KTM 520 hyd clutch issues
Discussion in 'Thumpers' started by Billyb88, Jan 11, 2015.
  1. Billyb88
    Billyb88 n00b
    Jan 11, 2015
    1
    Kalgoorlie Western Australia
    Hi all,
    I have just got a 01 KTM520 it's got no clutch, lever has no resistance what so ever tried reverse bleeding it can't get any fluid into the master cylinder Evan with the lever removed can't squeeze any fluid from the bleed nipple up. Any body had this before
    With the clutch line removed from the master cyl, fluid flows fine from the bleed nipple up the hose.
    Cheers Bill
  2. Droptarotter
    Droptarotter Long timer
    Jul 11, 2007
    2,622
    Creston,BC
    With the clutch line still disconnected, what happens if you put fluid in the master and pull the lever? Any fluid come out of the master? If you put your finger over where the line would go, do you feel any pressure?
    Cheers
