KLR650 Only Thread......
Discussion in 'Thumpers' started by willys, Nov 19, 2011.
  1. misterjack
    misterjack Universal
    Jan 18, 2013
    77
    Cincinnati, Ohio
    looking for a new pair of tires that will accommodate about 40% on road and about 60% off roads. currently riding an 89
  2. misterjack
    Jan 18, 2013
    77
    Cincinnati, Ohio
    sick paint job my man. I might have to consider doing this myself!
  3. Aprilia
    Aprilia Long timer
    Sep 15, 2008
    1,799
    Phoenix, AZ
    Mostly maintenance related but the pre 96 engines you want to keep an eye on the stock Doo (I'd just upgrade and be done) and by 20K miles I'd upgrade the balancer sprockets to post 96 design. The earlier versions were multipiece designs that are/were well known to come apart with higher mileage. If you ride in colder weather and/or for short distances a Thermobob is a good upgrade.
  4. MacNoob
    MacNoob piney fresh
    Jun 2, 2010
    3,092
    The mosquito-y Center of Canada
    Better seat
    Better windshield
    Throttle lock
    Good tires
    Check/adjust steering head bearings
    Good oil and a few pounds of air in the forks
    That's on top of all the 'usual' KLR stuff.
    hmmmm.... not much really.
  5. Jon B.
    Jon B. Been here awhile
    Apr 9, 2010
    631
    Rice County, Minnesota
    And a 16-tooth counter-sprocket, maybe.
    Jon
  6. DesertDuster
    DesertDuster Old Pueblo Rider
    Apr 17, 2009
    205
    Amarillo, TX
    All good tip and thanks.
    I guess as long as the spokes are still tight and the wobble is not too bad then I continue riding it in the short run?
    Ron
  7. DesertDuster
    Apr 17, 2009
    205
    Amarillo, TX
    I agree with the others. I have 20K on my 09 and would buy another with 20K on it. The chain may need replacing by that mileage.
  8. phideaux
    phideaux Long timer Super Supporter
    Feb 4, 2008
    4,326
    NW Georgia
    What air filter set up are you guys using? I'm using K&N and I'm not too happy with it. Pulled the carb today and was kinda surprised at how nasty it was inside. :ear
    Fido:norton
  9. Gonzoso
    Gonzoso Been here awhile
    Sep 2, 2012
    205
    Pocono Mt.s PA
    Tore my bike down because it's 19 degrees outside right now. 22 cent mod, oxford grips, measured and adjusted valves, replaced choke plunger plastic piece I broke, drilled air box and threw in some 1" uni filters in place of the L mod. The latter mostly because I'm bored and itching to ride.
  10. nvklr
    nvklr Long timer
    Jul 11, 2008
    1,034
    Carson City
    Stock flows better than k&n on this filter, and Uni flows better than stock. Both do a good job at cleaning the air. You will need to source a stock filter cage and wing nut to go with it.
  11. OKlr
    OKlr 25mph gate inpector
    Sep 23, 2009
    853
    Ponca City Oklahoma
    picking a good air filter is not all about airflow with motorcycles. its about how well the filter seals and filters air. Personaly i like the no toil and uni filters. Either one you run it needs to be oiled well and use a filter seal grease between the filter and the airbox.
  12. CA Stu
    CA Stu Peace and Love
    Aug 27, 2004
    65,523
    Riverside CA
    Uni filter with a PC Racing Filterskins pre-filter
  13. stuser
    stuser Putt putt putt
    Sep 19, 2012
    409
    Canberra, Australia
    Gee. You USAmericans have it good. $3250!!! At todays exchange rates that's about $AU3080....
    Down here in Aus I bought an 08 KLR for $AU5300 (ie about $US5600 )a couple of months ago, and that is NORMAL, if not slightly better than normal....
    it had just over 10,000 miles on it and no oil in the engine, but it does run well and it has some good basic farkles....
    so no complaints about your price :D
    oh yeah and we in australia don't have easy access to eagle mikes or 685 or 705s so in the US the KLR is an even better deal again!!!
  14. DesertDuster
    Apr 17, 2009
    205
    Amarillo, TX
    Most people on the forum seem to like the UNI filter. I am using the UNI filter also and give it a my recommendation but I think the stock filter has performed well. If I was given a choice between the UNI and stock, I would go with the UNI.
  15. stuser
    Sep 19, 2012
    409
    Canberra, Australia
    what's wrong with the K&N air filter on the KLR????
  16. WARRIORPRINCEJJ
    WARRIORPRINCEJJ Forsaken
    Jun 29, 2009
    29,627
    A lotta' the "performance" filters (not just K&N) are pretty notorious for not "filtering" a helluva' lot.
    Probably not the best choice for a dualsport...
  17. stuser
    Sep 19, 2012
    409
    Canberra, Australia
    Hmmm, interesting. Any actual comparisons across filters?
    I just googled UNI filter and see that they look entirely different from the K&N that is currently on my bike, more a sponge than the cage type.
  18. WARRIORPRINCEJJ
    Jun 29, 2009
    29,627
    I have no data. My comment was strictly based on personal experience (mine...and my buddies', that I have been witness to).
    YMMV...
  19. stuser
    Sep 19, 2012
    409
    Canberra, Australia
    so... more dirt getting past the filter then?
    So you are of the opinion that the UNI brand are better?
  20. WARRIORPRINCEJJ
    Jun 29, 2009
    29,627
    Me? I like the OEM filter.
    However, as DD posted, there seems to be a lotta' folks who favor the UNI.
    Six in one...
