Kouba links on a KTM 625 SXC - how to file swing arm or spring for clearance?
Discussion in 'Thumpers' started by Mayhem_Unlimited, Sep 11, 2012.
  1. Mayhem_Unlimited
    Mayhem_Unlimited Adventurer
    Apr 13, 2012
    52
    Rosamond, CA (formerly Sleazattle, WA)
    Last night, I installed the Kouba lowering links on my 2004 KTM 625 SXC. It was pretty straightforward. I'm now at the point where I need to either file down the rear spring or file down (about .040") the swing arm to gain clearance between the swingarm and spring. I have a few questions:
    1. Should I file down the spring or the swing arm?
    2. How do you guys get in there with everything assembled? Or does this require disassembling a portion of the rear suspension?
    3. What's the preferred tool for the job? Is a metal file sufficient?
    Thanks for any help. I'm such a n00b. :(
  2. Mayhem_Unlimited
    Apr 13, 2012
    52
    Anyone? :muutt
  3. timg
    timg Adventurer Supporter
    Feb 17, 2007
    76
    Rolleston New Zealand
    Hi, been there, done that. Take it off the swing arm - it's soft aluminium. Use a file. Doesn't need much. Chalk the area and file until the chalk doesn't get worn of. Cheers
  4. Mayhem_Unlimited
    Apr 13, 2012
    52
    Thanks, Timg.
