sources for 175/55/17 tires in US
Discussion in 'Hacks' started by transalpian, Aug 6, 2012.
  1. transalpian
    transalpian Over, Across, and Through
    Feb 28, 2005
    404
    Oak Ridge, TN
    I'm looking for a 175/55/17 tire to put on the front end of my Rocket 3 rig. Does anybody know of a US source for this (or a similar size) tire?
    FYI, the Rocket has a 17" x 3.5" wide front rim.
  2. DRONE
    DRONE Dog Chauffeur
    Oct 1, 2007
    11,127
    Tacoma, WA
    Hack Vendor thread here
  3. transalpian
    Feb 28, 2005
    404
    Oak Ridge, TN
    Tried that with a pm and email. No response yet so I'm checking around.
  4. DRONE
    DRONE Dog Chauffeur
    Oct 1, 2007
    11,127
    Tacoma, WA
    Just to be sure we're on the same page, yer talkin about a car tire for your new rig, right? Not a moto tire.
    Did you ping the previous owner to see if he had a source?
  5. kailuasurfer
    kailuasurfer Dreamer
    Jun 8, 2009
    563
    PNW
  6. kailuasurfer
    Jun 8, 2009
    563
    PNW
  7. Bobmws
    Bobmws Curmudgeon At Large
    Jun 6, 2005
    5,920
    Same trailer, different park, FL
    I couldn't find anything smaller than 195/45/17 when I was looking for a pusher tire.
    FWIW, I've been extremely pleased with a ME880 bias ply on the front of my K-bike rig. Around 4k miles and it's only worn 1.5/32ths. About 1000 of those miles were in the Arkansas twisties.
  8. Brendan J
    Brendan J Pfft
    Feb 2, 2008
    1,896
    Planet Earth
    I would be concerned about fitting a 175/55-17 on a 3.5" width rim. A tyre of that size and aspect ratio would be more at home on at least a 4.5-5.5" width rim if not even a bit wider. I've seen guys fit 195-205 width tyres on standard V-strom rims which are only marginly wider and it doesn't look like it's doing the tyres sidewall much good.
    I'd be inclined to find something narrower with a higher aspect ratio to fit the rim better.
    #8
  9. transalpian
    Feb 28, 2005
    404
    Oak Ridge, TN
    Yes, a car tire for the front of my new rig. :D The bike is coming with a well worn moto tire on the front, I'm preparing to replace it.
    I've seen a lot of those price range options too. I was hoping for something closer -or- to arrange a group buy to reduce the per-tire shipping cost.
    Here's what that tire looks like on kailuasurfer's Rocket rig with stock front rim:
    Seems to fit well and has been a great tire, according to kailuasurfer. Now to be fair, Claude did warn of difficulty sourcing a replacement...
    #9
  10. transalpian
    Feb 28, 2005
    404
    Oak Ridge, TN
    I was also looking at a Yokohama S-Drive in 195/45/17. It looks to be about 1" wider than the 175/55/17 on kailuasurfer's bike above. I'll need to measure closely, but it looks like it might fit and is super easy to find here in the US. Here is that tire on a FJR1300 stock rear rim:
    This rim is 5.5" wide (+2" than mine), but it looks like it might work? More to come....
    #10
  11. transalpian
    Feb 28, 2005
    404
    Oak Ridge, TN
    And here is my rig:
    #11
  12. AviatorTroy
    AviatorTroy Following my front fender
    Oct 15, 2007
    2,988
    Castle Rock, CO
    Not that I know anything about hacks, but, did you look on Tirerack.com? I think they have just about anything.
    #12
  13. transalpian
    Feb 28, 2005
    404
    Oak Ridge, TN
    I've looked at all the major (and minor) tire suppliers. It seems this tire is not used on any US-spec cars so it's very hard to obtain here.
    It is used on a Euro Spec Lotus Elise so my next idea is to call a Lotus dealer and see if (and for how much) they can find the tire.
    #13
  14. kailuasurfer
    Jun 8, 2009
    563
    PNW
    I understand that the U.S. spec Lotus Elise uses 16 inch front wheels.
    #14
  15. transalpian
    Feb 28, 2005
    404
    Oak Ridge, TN
    Yep. The Euro-specs get the 17's, we get 16's. I'm hoping (probably falsely) that my local Lotus dealer can get parts for both?
    Have you talked to Claude about suitable replacements?
    #15
  16. kailuasurfer
    Jun 8, 2009
    563
    PNW
    Looks great! Is it a 2005?
    #16
  17. transalpian
    Feb 28, 2005
    404
    Oak Ridge, TN
    Yes, its a 2005 with a Champion Escort car. Hydraulic Brembo on the car wheel with Jay's TILT mechanism between the car and bike. I'm thinking its an upgrade from my old GL1000/Velorex 562.
    Nowhere near as nice as your rig though! I'd love to know what your conversion cost....
    #17
  18. kailuasurfer
    Jun 8, 2009
    563
    PNW
    That will be an excuse for us to get together :1drink. Rocket III is an amazing sidecar pusher but I see very few Rocket rigs around. Did you make any steering modifications?
    #18
  19. transalpian
    Feb 28, 2005
    404
    Oak Ridge, TN
    Not yet. I talked to Brock at Steerite and will likely go that route this winter.
    I had Unit leading links on my wing, but never really got it to where I wanted it to be. Have you seen any hub-steering setups for these? I was seriously Jonesing for a BMW GT1300 rig with a Hannigan HPS car, but at $19k I couldn't justify it yet.
    #19
  20. Bobmws
    Jun 6, 2005
    5,920
    Here is the Yoko on my BMW 5.5" rim. It was a real bitch to mount, I think a 2" narrower rim will distort the tread alot, the side walls are short and stiff. Even wit 6mm additional spacers the tire grew with road heat and rubbed the corner of the BMW swingarm, had to sand some rubber from the inside edge of the tread. I will probably go with the adapter from Claude and 15" wheel in the future.
    Want to buy a slightly used (4000 miles) tire?
    #20
