Old 06-30-2014, 08:49 AM   #526
Sporting Wood OP
I <3 Energizer Bunny
Sporting Wood's Avatar
Oddometer: 855
Originally Posted by Chuckracer View Post
Chris, I have 1ea: 160, 165, 175, 178, 180, 182 if there's anything there you need...
Lots of 168's 170's 175's 178's etc... Only one 172. Tells ya something, eh?
I've got an order with FP. Can add on some 172's for you.
Sporting Wood is offline   Reply With Quote
Old 06-30-2014, 09:41 AM   #527
mousitsas
mousitsas's Avatar
Oddometer: 2,580
I must have the only 950 in the known universe which needs larger than 182 mains
Old 06-30-2014, 09:47 AM   #528
Sporting Wood OP
Oddometer: 855
Curious, what kind of afr are you pulling at near redline?
Old 06-30-2014, 09:50 PM   #529
mousitsas
mousitsas's Avatar
Oddometer: 2,580
With 180/182 mains and stock needles at 3rd, a perfect 12.8 to 13.2 depending on temperature. Roll-on when on the mains is tremendous with these settings and top speed is well above 200km/hr.
With FP needles on 4th at some point it stops accelerating at around 180km/hr where I see AFR above 14 and if I open the throttle further, afr shoots to the sky.
All acceleration tests are done sitting at 150km/hr and slowly opening to WOT, on 6th gear, close to sea level.
It makes no difference on WOT afr between 42 and 45 pilots, floats are set at 3mm and exhausts are open akras.
mousitsas screwed with this post 06-30-2014 at 10:30 PM
Old 07-01-2014, 08:10 PM   #530
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 7,082
I'll buy those! I could use a 175 and a 178 if it's possible?
2005.5 KTM 950 Adventure
2001 Scorpa SY250
Chuckracer is offline   Reply With Quote
Times are GMT -7.   It's 02:58 AM.
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
