Removing stick coil (GSW) & the oil change
Discussion in 'GS Boxers' started by Otherworld, Oct 11, 2014.
  1. Otherworld
    Otherworld Been here awhile
    Feb 24, 2013
    561
    For now, Toronto...
    Two related questions:
    How is the stick coil removed without a removal tool? My sense is "not recommended without one", yet curious if anyone out there is doing their maintenance without one and how that's working out.
    When performing the oil change, I think something upwards of 1/2 litre of the oil is under the valve covers. I assume its ideal to have as much of the dirty oil out before re-filling with the new oil, but how important is this given the amounts? And can you get the oil out without removing the stick coil?
    Cheers, y'all!
  2. Cogswell
    Cogswell Road General
    Jan 3, 2005
    13,187
    Riding with my pal Richard Cranium
    Put something on the ground to keep from scratching your bike. Lay it over on each side for about 10-15 minutes, that should get all the oil out of each cover.
    :freaky
    Mike
  3. Bill-66
    Bill-66 The End of the Republic is upon us... Supporter
    Sep 13, 2009
    9,857
    The Southeast
    The stick coil has nothing to do with oil????
    Use two screwdrivers on the stick coil to remove....
    There MAY be two tablespoons of oil in each cover...more like one...
    Edit...
    Oh..I think I see what you're saying...for an oil change..don't pull the valve covers..that's ridiculous...no you have to pull the stick to get the valve cover off...
    What kind of oil are you planning to use? Def will be asking you what your old oil smelled like...pay attention to that, you don't want to be caught with your pants around your ankles when he asks...
  4. JetSpeed
    JetSpeed Naviator
    Nov 28, 2007
    7,653
    Coronado, CA - KNZY
    This is a useful thread with some creative suggestions on removing the stick coils without the "tool", word of caution: be careful.
    I do not believe that getting those last drops of oil that reside in the valve covers is all that important.....to most people.
    To me it's crucial, there is a lot more oil in there on the new GSW then you would think, at least 6oz.
    I only remove the valve covers to get that extra oil out when the maintenance schedule calls for a valve adjustment, otherwise I drain the oil with the bike on it's center-stand using a 6qt plastic drain pan underneath, once the oil is only dripping I grab the bike securely and tip it to one side towards me and hold it there for 30 seconds or so, I repeat this several times on each side until no more oil flows out when tipped.
    I do it this way due to the fact that I already have the bike on its center-stand during an oil change, just make sure not to go too far to the side (you can feel it) and to keep a small amount of pressure pulling the bike back so the center-stand doesn't fold up.
  5. JCMagoo
    JCMagoo Been here awhile Supporter
    May 23, 2014
    277
    Las Cruces, NM
    Wouldn't it be more practical to add small drain-plugs to each cover?
  6. JimVonBaden
    JimVonBaden "Cool" Aid!
    Feb 11, 2005
    101,516
    Alexandria, VA
    Hi,
    There is nowhere near 1/5 liter inside the valve covers. If you really want to minimize the oil left in the covers, a few tablespoons in each, tip the bike for 20 seconds to each side about the amount your sidestand leans.
    As for removing the stick coils:
  7. Beecher Snipes
    Beecher Snipes Fool
    Sep 2, 2002
    880
    Mount Vernon, WA
    You can take a piece of aluminum and cut a tapered notch to slip into the coil grouves. I make these. And there are other good ones on the market cheap.
  8. JetSpeed
    JetSpeed Naviator
    Nov 28, 2007
    7,653
    Coronado, CA - KNZY
    Speaking about just the wethead, I can say with certainty that I get at least 5-6oz of additional oil out of the engine when I tilt the bike from side to side after I have left it drain while sitting vertical on the side-stand, I'm not saying that the extra oil is all coming from the valve covers, it is likely trapped in a myriad of nooks and crannies within the mill.
    #8
  9. marchyman
    marchyman barely informed Supporter
    Jun 30, 2005
    20,835
    SF Bay Area
    There is more oil in wethead valve covers than there was in hexheads. I didn't measure the amount. It's a little more than you see in the catch pan in this picture.
    #9
  10. atwoodtja
    atwoodtja Been here awhile
    Jun 6, 2004
    929
    New England, US
    If you have a ram ball clamp, you can use it to pull the coil. Easy peasy.
    Sent from my nokia 1020.
    #10
    Pch123 likes this.
  11. GrouchyGeezer
    GrouchyGeezer idjit galoot, still
    Dec 10, 2012
    7,974
    S.E. Michigan
    Ooooh, nice one!
    #11
  12. def
    def Ginger th wonder dog
    Feb 28, 2004
    14,308
    The woods and mountains of Alabama
    If you are concerned about oil left behind in your engine at an oil change, let's think about it for a moment;
    There is old oil left in the main bearings, rod journals, oil pump, oil galleries, on engine surfaces inside the engine and elsewhere.
    Lets say, this old oil amounts to 6 ounces. You remove the old filter and discard it along with the old oil left in the filter.
    Now, you come along and add 1 gallon (128 fluid ounces) of new oil to the engine after installing a new oil filter.
    What percent of the new oil is old oil? Do the math.
    If you are still overwhelmed with concern about the residual old oil left behind contaminating the new oil, I would put your psychiatrist's phone number on speed dial or move on to something important.
    #12
    Pch123 likes this.
  13. def
    Feb 28, 2004
    14,308
    Oh yes, I forgot, (thanks for the reminder Vegas) what oil do you use? What does the old oil smell like?
    Probably most important, what oil filter will you use?
    #13
  14. Cogswell
    Jan 3, 2005
    13,187
    Well that's one solution. :1drink
    He could also just disassemble the entire engine and wipe all the dirty oil off each part. Then reassemble and install fresh oil, problem solved !
    :freaky
    Mike
    #14
  15. GrouchyGeezer
    Dec 10, 2012
    7,974
    S.E. Michigan
    #15
  16. slowinfastout
    slowinfastout Halfway to nowhere in particular
    Jan 10, 2007
    2,473
    Fairfax Station VA
    truth
    #16
  17. PeterX
    PeterX Been here awhile
    Mar 26, 2005
    284
    Philadelphia/San Francisco Bay area bi-coastal
    "...I do not believe that getting those last drops of oil that reside in the valve covers is all that important.....to most people.
    To me it's crucial, there is a lot more oil in there on the new GSW then you would think, at least 6oz..." JetSpeed
    When I checked valve clearances i measured the oil that came out - a lot more than on my oil heads - it came to about six ounces (from both sides).
    #17
  18. JimVonBaden
    Feb 11, 2005
    101,516
    Alexandria, VA
    That I can believe. I am just referring to popping the valve covers with a motor full of oil.
    #18
  19. def
    Feb 28, 2004
    14,308
    Or, fill the engine with flushing oil, run the engine, drain the flushing oil and fill with fresh engine oil....then call the psychiatrist.
    #19
  20. def
    Feb 28, 2004
    14,308
    Those of us who use synthetic oil no longer need to taste the used oil. However, I believe there are still some who just can't break the habit and still sip from time to time.
    #20
