ktm 500 exc?
Discussion in 'Thumpers' started by Visigothic, Apr 27, 2011.
  1. hoss314
    hoss314 Been here awhile
    Nov 15, 2008
    136
    Lakeside CA
    Love the tank! I do not have the guards (tank doubles as guards) there should be enough room for the guards.
    Seat is AWESOME! Mine is the tall from Seat Concepts. Best seat I have ever had. Have had one on three of my bikes.
    Sent from my ADR6350 using Tapatalk 2
  2. JetskiMark
    JetskiMark n00b
    Jun 16, 2008
    6
    Near Los Angeles, California
    That looks really nice with all the black plastic.
    Can you see the fuel level with that tank?
  3. KrustyKustom
    KrustyKustom Lets Go....
    Dec 9, 2005
    933
    Desert-away from people...
    Brought my new 500 home today. Looking forward to digging in and sorting everything out.[​IMG]
  4. hoss314
    Nov 15, 2008
    136
    Lakeside CA
    Yes....after taking the cap off.
  5. JetskiMark
    JetskiMark n00b
    Jun 16, 2008
    6
    That's what I assumed, thank you. My only experience is with natural color tanks.
  6. joec63
    joec63 Been here awhile
    Aug 25, 2005
    281
    Olmsted Twnshp, OH
    :clap nice!
  7. Hueychief
    Hueychief FNG
    Mar 29, 2010
    77
    Minnesota
    My newly minted 2013 KTM 500EXC, to include:
    - Desmog
    - JD Tuner
    - FMF silencer
    - RTE rack
    - Reardisc sharkfin
    - HDB handguards w/mirrors
    - HDB topclamp w/ 4 switches & 2 powerlets
    - Sicass racing slim switch assy.
    - Front axle pull
    - KTM skidplate
    - Heated grips
    - G2 throttle cam system
    - 14/48 gearing
    All ready for Colorado next season.
    Pulled all the bearings and regreased them (steering head was dry), balanced wheels (used ALOT of weight), replaced the fuel injector side of the fuel hose twice so far due to leaking (small pin holes in hose) and need to reseed my torn up lawn (self induced).
  8. AussieClay
    AussieClay Adventurer
    Feb 6, 2012
    73
    High Country, Australia
    Harcus/Stu, who makes the radiator guards? Are you happy with them?
    Cheers.
  9. LukasM
    LukasM Long timer
    Nov 15, 2006
    5,513
    On a RTW ride - currently touring the U.S.
    Bullet Proof Designs, best radiator guards by a mile, I have them on 3 bikes. Swingarm and rear disc protectors are really good too.
    http://bulletproofdesigns.com/
  10. SoilSampleDave
    SoilSampleDave Dr. Zaius was right!
    Jan 21, 2005
    12,257
    The Delta Ghetto, GA (aka PTC)
    I have a '13 on order; I didn't realize the rims weren't going to be black. Bummer, I much prefer the black rims.
  11. matt33
    matt33 Been here awhile
    Jul 29, 2012
    121
    NE Pennsylvania
    +1. I was a little bummed, but it does look decent with the black spokes on silver rims.
  12. AussieClay
    Feb 6, 2012
    73
    Some nice looking gear on the website. Thanks.
  13. Nomad
    Nomad High Speed Low Drag
    Mar 29, 2012
    250
    Virginia
    i really like the orange headlight masks found on the 530s, the part #s seem to be different between those and the new 500s though.
    does anyone know where to get an orange one for the 500 or if one from a 530 will work? I just don't see them changing much from the 530 to the 500.
    EDIT: ok i see now...the different part numbers I was seeing were just the different color codes (duh! :baldy ) and the old masks are the same as the new white ones.
    if anyone else was wondering the same, the part numbers are:
    7800800100028 - white
    7800800100030 - black
    7800800100004 - orange
  14. EVELKNIEVEL
    EVELKNIEVEL Adventurer
    Oct 28, 2011
    49
    COUCH IN SUNNY AND HOT FLORIDA
  15. Jbay
    Jbay Adventurer
    Jan 9, 2011
    41
    fuel line broke on new 500 exc, pin hole leak started spraying gasoline, got a boot full
    thanks for the fix here, still this should be embarrassing for KTM for them to something proactive
    luckily was only on a trail ride and had the 350 exc at the truck :evil
  16. Hueychief
    Hueychief FNG
    Mar 29, 2010
    77
    Minnesota
    I'm on my 3rd one with 2.8hrs on the bike, completely unacceptable considering where I will be taking this bike in the future. I made a new one from fuel-injector hose from my local auto parts store and have large looping bends in so as not to kink the hose. I will carry a spare with me.
  17. SteveO
    SteveO scratched and bruised, but not out Supporter
    Jul 15, 2010
    1,571
    Land of ambivalence
    So, after putting the Acerbis 5.3 gallon tank on, I've noticed that the bike gets up to the 220* temp much faster.
    I've ordered a radiator fan kit and I'll get it installed on the left radiator
    two fans running, with a switch to engage when I want them to engage. Having the TrailTech gauge lets me know the temp at any given time.....
    I'll have a write up when i'm done.
    edit: Arrggghhh, darned fan is way too big, can't fit it on the left side behind the radiator. Need to come up with something else.
  18. Bengt Phorks
    Bengt Phorks Been here awhile
    Sep 20, 2012
    597
    To stop the fuel line from kinking stick a 1/4 inch diameter spring inside the fuel line.
    You can bend it as tight as you like.
    http://www.mcmaster.com
    9664K15 Spring STL Cut-to-Length Extension Spring 36.0" Length, .250" Outside Diameter, .028" Wire
    Stainless Steel:
    9665K39 Type 302SS Cut-to-Length Extension Spring 20.0" Length, .25" Outside Diameter, .028" Wire
    While you are ordering:
    pack of 100 Metric Buna-N Orings 2.4 mm width, 7.6 mm ID online at Mcmaster-Carr. Part number is 9262K217
    They are the same size as the original one.
    $5.62 + shipping.
    You can get the fuel line there too.
    54605K33 Low Pressure Sae Fuel Hose, 5/16" Id, 9/16" Od, 50 Psi, Black (250 psi burst pressure).
    Clamps: 53175K26 Miniature Bolt Hose & Tube Clamp, 304 Ss, 31/64" To 35/64" Clamp Dia Range.
    If you want OEM clamps:
    52545K54 Gap-free Pinch Hose And Tube Clamp, 33/64" To 5/8" Clamp Dia Range, 9/32" Band Width
  19. Wentjo
    Wentjo Been here awhile
    Aug 9, 2012
    423
    Lakewood, CO
    Does anybody have the Clockwork KTM 3.1 gal tank? I was just curious how people are liking them. I just put one on my bike 2013 EXC.
  20. Colemanfu
    Colemanfu King of all manfu
    Jan 27, 2006
    6,548
    DAYTONA USA
    For this FF that could be the perfect size.
    Anyone?
