Alarm system battery for "05" r12gs
Discussion in 'GS Boxers' started by studley, Jul 18, 2009.
  1. studley
    studley Lord and Master
    Feb 9, 2007
    702
    Phoenix Arizona
    Does anyone know what the common size or number is for the alarm system?
    It looks like a thick watch battery on the computer, but there is no part number.
    Dealer says $6.50 for the battery and a 5 to 10 day wait to get it.
  2. Anorak
    Anorak Woolf Barnato Supporter
    Jul 23, 2004
    73,073
    Petaluma
    It's either a cr2 or a cr123. You should be able to find either at a drugstore or Radio Shack for about $6.00. I'm pretty sure it's a CR2.
  3. digger2
    digger2 A cad & a bounder
    Sep 17, 2006
    1,292
    Prescott Az
    for the rt alarm battery. factory alarm is called a Dwa6 for that model
  4. Anorak
    Jul 23, 2004
    73,073
    Petaluma
    I'm making the assumption that it was about the batteries in the alarm itself. I think you're probably correct that it's the batteries for the remote.
  5. studley
    Feb 9, 2007
    702
    Phoenix Arizona
    I am looking for the one that goes in the unit on the bike. I have to drop the fender well to get to the bottom of the unit to pull the battery. The remote still works fine. But I will get a new battery for it also at the same time.
  6. Anorak
    Jul 23, 2004
    73,073
    Petaluma
    As I said, I'm pretty sure it's a pair of CR-2. You don't drop the fender, you take the rear plastic cover which BMW calls the "rear carrier" off to access the alarm.
  7. studley
    Feb 9, 2007
    702
    Phoenix Arizona
    Well just went out and tore in to the fender area. (It's only 114 degrees, probably 120 in the garage) Pull the taillight assy. and three more screws and the fender well drops. The alarm unit in held in with three screws. Remove one and loosen the other two. Take off the top of the unit and remove the cover inside to get to the two batteries.
    They are Sanyo Lithium CR17335 (3 volts). They look like a half of a AA battery.
    Oh well, Google is your friend....
  8. Anorak
    Jul 23, 2004
    73,073
    Petaluma
    It appears that the CR17335 cross references with the CR123.
    #8
  9. studley
    Feb 9, 2007
    702
    Phoenix Arizona
    How did you find that? I tried Google and found them at Radio Shack. $20.00 for the pair. Sure hope they work...
    #9
  10. Anorak
    Jul 23, 2004
    73,073
    Petaluma
    Try CR17335 CR123. A pair of generic CR123 cost about $4.50 at Fry's Electronics here in the S.F. Bay Area.
    #10
  11. studley
    Feb 9, 2007
    702
    Phoenix Arizona
    Thanks for the link. I will hit the Fry's here in Phx. later today.
    #11
  12. stealthpilot313
    stealthpilot313 Stealthpilot
    Jun 9, 2008
    97
    Little Red Dot
    Sorry to revisit this after so long. Am not very good at this but would like to attempt to replace my batteries. Does anyone have a step by step way of doing this. Is the alarm unit where the battery is stored obvious if I can remove the rear fender?
    Many thanks for your replies.:norton
    #12
  13. teomannaskali
    teomannaskali Long timer
    Mar 8, 2011
    1,185
    Plaka 34
    How do you disable the alarm?
    I disabled it (getting the three beeps) but then when i tried removing the bike main battery it was shouting all the time. Very annoying...
    #13
  14. studley
    Feb 9, 2007
    702
    Phoenix Arizona
    Read post number 7.
    and yes,
    The alarm control box is the first thing you come to. You have to come in through the fender from below because the screws are on the bottom. Just pull the unit and you can work on the bench to change the battery's.
    If you google the alarm unit and replacement batterys you will find a parts breakdown photo. This will show you what the unit looks like and where it is.
    Yes, a cold frosty beverage will make the job easier!!
    #14
  15. stealthpilot313
    Jun 9, 2008
    97
    Little Red Dot
    Many thanks to CrustyAPO for his kind assistance.:rofl
    #15
