Can I cut off a cooling fin?
Discussion in 'Thumpers' started by _CJ, Jun 27, 2013.
  1. _CJ
    _CJ Sitting on pins and needles
    Dec 29, 2010
    4,350
    The 719
    Asked this in the DR350 thread, but nobody knew and/or the question got buried before anyone saw it as is often the case, so.....
  2. brucifer
    brucifer Long timer
    Nov 27, 2007
    3,497
    Eureka, Ca.
    I don't see where that would be a problem. Maybe just clearance it with a die grinder.
  3. SloMo228
    SloMo228 World Class Cheapass
    Sep 22, 2012
    1,883
    SE Michigan
    They're not structural, so trimming one down isn't going to weaken the engine. All you're doing is slightly reducing the surface area from which the engine heat is dissipated into the air. Grinding a little off to make room won't make very much difference at all.
  4. Bronco638
    Bronco638 Nobody Home
    Dec 1, 2004
    6,413
    Notorious EGV
    I had two DR350SEs, both with the Raptor petcock. I trimmed the offending fin, on both bike's cylinder heads. I had no issues at all. You will do no damage to the engine.
  5. Droptarotter
    Droptarotter Long timer
    Jul 11, 2007
    2,622
    Creston,BC
    The dremel idea is the best way.
    I say go for it...........a DR could probably run forever with no fins!
    Cheers
  6. Sniper X
    Sniper X De Oppresso Liber
    Jul 18, 2006
    33,561
    Central New Mexico, 7420ft above sea level
    Every single 2t Enduro that came with an up pipe all did far more than trimming ONE fin, you'll be fine. Some shaved half the length of the fins off on one side corner of the cyl and head!
  7. _CJ
    Dec 29, 2010
    4,350
    The 719
    Okay, surgery complete. No big deal with a cut-off wheel on an angle grinder.
    Interestingly, the fins are shaped kind of like an airplane wing. :pynd
  8. Sniper X
    Jul 18, 2006
    33,561
    Oh NOW you've gone and done it! We were KIDDING about cutting off a fin! :rofl
    #8
  9. JustinP
    JustinP Bike Curious
    Jun 19, 2011
    15,654
    Staatsburg NY
    Oh shit, you didn't say it was the top fin :(
    Just like your body, all the heat goes out the top.
    #9
  10. ping
    ping Been here awhile
    Mar 9, 2008
    184
    A photo is needed to determine solution
    #10
  11. tHEtREV
    tHEtREV Encouragement award recipient. tEAM iDIOT.
    Apr 14, 2007
    14,150
    Middle Park, Brisbane, Australia
    Yeah, that fin is the main inlet cam cooling fin!!!
    Now you will have to make another fin out of JB weld.
    #11
  12. _CJ
    Dec 29, 2010
    4,350
    The 719
    #12
  13. brucifer
    brucifer Long timer
    Nov 27, 2007
    3,497
    Eureka, Ca.
    You guys are bad! :lol3
    Have a good ride there CJ. :thumb
    #13
  14. _CJ
    Dec 29, 2010
    4,350
    The 719
    #14
