Rox Risers on 05 gs1200 and cable issues
Discussion in 'GS Boxers' started by jdbski, Feb 20, 2013.
  1. jdbski
    jdbski old but getting younger
    Aug 3, 2004
    597
    Santa Monica, CA
    I want to rotate my front brake line more in parallel with my handbars so it doesn't bind when i turn the handlebars with my rox risers installed. What i wanted to know is it possible to loosen the banjo bolt at the bottom of the brake line as it exits the reservoir without having to bleed the brake line? I was hoping you could crack open the nut just enough to rotate the line and then tighten it back up without introducing air into the line. Might spill a little brake fluid but thats no big deal.
    Any thoughts?
    jb
  2. JimVonBaden
    JimVonBaden "Cool" Aid!
    Feb 11, 2005
    101,516
    Alexandria, VA
    Drop the fork tube and move the line behind the fork tube. No need to loosen the brake line.
    Jim :brow
  3. trc.rhubarb
    trc.rhubarb ZoomSplat!
    Nov 15, 2011
    8,679
    Concord, CA
    Oya, and let me say that it sounds like a big deal but it's so simple, I can't believe I even worried about it.
    It's not a shock, just a sliding tube that you can slide with your hand.
  4. jdbski
    Aug 3, 2004
    597
    Santa Monica, CA
    will do jim, what about the cable kinking behind the fork tube? and do you know the torque setting for the tube bolt or nut?
    thanks,
    jb
  5. Britome
    Britome Get Free
    Nov 7, 2009
    2,306
    Cincinnati, OH
    Agree. Done this twice. The torque is until it is tight without stripping... I know I'm about to get skewered for that comment but it is what I have done.
  6. Boondox
    Boondox Travels With Barley
    Aug 4, 2007
    4,710
    Vermont
    Torque it to one grunt
  7. JimVonBaden
    Feb 11, 2005
    101,516
    Alexandria, VA
    It really will not kink, a non-issue.
    Torque is 40NM according to ReProm.
    Jim :brow
  8. jdbski
    Aug 3, 2004
    597
    Santa Monica, CA
    what about the kink issue?
    come on folks i know somebody has an opinion on this!
    thanks,
    jb
    #8
  9. jdbski
    Aug 3, 2004
    597
    Santa Monica, CA
    ok i moved the line behind the fork tube (super easy i might add) but now it seems as though it has even more pressure on the line as opposed to when the bars are in the straight ahead position. remember folks that its a 05 and i think its very different than later year bikes and possibly adv versions as well. I would post a picture but i dont yet know how.
    Thanks,
    jb
    #9
  10. JimVonBaden
    Feb 11, 2005
    101,516
    Alexandria, VA
    My first bike, and I was the first to use ROX Risers, was an 05. I have installed them on at least a dozen bikes since, no issues. Don't sweat it.
    By the way, I have risers now that are even more extreme on my new to me 05GS.
    Jim :brow
    #10
  11. jdbski
    Aug 3, 2004
    597
    Santa Monica, CA
    You weren't kidding, those are some badass risers. Ok I will ride it like I stole it and see what happens I guess it should be fine. If not I will fix it when it breaks. Sh$t happens right?
    Thanks again,
    Jb
    #11
  12. Monsignore
    Monsignore Plunger Boy Supporter
    Nov 26, 2007
    1,733
    Astoria, Queens
    Well, this is the internet. I'm sure there's a porn site somewhere with brake lines and fork tubes.
    Wait, that's not the kink you were referring to.....
    Also, I have Rox Risers on my '05 and did the fork drop. No tribble at all. Although it did freak me out at first cuz I wasn't holding the tube when I loosened the nut. That initial drop had my gut jumping into my throat when the whole bike shifted. :yikes
    #12
