Old 08-06-2014, 01:28 PM   #1
TDL028 OP
man of leisure
TDL028's Avatar
Oddometer: 388
Jug/cylinder markings
Howdey ADV,
just a quick question here. If my jugs are marked "B" and "10" then I would have R100 cylinders on my r80..correct?
thanks!
tom
My '84 R80 overhaul:
http://www.advrider.com/forums/showt...errerid=297067
Frame Hoops: Gasolineheaven.etsy.com
Instagram: too_many_projects
Gasoline_Heaven
TDL028 is offline   Reply With Quote
Old 08-06-2014, 01:33 PM   #2
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,809
Yep!
Rob Farmer is offline   Reply With Quote
Old 08-06-2014, 01:40 PM   #3
TDL028 OP
man of leisure
TDL028's Avatar
Oddometer: 388
sweeeet.. thanks dude!
Gasoline_Heaven
Old 08-06-2014, 03:02 PM   #4
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,813
cylinders come in three different grades, A,B and C (smallest to largest), each are matched to one of three different size pistons.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 08-06-2014, 03:26 PM   #5
drhach
gorillamanufacturing.com
drhach's Avatar
Oddometer: 2,520
So, I should see a "9" on my R90 cylinders? Are the "A,B,C" markings overbore markings or cylinders that were matched at the factory?
1976 R90/6
1972 XLCH
2010 Triumph Thunderbird SE
drhach is offline   Reply With Quote
Old 08-06-2014, 07:15 PM   #6
One Less Harley
Oddometer: 4,813
they aren't over bore numbers, but just correspond to a specific factory sizing, bores were matched to the appropriate pistons. Check your workshop manual for specific sizes. Chilton gives the specs, which I'm not going to post up here. Cylinders are marked A,B or C, pistons are just stamped with the size on top and the workshop manual assigns the A,B, C designation to the three different sizes. You will want to match cylinders to the corresponding pistons for the best piston to bore clearance. For nickasil it is .03-.04 mm NEW and a max of .08mm.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 08-06-2014, 10:31 PM   #7
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,569
It almost sounds like you've had recent experience with this.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 08-07-2014, 04:45 PM   #8
drhach
drhach's Avatar
Oddometer: 2,520
so I have a B stamped on mine and the on a pad there is a 30 with 03 under it. I assume that is an upside down 30. Does the 30 denote R90?
1976 R90/6
1972 XLCH
Old 08-07-2014, 06:20 PM   #9
Airhead Wrangler
Adios Mexico
Oddometer: 6,569
R90 just has a '9', R80 an '8', R100 a '10', etc.
Old 08-07-2014, 06:56 PM   #10
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,911
We're talking two different subjects, methinks...
The "80" "90" and "10" are cast onto the top of the jugs, visible from above when looking at the base of the jugs. I THINK, but not certain, that the early versions had a "6", "8", "9" versus later "80" etc. My 1983 R80 ST has a very clearly stamped "80".
The "a". "b". "c" are markings on the cylinder and piston itself, so that it matches as close as possible wi
th the range of bores within that engine size.
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm screwed with this post 08-07-2014 at 07:21 PM
bpeckm is offline   Reply With Quote
Old 08-07-2014, 11:51 PM   #11
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,234
Not sure it was explained clearly enough about the A,B and C. Those aren't over-bores - they're the standard bore - it's just that when the parts were machined some come out a little larger or smaller than the target size. In any manufacturing and machining process tolerances are given. Parts can be within that target size and be acceptable. Not sure what they were in this case - but let's say it was plus or minus a tenth of a millimeter. That means that there could be a difference of .2mm from the smallest to the largest.
Other manufacturers didn't necessarily pay attention to this and assembled the parts without matching for best fit. What could happen is a cylinder on the large side mated with a piston on the small side - could make for a rattly engine right off the line.
Wirespokes is online now   Reply With Quote
Times are GMT -7.   It's 09:25 PM.
