too much oil during oil change
Discussion in 'The Garage' started by SZGS, Jun 2, 2010.
  1. SZGS
    SZGS Adventurer
    Oct 19, 2009
    38
    let me begin by saying that i'm new to wrenching... just bought tools this weekend.
    probably no surprise that i accidently poured too much oil in my GS while talking to a neighbor. so i unscrewed the plug and bled some oil and then retightened it.
    and now i can't help but think the plug is going to loosen and cause a problem when I least expect it.
    so the questions are:
    do i need a re-do on my oil change?
    will the oil that doused the plug cause it to lose its grip someday soon?
    do i need a new crush washer after tightening and then loosening the one that is on there now?
    how important is a torque wrench? I didn't know the value so just did it by hand - plug and filter.
    thanks for your time.
  2. Pike Bishop
    Pike Bishop Pull Down the Ponzi.
    Nov 8, 2008
    14,627
    Your Back Yard
    I'm no mechanic, and I know zero about your particular bike, but I wouldn't worry about it too much.
    Just check the bung plug for looseness after your next couple rides, and look for any oil leaks at the plug and filter.
    I'd be more concerned about over-filling with oil, but only if it was WAAAY overfilled, in which case smoke might be one clue.
    Good luck.
  3. GreaseMonkey
    GreaseMonkey Preshrunk & Cottony
    Jun 16, 2006
    6,001
    The only county in Illinois with no train tracks
    You'll be fine, just go ride. What you can do to make yourself feel better (a good idea anyway) is after a couple of rides just put a wrench on the plug and make sure it is still snug. If it has loosened up you will notice it, and if it hasn't then you know that it is OK.
  4. fritzcoinc
    fritzcoinc Enjoying my last V8 Supporter
    Apr 30, 2008
    10,582
    Hockley, Tx
    See above
  5. Laconic
    Laconic Old Normal
    Sep 28, 2007
    30,574
    The Gaslight District
    If you are tightening a steel plug into an aluminum case, a torque wrench might be advisable.
    There is a tendency for inexperienced mechanics to overtighten things.
    In any case, you're going to want one as you start delving into other repairs, so why not go ahead and get one?
  6. eRRmmm
    eRRmmm Been here awhile
    Aug 21, 2009
    587
    antarctica
    Note that all my experience has been on Japanese bikes, mostly old dirt bikes. It's possible that a BMW has some special metal alloys that make normal mechanical skills irrelevant :wink:
  7. eRRmmm
    Aug 21, 2009
    587
    antarctica
    Geez, you have to type quick around here :D
    Good advice, just don't tighten it up while the engine is hot. You might struggle to undo it once it cools down (although you should do an oil change while the engine is hot anyway).
  8. prsdrat
    prsdrat Been here awhile
    Sep 9, 2008
    895
    San Diego, CA
    Just be careful when "retightening" a bolt in aluminum. I always loosen
    first then tighten. Had a block heater blow out on a Ford diesel 400 miles
    south in Baja. I appeared that the "mechanic", at every oil change, noticed
    a slight leak and simply gave it another snug which eventually fractured the
    interior tee.
    #8
  9. SZGS
    SZGS Adventurer
    Oct 19, 2009
    38
    thanks for all the quick responses.
    i will definitely get a torque wrench.
    was going to upload a pic of my hot neighbor but the upload failed.
    too bad, i'm sure she would love to meet you!
    #9
  10. Mista Vern
    Mista Vern Knows All - Tells Some.
    Dec 1, 2005
    25,203
    McMinnville, Oregon
    I am not sure if it would have worked with your bike, but on some engines you can get excess oil out with a turkey baster. Probably best not to put it back in the kitchen afterwards though.
    PS: Also good for filling batteries.
    #10
  11. Flashmo
    Flashmo Whatever...
    Dec 21, 2008
    2,687
    Vagabond Hippie
    It'll be fine.
    #11
  12. JDLuke
    JDLuke Ravening for delight
    May 3, 2007
    8,646
    New Jersey
    What's the best kind of oil to use in our batteries? :lol3
    #12
  13. JensEskildsen
    JensEskildsen Long timer
    Mar 24, 2009
    2,482
    Denmark
    You're fine, no worries..
    #13
  14. Flashmo
    Flashmo Whatever...
    Dec 21, 2008
    2,687
    Vagabond Hippie
    Not another oil thread....................
    #14
  15. FatChance
    FatChance Road Captain
    Jun 12, 2003
    14,508
    Oak Creek, AZ
    I would never use synthetic oil in my Westco battery... :deal
    #15
