    youd have to re cast cylinders, and bore them, then have them coated...... id stick with iron liners.
    #12
  13. ragtoplvr
    ragtoplvr Long timer
    Oct 18, 2007
    12,988
    central USA
    It is also possible to bore out the iron liners and fit mikasil aluminum liners. It is done on some outboards where the heat transfer from Iron liners is too low, to save those expensive blocks. I do not know how successful it is. I know of one that had it done by a good mechanic, and it was still running when I sold my trailer. Of course many outboards only get 50 hours or less a year.
    Rod
    #13
