the DR650 thread
Discussion in 'Thumpers' started by sleepywombat, May 1, 2006.
  1. Sierra Thumper
    Sierra Thumper Been here awhile
    Oct 3, 2012
    641
    Yep, there could be many reasons why a clutch would need replacing before 15k miles on a DR, but the most likely reason is stated above...the po just plain wore it out through his riding style.
    I'm always suspicious of replaced parts like clutches on lower mileage machinery.....makes me wonder what other hidden wear and tear the machine went through to prematurely wear out the clutch.
  2. SCExpat
    SCExpat Ex-expat
    Dec 31, 2009
    1,088
    Nampa, ID
    My exact concern. I thought 15K was a bit early for a new clutch. As I am in no rush I am going to pass on it. Even if it is a good price. A nicer one will show up before it gets warm enough for me to ride here.
  3. doug s.
    doug s. Long timer
    May 2, 2011
    1,520
    md
    if it otherwise looks decent, you could always offer $1500, and then walk away if the seller says no...
    doug s.
  4. Rusty Rocket
    Rusty Rocket Life behind "Bars"
    Dec 22, 2005
    20,445
    Tri- Cities TN
    I have always cut strips of HD innertubes and squeezed them between the frame and skidplate on all my bikes. I think that much of what people are hearing is the plate vibrating harmonically. This may not be enough for some of you. The DR650 is the quietest bike I have ever owned, I've never had a streetbike so I can't compare what others perceive as noisey.:1drink
    You definitely want closed cell foam,(like GSF suggests) especially offraod. The bufferpad will soon be adobe. Think about using a "pool noodle" or foam pipe insulation instead.
  5. WindPipe
    WindPipe Been here awhile
    Aug 18, 2008
    219
    Duneland
    What size socket do I need for that primary nut. My searches have come up empty ...
  6. shu
    shu ...
    Feb 23, 2010
    2,284
    Colorado
    That's what I did as well. Seems to work fine for me- of course, I wear earplugs when I ride. :wink:
    ...........shu
  7. jessepitt
    jessepitt Ride More
    Oct 20, 2008
    993
    Redmond Oregon
    I also use inner tubes to dampen vibration but like any other sane or intelligent person I wear earplugs, so the noise doesn't really bother me.
  8. barko1
    barko1 barko1
    Nov 24, 2004
    5,769
    St Cloud
    I bought a piece of compressible foam designed for the purpose but frankly since I always where earplugs I don't notice much difference. I wonder if several coats of Plasti-Dip might work. It is pretty tough, you can cover your whole car with it (might be good for DR side panels!).
  9. SkunkWizard
    SkunkWizard Long timer
    Mar 26, 2009
    3,603
    Duty Free
    Job done well! be proud show it off
    looks very Latrodectus hesperus
  10. LucasLeader
    LucasLeader Been here awhile
    Mar 21, 2010
    299
    Anchorage, AK
    Is your chain a little loose?
  11. motolab
    motolab Long timer
    Feb 16, 2006
    7,905
    Sorry for not replying sooner and thanks for the PM to remind me.
    The area the needle is responsible for is 1/4 opening. The needle should not be used to tune closed throttle even though there may very well be enough overlap to affect it. To illustrate the problem: Let's say that you had tuned the clip position to achieve perfect running at 1/4 opening, and you now raised the needle to richen the mixture at closed throttle. The result will be that the mixture at 1/4 opening will now be too rich, while the effect on closed throttle may or may not be as desired. Closed throttle is solely the responsibility of the fuel screw unless the pilot jet size is out of range. You can test this by evaluating 1/16 to 1/8 opening running and/or by whether or not the engine can be killed at both extremes of the fuel screw's adjustment range. Of these two, the former is absolute (misadjusted float height, clogged/incorrect pilot air bleed size or worn parts notwithstanding) while the latter should only be used to give you hints.
    Regards,
    Derek
  12. ram1000
    ram1000 Long timer
    Feb 14, 2004
    1,893
    Tricities Washington
    I am waiting for new tires before I adjust the chain...
  13. Adv Grifter
    Adv Grifter on the road o'dreams
    Jan 18, 2010
    6,128
    Passing ADV Stalkers in California
    A very good point ... and valid reason for concern. When buying ... and I've bought over 50 bikes ... a good idea to have close look at the seller. How is his garage kept? Does he keep maintenance logs? Lots can be learned from his answers regards maintenance or "fixes" he has done on the bike.
    All that said ... as I said before ... the DR is a pretty tough customer and can handle abuse well. Still ... a hard used bike would never be my first choice. Good luck! Good shopping. :clap
  14. shu
    shu ...
    Feb 23, 2010
    2,284
    Colorado
    :nod Black Widow Spider. (Had to look it up.)
    ...........shu
  15. Adv Grifter
    Jan 18, 2010
    6,128
    I also used HD innertube stripes on all places where frame contacts skid plate. Not sure how much it helped but seems OK. Spraying with some sound deadening stuff can't hurt. More the quieter.
  16. gjcarving
    gjcarving Been here awhile
    Aug 4, 2010
    252
    Santa Fe, NM
    I did mine a few months ago. I believe it is a 30mm. Had to go to an auto parts store to get one. Pep boys! Hope yours is not as loose as mine was. Mine ate a bunch of the clutch basket apart on the back. Enough that I decided to replace it. Good luck!
  17. 3DChief
    3DChief "Moto therapist"
    Jun 2, 2010
    412
    Montana
    In addition to the bedliner spray, I also have the HD tube strips between the frame and skid plate. I didn't notice much, if any difference. My KLR 250 with the same treatment on the skid plate is way worse for reflecting noise, my DR 650 is quiet by comparison! Can't hear either with my earplugs in. Good point about the closed cell foam, I didn't think about the buffer pad-type material filling up with dirt and turning into a brick.
    Gear Nazi rant on: If you are not wearing ear plugs when you ride, you need to, every time! As someone with hearing loss and that has to wear hearing aids, I can tell you from experience to do everything you can to protect your hearing. It is not the noise of the bike that will damage your hearing unless you are running straight pipes, it is the constant wind noise! You can have the quietest exhaust ever and still lose your hearing in pretty short order! Plus it helps tremendously with fatigue. Ear plugs every time! Gear Nazi rant off!
    :beer
    Tim
  18. Adv Grifter
    Jan 18, 2010
    6,128
    As a sound recording pro ... I agree. I've done many many similar rants on ADV ... most riders just ignore ... if falls on "deaf ears" :rofl.
    Everybody has an excuse, like, "... plugs are too uncomfortable", " ... they don't fit my ear canals". "... too expensive". " ... too much trouble to put in and out". Yada Yada. Got an issue? Get a tissue! :D
    As you say, hearing loss is no joke. And yes ... it's the low freq buffeting from wind noise that does damage to the tiny Scilia around the ear drum. First you loose ability to hear high frequencies ... makes understanding speech in a noisy place hard. Goes downhill from there.
    So easy to protect your hearing. At least wear them on long rides ... and learn how to insert them properly .... many riders do it wrong. :huh
    RANT OFF! :lol3:freaky
  19. neo1piv014
    neo1piv014 Garden Variety ADV
    Aug 12, 2011
    661
    Albuquerque, NM
    As a fairly young guy who actually has noticed a little bit of hearing damage since I started riding a few years ago, I definitely second this. I ride with tight fitting ear buds in when I'm on long trips or commuting, though I'm sure they're not helping as much as real plugs would. Do you ride with any kind of music/sound system in your helmet? If I didn't have music and podcasts, I'm not sure I'd ever use my bike to commute.
  20. Mongle
    Mongle Cyberdos groupie
    Dec 4, 2009
    18,019
    NC
    Anyone ever try that Dynamat ( I think that is what it is called) the car stereo guys use in trunks? Might be a good alternative.
    I noticed my DR650 when I first put the skid plate on. Now, it is just the music it makes.:lol3 Now if I don't hear stuff I get worried.
    The dyno room has ruined my hearing. If we are out anywhere that has "noisy" dining area I can't hear anyone say shit. I just nod and smile. I have gotten where I wear ear plugs on long trips or if I ride the highway. Makes the ride more enjoyable.
