*** Admin Note: Welcome to the massive thread of "Yamaha Forks on a BMW F650gs Dakar"! *** If you are here you likely have a lot of questions that have been answered several times in the thousands of posts found in this thread. To try and consolidate some of the FAQs a summary post has been added here. It should have the answer to almost every question you might have about this conversion. PLEASE READ IT FIRST AT LEAST ONCE to see if your questions have already been answered. If after reading the summary post you still have questions, feel free to ask! CageFreeBMW will do his best to update the summary post as needed to help other inmates in the future. Summary Link: https://advrider.com/f/threads/yamaha-forks-on-a-bmw-f650gs-dakar.399113/page-355#post-41248009 *** Got alot of interest on this so ill try and post what i can remember about doing the upgrade. For starters heres a pick. The forks i used were off of a YZ426f, came with triple clamps, brake caliper and then picked up an excel wheel all for 250 bucks! Put in a heavier weight oil and then the heaviest springs i could find for the forks, new seals of course. The main two issues i remember having(did this last winter) were i had to machine the stock yamaha steering stem down about .010" for one of the bmw steering bearings, the other one fit like a glove! Also i had to trim the inside of the fairing so i could swing the forks without rubbing anything on the inside, and i also think i had to do somethin for the fork stops to work also. But let me know if you have any more questions and ill try and get some better picks once i wash my bike, its covered in a pile of mud right now! But i measured the weight difference of the two it was about 15lbs savings, the new ones were a bit longer then that dakar forks, but handles like a new bike now, and the front end feels so light and no more bottoming out!
Skibum, if you use the Yamaha bearing kit, you dont have to machine the shaft. The BMW, and Yammy have the same size outer cup diam. I used the Yam bearings on my GSPD conversion, and the GSPD has the same bearings as the 650GS/Dakar.
Interested in the actual difference in length and also the size of the disc rotor. You have not mentioned the upper fork yoke & whether it is the Yamaha one. How do you find the braking performance compared to the BMW disc & rotor
You use the upper and lower Yamaha yokes. Not sure on the 650, but I use the BMW wheel and brake on my GSPD.
Now this might warrant me to keep the Dakar. Tell me more about the way it performs, does it not make the front end to light? The KTM640 is very twitchy over rocky terrain, where the Dakar normally just plough through, yes, I know it's fronts are rubbish, but it does work there for some reason. The only problem would be to mod the ABS ring and sensor on the ABS bikes. Did you also fit different handlebars and did you had to do other mods to the switches and throttle?
Hi, what I would like to know if you tried using BMW wheel set, and if it would fit, and why you went with the yammi wheel set?
The conversion certainly looks the business. If it were me I'd consider an oversized rotor and supermoto caliper for better braking. The brakes are suitable for a 240lbs bike off road, but for me they would be insufficent for road use on such a heavy bike. Were you able to buy sufficiently stiff fork springs? The GS has got to weigh about 200lbs more than the YZF.
Breaking has not been an issue with the stock setup, lots of offroad and onroad miles ive never needed any more stopping power, that was one thing i was concerned with but it hasnt been an issue at all, and the springs yeah i seem to have them pretty close, dont feel to stiff and havent gotten it to bottom out once yet even after some descent jumps, you may have trouble if your a heavier rider but im only 175 so the heaviest ones i got worked well for me.
no idea if they would fit im sure you could but yamaha wheels are cheap especially excel wheels versus the cost of an excel for the 650 front end.
I commented on this conversion in another thread, and I'm glad to see a new one dedicated to the issue. I'm really interested in pursuing this, and will be haunting eBay for the parts I need. One thing that adds just a little complication to my conversion is that my bike has ABS. At a bare minimum, I'd need to put together some kind of custom bracket for the sensor, which currently mounts right to a hole in the fork leg casting. In addition, I'll need to adapt the sensor ring to whatever wheel/brake I wind up with.... So I think I'd prefer that it remain stock if possible. Might need to talk to Woody about adapting that. From casually browsing the listings, it looks like bikes from about '98 to '03 had forks roughly similar in diameter to my stock Showas, although upside down of course. That ought to be plenty strong I reckon. It looks like larger tubes came out in '04 or so. I'm wondering a bit about clearance issues if I went for the larger, and presumably stronger legs.
Mine are off a 2003 YZ450. 46mm lowers. The bottom tripple is around 30mm wider than the standard 650 tripple, so may have clearance issues on the 650. ( mine on GSPD) The other option for the front end is Honda XR400R forks. Not sure on the size, but I know the XR250R is the same size as the BMW, so dont need to change tripples. These are cartridge forks, so are modifiable. Just another option that maybe cheaper again. Check out FAQ at www.f650.com section on fork upgrades.
Cool stuff. For the springs, check the sag. If they are too soft and you have too much sag you'll be riding in the much stiffer mid-stroke too often and more preload or stiffer springs may improve things. You should have around 80-95mm of race sag with those forks:)
The KTM is "twichy" in the rough stuff because of the geometry, rather that the forks. This is a charachterisc common to many KTM to provide nimble handling in the tight stuff. Most KTM guys run a steering damper to get the best of both worlds. I am planning a swap using 50mm WP extreme convensional (rather than inverted) forks. For my purposes the Dakar is a adventure bike that sometime goes dualsporting, rather than a dual sport that tries to go dirt biking. Conventionals seem to have better fork seal life, and the WP's are fully adjustable. I will use the stock BMW wheel and brake, I feel the dirt bike brakes with their thin thin rotors just won't handle 800+ lbs (trip loaded with me) just aren't going to last.
Very interested in replacing my wrecked 07 front end this way. However could use some advice on what to do with the abs.:jose
I dont believe the ABS is all that big a problem. I think it wouldnt be all that hard to make a bracket to hold the sensor. Use the lower fork shield bolt holes to fit something.
I have a 2001 dakar with the old style forks and am very interested in doing this conversion. How did you mount the ignition to the fork? Do you only use the yz caliper with the rest of the stock break setup? Is the yz wheel as strong as the bmw? Do you have to do anything with the handlebar mounts? I am new to this and this is my first post, so hopefully these questions arent too stupid.
i actually couldnt find a good place to mount it on mine as i also put a steering stabilizer on, so i just zip tied it under my left side body protector, and yes i used a yz caliper along with wheel on mine, and i would think an excel yz wheel is alot better then a stock bmw, stock versus stock im not sure, i also addred fat bars with risers so i changed all of that to.
I am gonna go for it. I found an 03 fork on thumper talk, I am getting fork, triple clamps, and brake caliper for $250. What weight oil did you use and what springs did you use? Thanks for all the info. I will post some pics when I get going on it. Also where did you get your black storage canister? Or did you make it? Obviously I really like your bike, I had to sell my dirt bike this year and now I miss it, the dakar is not that dirt worthy so far, but yours looks the most offroad ready of any that I have seen. Maybe I won't need to get another dirt bike after all.
it was either 15 or 20 weight oil and then the springs i think were .52kg if that sounds right, if you really want i can check my reciepts and fine out, and yeah i made that storage container, i tried selling some on here a while bike but never had anyone follow through so i gave up, and yeah i take mine through anything, single track, mud, open road, etc, some jumping but need a ohlins rear for that still!
