03 Honda Elite 80
Discussion in 'Battle Scooters' started by gec343, Oct 14, 2008.
  1. gec343
    gec343 Long timer
    Jan 13, 2005
    1,070
    Evart, Michigan
    Today, I purchased a 03 Honda Elite 80, no manual. I have been unable to start it, It rolls over well, but will not start. Where is the choke located? Or is it automatic? Any help appreciated.
  2. Photog
    Photog Charismatic Megafauna
    Oct 13, 2003
    46,323
    Cackalacky
    Some scoots require that you squeeze the rear brake lever while hitting the start button...have you tried that? (sorry if that's too elementary but I thought I'd mention it just in case...)
  3. gec343
    gec343 Long timer
    Jan 13, 2005
    1,070
    Evart, Michigan
    Thanks for that advice. I will try that in the morning.:norton
  4. ernest t bass
    ernest t bass Been here awhile
    Apr 11, 2007
    592
    Cardiff by The Sea, California
    Automatic choke on an Elite 80
    try some starting fluid (ether)
  5. Tinfish
    Tinfish Long timer
    Oct 17, 2003
    1,565
    NW/SW
    The choke (called a "bystarter" on those CH80s, for when you inevitably need to replace it) is automatic. You do have to squeeze the brake lever, otherwise it won't start.
    This webpage has lots of really good information on maintenance on the CH80s, including how to test the bystarter.
    You have checked that it has gas, and the air filter isn't blocked, right? (Obvious, I know, but sometimes the obvious things need to be double-checked.)
  6. Motomech
    Motomech Adventurer in Latin Amer.
    Dec 29, 2005
    337
    Playas del Cocos, Costa Rica
    What does the gas in the gas tank look and smaell like?
    The scooter may have sat(always put in the miles when posting a problem).
    If it starts with starting fluid(a shot into the air box), but doesn't keep runing, the carb needs to be cleaned.
  7. gec343
    gec343 Long timer
    Jan 13, 2005
    1,070
    Evart, Michigan
    Thanks for that tip.
    It is a 03 Elite with 157, yes, 157 miles. About three years ago, I purchased it for my female friend while vacationing in Florida. She took the MSF class, but failed, due to dumping her bike in class, breaking her arm, etc. She never got back on the bike. This scooter was not involved in that fall.
    I did ride the scooter a few miles, but not much. I just purchased the scooter back from her, since she is afraid of two wheels now.
    I went out and worked (fiddled) with the scooter yesterday. However, while working on the scooter, a girl showed up to buy an old BMW that I had for sale, so lost interest and got busy doing other things. The gas could be bad, so will drain it if getting spark.
    Today, I'll check for ignition spark. Where is the air cleaner located? My friend is trying to located the manual, but I'll probably have to order one. .
    I really appreciate all of the help so far.
  8. gec343
    gec343 Long timer
    Jan 13, 2005
    1,070
    Evart, Michigan
    I sprayed starter fluid into the air intake and the scooter started instantly. I added some fuel injector cleaner, let it idle for a while, then took off. It runs fine, but then it should with only 158 miles.
    I appreciate all of the tips here. What a great bunch of people.:norton
    #8
  9. Photog
    Oct 13, 2003
    46,323
    Cackalacky
    Pics! :ddog
    glad it's running...hope you have a good time with the little critter.
    #9
  10. brockster
    brockster Despair & Repair Garage
    Dec 26, 2004
    2,042
    Near Dayton, Ohio USA
    Better living through chemistry! :evil
    Don't cha just love fixing bikes with spray cans?
    #10
  11. gec343
    gec343 Long timer
    Jan 13, 2005
    1,070
    Evart, Michigan
    Yes, I do. Seems like the fix is almost alway simple with Honda quality.:norton
    #11
