Hi all, This post just to tell you that i've just released a free app on Google PlayStore called ECU Sensors. This app is totally free and allow you to monitorin real time the values of each sensor on your LC4 or LC8 (only the tuneecu compatible models). You can also activate a log function wich record each value in a text file. In order to use it, you need to buy an OBDII Bluetooth dongle and plug it on the diag connector of the bike. You can find the app at the following adress : https://play.google.com/store/apps/d...m.ktmbtsensors Even KTM has tested it and found it very cool, hope you'll enjoy it Unityraptor from the french forum ktmmania.net
I've listed your app in the tuneecu thread in OC. I think it's a nice complimentary tool. I look forward to use it once I get the dongle. thanks again
Here is the one I've been eying, might just have to get it now http://www.ebay.com/itm/380669921609?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
You need an elm327 based OBDII dongle (95% of the Bluetooth dongle market) v1.4b minimum (most of thoses dongles are v1.5 now which is good)
I have only seen a single ktm 990 adventure in the past few months. Maybe we'll cross path. I often go to Paris coming from Lognes/Foret de Ferriere.
I own a 690 SM (custom color mate black). you're right we mayl cross path as i sometimes take the A4 to go to paris
A Friend tried it on his 690 - but he said the app doesn't read error codes nor can it reset error codes. I haven't checked so I can't tell if it's hidden in some menus or not. now that would be useful!!
