Diesel fuel in r1200gs tank
Discussion in 'GS Boxers' started by Dan Cãta, Jul 22, 2014.
  1. Dan Cãta
    Dan Cãta Long timer Supporter
    Jun 5, 2008
    2,569
    Cluj-Napoca, Romania
    Hi all,
    A friend of mine put, accidentally, diesel fuel in the tank of his 1200gs, 2004.
    He started the bike and it quit after ~ a few seconds, normally. Then he drained the tank and put normal gas. The bike started and was ride-able.
    The next day, it started to run bad. If you twist the throttle, it would sputter, as if the red line rev limiter was at 2500 rpm.
    The first thing to do was clean the tank on the inside and replace the fuel pump. I also cleaned the injectors in a ultrasonic cleaning shop. Lucky him, I had a R1150 R Rockster pump around and it is a direct swap. I put in fresh fuel and started it. Nothing changed, the bike runs the same.
    So I am thinking it is the fuel pressure regulator fault. I ordered one and am now waiting for it to arrive. I am asking myself if it is worth the trouble to fit a 3 bar FPR instead of the usual 3.5 bar FPR that the 1200 comes fitted with. Replacing it is a PITA!
    Also, do any of you think I should be replacing anything else? IMHO, the bike now acts like it is the FPR's fault. I never opened one, but I guess it has a seal and a spring inside and the seal went bad as it is not designed for diesel, but for gas.
    Dan.
  2. Aco201
    Aco201 Adventurer
    Jan 16, 2014
    51
    I would guess to clean out the fuel tank. fuel filter, fuel lines and fuel pump would be enough.
    Have you tried to connect a fuel line from a separate fuel tank directly to the fuel pump?
  3. Dan Cãta
    Jun 5, 2008
    2,569
    My answers inline.
    Dan.
  4. PeterW
    PeterW Long timer
    Nov 11, 2005
    7,302
    Gold Coast
    That's usually 'mostly harmless', it's petrol in a diesel engine that gets expensive.
    I'd guess plugs are fouled and everything is a bit carboned up. Pull one of the plugs to check and replace or clean them if they are fouled and try again.
    Pete
  5. CheckerdD
    CheckerdD Long timer
    Apr 30, 2005
    1,496
    Dave Rankine, Reno NV
    A friend of mine accidentally put a couple of gallons of diesel in his K75. After he realized what happened he stopped at every gas station along I-5 and topped op with real gas which diluted the diesel. After the bike ran normally he did not do a damn thing. He still has the bike a couple of years later. Ever heard the expression "if it ain't broke don't fix it." Dave
  6. Dan Cãta
    Jun 5, 2008
    2,569
    Forgot to mention, the owner also changed all 4 spark plugs back then.
    Dan.
  7. Marki_GSA
    Marki_GSA Long timer
    Sep 6, 2011
    2,271
    Scotland
    Yep the plugs are probably oiled so I would clean or replace them.
  8. Dan Cãta
    Jun 5, 2008
    2,569
    But the bike is not rideable right now. You cannot overtake even at low speeds. When it needs more fuel - higher rpms, the engine does not work right.
    #8
  9. hammick
    hammick Long timer
    Dec 2, 2007
    4,787
    Kansas City, Missouri
    Mix some Seafoam and Heat in with the gas and rev the throttle for five or ten minutes. I had a full tank of bad gas in my RT this Spring and it would not even start until I put in the Safoam and Heat and sprayed ether in the intake. Once started it coughed and stuttered for about five minutes and then ran fine
    #9
  10. eric2
    eric2 ®egister this:
    Aug 13, 2003
    3,866
    Austin
    I suspect one of the primary coils has picked this occasion to fail, it's old enough for it to happen. Did the bike get wet or was it washed around the time diesel was introduced? I think my first coil went out on my 05 r12gs around 100k, and it died right after a rare pressure wash.
    #10
  11. mefly2
    mefly2 Long timer
    Jun 28, 2010
    1,241
    Big Sky Country
    If diluted ...it sounds like a situation similar to adding snake oil (Marvel Mystery) to gas for upper cyl lubrication ...
    #11
  12. Thuben
    Thuben n00b
    Dec 13, 2009
    9
    Stockholm, Sweden
    Could it be that the O2 (lambda) sensor stopped working after having been drenched in diesel and then, after being started on gasoline, having that same diesel burnt in?
    I believe Roger 04 RT, had a post on how to check the function of the O2 sensor, at least enough graphs to see how a working sensor should behave.
    Maybe start with disconnecting the sensor an do a Motronic reset? Should still run like crap in "limp home mode", but differently from now - if the O2 sensor is the problem.
    /Urban
    #12
  13. bikeroz
    bikeroz Long timer
    Oct 18, 2012
    2,514
    Sydney Lower North Shore
    "A friend of mine put, accidentally, diesel fuel in the tank of his 1200gs, 2004."
    I should remember this one, referring to myself in the 3rd person.
    #13
    jacoba331 likes this.
  14. jslyter
    jslyter Been here awhile
    Mar 17, 2006
    351
    Colorado
    Check out this "Bad Gas" thread in the Rocky Mountain regional forum. Apparently there was a gas station in the mountains that had a diesel/gas mixup when there underground tanks got refilled and some ADV members posted up the effect on their bikes.
    http://advrider.com/forums/showthread.php?t=992837
    Without reading through the whole thing, here is the post from one of those affected:
    "Just picked up my very nicely running FJR! Dealership removed the fuel tank, drained & flushed it. Flushed & cleaned fuel injection system. Installed new fuel filter & 4 plugs! Compression test on all four Cylinders came back perfect. She's nice & crisp again!"
    Good luck getting things running smoothly again.
    #14
  15. Scottishman
    Scottishman Been here awhile
    Nov 4, 2012
    133
    North Vancouver, BC
    Two years ago, I put diesel in a rented 800 in Poland. Had it taken to a dealer where they drained the fuel, PUT IN NEW PLUGS, and I was back on the road in 3 hours, even with language barrier.
    #15
  16. k1w1t1m
    k1w1t1m Kiwi
    Oct 10, 2010
    951
    NW Arkansas
    I seem to remember another post about a poorly running bike. IIRC it turned out to be the low voltage connections to the stick coils hadn't been connected properly.
    #16
  17. def
    def Ginger th wonder dog
    Feb 28, 2004
    14,308
    The woods and mountains of Alabama
    You mean, they don't speak Gaelic in Poland? Of all the...I'm cancelling my trip there.
    #17
  18. Dan Cãta
    Jun 5, 2008
    2,569
    I changed the FPR this evening, with no luck... The bike runs the same.
    I took out one upper spark plug and it is white, so the mixture is too lean, so not enough fuel.
    The next thing I am thinking about is replacing the hoses. Perhaps the diesel fuel made the inside of the hoses to melt, preventing the needed fuel volume to get to the injectors.
    Sadly, I do not have tools to measure fuel pressure.
    Dan.
    #18
  19. LARK
    LARK Been here awhile
    Feb 26, 2010
    137
    Louisiana
    Diesel fuel is not going to damage hoses.
    #19
  20. LARK
    Feb 26, 2010
    137
    Louisiana
    Oh BTW change the spark plugs. I'm not saying it'll fix it but by leaving them in you're by-passing a likely culprit. I've seen many cases when a plug that looked good didn't work correctly. It was alway after a fuel related issue. The worst you could do is have fresh plugs before throwing expensive parts at it.
    #20
