tuning up and servicing my R100RS
Discussion in 'Old's Cool' started by smashomatic, Jun 5, 2011.
  1. smashomatic
    smashomatic Been here awhile
    Jul 8, 2006
    107
    Youngstown, Ohio
    So having owned my 1977 R100RS for a while now I figure its time to maintain it. I'm planning on changing all the oils, the oil filter, the fuel lines, the spark plugs, the plug wires, the clutch cable, tires and tubes. I'm also going to adjust the valves.
    I don't have any manuals so I need some help with what types and the amounts of oils. I know the motor takes 3 quarts of 20/50 and the tranny takes 800cc of GL5 80W90. I'm going to use semi synthetic motor oil and was wondering if I could use synthetic or semi synthetic oil in the tranny. What type of oil does the rear drive take and how much of it? Can I use synthetic or semi synthetic in it?
    I ordered a tube of Honda moly 60 to lube the splines when I have the wheels off. The bike has Avon Roadrunner AM20 and AM21 on it now, but the sidewall on the front is starting to crack. I am going to try a set of Bridgestone Battlax in sizes 100/90/19 and 110/90/18.
    The bike is dual plugged with Denso W20EXR-U plugs, I googled them and came up with a bunch of pages in foreign languages. Are they a common plug? I always used NGK in all of my jap bikes. Do airheads like them at all? Where is the best place to get premade plug wires? Once I figure out what my coils are should I swap them out?
    Anything else I'm not doing that I should be? The forks and brakes feel fine so I don't want to mess with them yet. A carb and petcock rebuild is planned for this winter.
  2. Tripletreat
    Tripletreat Long timer
    Dec 20, 2008
    1,310
    Boise, Idaho
    Geez, don't you think that the ol' girl deserves someone working on her that at least owns a service manual? Mistakes can be expensive. :huh
  3. Caddy82rats
    Caddy82rats Long timer
    Mar 8, 2007
    1,365
    South France
    there is many online manuals
    download one of them ?
  4. boxerboy81
    boxerboy81 Stay Horizontal
    Jul 22, 2009
    4,824
    Melbourne, Oz
    Factory, complemented by Haynes or Clymer. All three is best. None are perfect.
    Read up on the oil filter. Google $2000 o-ring. That's a must.
  5. Jasper ST4
    Jasper ST4 Guest
    You've had the bike for a while and haven't done any basic maintenance?
  6. jtwind
    jtwind Wisconsin Airhead
    Nov 19, 2004
    3,501
    Madison WI
    In short you do need to get yourself a manual or two. You really can't own and maintain a bike with 2nd hand info off the web. The basic riders manual has most of the info you are asking for. I think you can still buy them new from Motobins if not others. There are online manuals you can find. Search this site and forum of info on oils and tires so you don't start another one of THOSE threads. Do yourself a favor and do alittle homework so you have a good lay of the land before you dig into the bike or the Q and A.
  7. DoktorT
    DoktorT BigBrowedNeandereer
    Apr 8, 2009
    1,147
    Chewelah, WA
    http://bmwmotorcycletech.info/techindex.htm
    That is SnoBums site. All info you need to know is in there if you will take the time to find it. With the factory manual and his depth of coverage you cannot claim ingnorance about anything, including the errors to be found in the FACTORY Manual. Haynes is a very good backup manual. It repeats the factory errors. The rate of errors in the Clymer will guarantee heartbreak for the Saturday mechanic. They repeat the factory errors and add a bunch of their own for good measure. Use that money for something else.
    Not a lot of errors in the Factory Manual, just a few, but some are critical, like the head bolt torque. TOO MUCH and will start pulling studs after 3 or 5 applications, pulling the threads a little bit each time. See SnoBum for the good data.
    I just shake my head and cringe every time I see the BMW dealer selling those Clymers. I am sure it guarantees some nice big receipts for both the parts and service dept.
  8. smashomatic
    Jul 8, 2006
    107
    Youngstown, Ohio
    I looked and only found parts fiche online. Does anyone have a link to an online manual? I will be ordering a manual when I place my order for the filter kit. (Why are all of my local dealers closed on my only day off?) I did search the site for oil and tire info but was unable to find any rear drive oil info. That's why I asked. Reading the tire threads helped me decide on the BT45 tire. I joined the ABC a few weeks back and I am waiting on my membership info. The Airhead who hosted the local tech day this year is willing to look over my shoulder to make sure I don't screw up that much.
    #8
  9. smashomatic
    Jul 8, 2006
    107
    Youngstown, Ohio
    I got lucky and bought a bike off someone who completely serviced it before he sold it.
    #9
  10. Boxer Metal
    Boxer Metal Mad Scientist
    Nov 3, 2003
    3,611
    Chico, California
    Buy a manual. They're cheap and it's good bed side reading.
    #10
  11. supershaft
    supershaft because I can
    Sep 9, 2010
    9,116
    San Francisco Bay area
    What about all the mistakes in Snowbum's sight?
    #11
  12. Caddy82rats
    Mar 8, 2007
    1,365
    South France
  13. Caddy82rats
    Mar 8, 2007
    1,365
    South France
    Yes, it's cheaper to buy it than to print it, I think. And It's easier to read, and you doesn't put any grease on your computer key board !!!
    #13
  14. DoktorT
    Apr 8, 2009
    1,147
    Chewelah, WA
    #14
  15. DoktorT
    Apr 8, 2009
    1,147
    Chewelah, WA
    Name ONE.
    #15
  16. DoktorT
    Apr 8, 2009
    1,147
    Chewelah, WA
    You don't know if it was done right unless you verify. If you assume it was all correct, best of luck to you. If he did do a good and proper job, you have lots of time to learn what you need to know when it is time for the next maintenance inspection.
    #16
  17. supershaft
    Sep 9, 2010
    9,116
    ONE? :rofl
    I name them as they are brought up. Otherwise you could make a career out of it.
    #17
  18. Jasper ST4
    Jasper ST4 Guest
    +100
    #18
  19. jtwind
    Nov 19, 2004
    3,501
    Madison WI
    My experience with snobums site has been very good. I've yet to find a mistake, not that that means much. But frankly I haven't had anyone else point one out either. That's saying alittle more. I've met and talked to the bum more than once and my money is on the guy. He's the sort of person who isn't going to tell others how things are done unless he is sure that's the way it is. He's basically a scientist and goes about learning about airheads the same way. You couldn't find a more honest, helpful fellow. He's never negative or condescending just trys to relate what he's discovered. Good guy and a good site.
    #19
  20. jwegman
    jwegman Been here awhile
    Jul 21, 2009
    254
    Rochester, MN
    I hope that one of these days snowbum will allow someone with appropriate skills to organize/redesign his site.
    Currently, my will to live decreases each time I navigate it.
    #20
