Side stand as shut-off
Discussion in 'GS Boxers' started by PeterX, Oct 10, 2014.
  1. PeterX
    PeterX Been here awhile
    Mar 26, 2005
    284
    Philadelphia/San Francisco Bay area bi-coastal
    I've been using the side stand as a shut off (down while the bike is in gear) on my GS LC. i've asked a couple of techs and have gotten very different responses "no problem, doesn't hurt anything", "don't do it, it use the key". I'm liking my system because it leaves the bike in 1st and more secure. Any input on this issue would be appreciated:ear
  2. schlim66
    schlim66 Lone Rider
    Mar 12, 2006
    730
    Somewhere in SoCal
    I've been doing that on the last 8 BMW's I've owned. I think it's the safest way to park a bike, period!
    3 R1200GS's
    2 HP2's
    2 S1000's
    G650X
    Never had a problem with any of them.
    Cheers,
    Schlim66
  3. PeterX
    Mar 26, 2005
    284
    Some pretty fine references:clap
  4. JimVonBaden
    JimVonBaden "Cool" Aid!
    Feb 11, 2005
    101,516
    Alexandria, VA
    Since you put the sidestand down every time you park I fail to see the harm in it. It is not like the kill switch.
    I use it often on my bike as well.
  5. lkchris
    lkchris Albuquerque
    Feb 23, 2005
    1,130
    A great idea and much more intelligent than using kill switch.
  6. usgser
    usgser Long timer
    Nov 6, 2005
    3,580
    Westside WA
    I don't see the harm but handle bar switch gear can be pretty flakey at best and if not used can be really flakey if not used often enough. The KILL switch is a good thing to know is working if needed. If it doesn't work and your laying under your 500 lb crashed bike and the back tire is sawing your leg off you're REALLY gonna wish that the kill switch would have worked. I would at least use the kill switch often enough you know you can count on it.
  7. JimVonBaden
    Feb 11, 2005
    101,516
    Alexandria, VA
    Thread ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~>
  8. Roadscum
    Roadscum Long timer
    May 7, 2007
    5,287
    SW Florida
    I usually us the side stand shut down method when I park my bikes, been doing if for years and never had an issue, except.....
    when I then forget to turn off the key and run down the battery!
    Good thing I always carry jumper cables. :lol3
    Paul
    #8
  9. slowinfastout
    slowinfastout Halfway to nowhere in particular
    Jan 10, 2007
    2,473
    Fairfax Station VA
    I must be old school because I never would even consider to use the sidestand kill OR the handlebar mounted kill button. I reach up and turn the key off, then pull the key out of the ignition, thereby ensuring I have the key out of the bike and in my pocket with all the electrics off. Seems to be more goof-proof than the other shut-off methods.
    #9
  10. Botch
    Botch Been here awhile
    Mar 17, 2013
    800
    Ogden, Utard
    I've always used the sidestand on both bikes. I have admittedly walked off without the key, but only a couple times the last decade.
    This sorta made sense except that the key is 4" away from the kill switch, can also save your leg.
    Really, I don't understand the need for a kill switch at all. :huh
    #10
  11. PeterX
    Mar 26, 2005
    284
    Always good to get some consensus on the answer you were hoping for. Thanks all:clap
    #11
  12. def
    def Ginger th wonder dog
    Feb 28, 2004
    14,308
    The woods and mountains of Alabama
    I have always used the kill switch to shut off the engine. Reason is, if I were to need to shut off the engine for some emergency reason, I would instinctively go to the kill switch.
    Sometimes I coast down the last 50 feet of my drive into the garage after turning the engine off, leaving the engine turning in gear then declutch as I come to a stop in the garage.
    #12
  13. JimVonBaden
    Feb 11, 2005
    101,516
    Alexandria, VA
    I typically use the sidestand when I need to keep the bike in gear and hold the brake. No hand left to turn the key, and it is easier than balancing on one toe to free up a hand and use the foot brake. Tall people may not have this issue.
    #13
  14. JimVonBaden
    Feb 11, 2005
    101,516
    Alexandria, VA
    But you are old, and instinct is all you have left. Your memory is long gone!:lol3
    :hide
    #14
  15. orgo
    orgo Been here awhile
    Jan 24, 2012
    349
    I always use the sidestand but don't see where it would matter much with any of the methods mentioned.
    Do what you like and feel comfortable with
    #15
  16. BMWS
    BMWS Calibration Due
    Jun 13, 2012
    84
    NE Ohio
    I use the side stand to cut the engine so I know it is safe to get off the bike.
    Learned that from my bro in law with an LT.
    850 LBS & trying to get off the bike without the side stand down could cause an embarrassing moment!
    #16
  17. kiwiAdventure
    kiwiAdventure Long timer
    Nov 7, 2002
    1,424
    Auckland New Zealand
    I always disconnect the side stand switch it drives me crazy with all these safety needs.
    #17
  18. PeterX
    Mar 26, 2005
    284
    This!!
    #18
  19. pistole
    pistole Long timer
    Jan 11, 2013
    3,360
    earth
    when offroading , will usually kill the bike with the sidestand , whilst in gear.
    more secure
    #19
  20. longslowdistance
    longslowdistance Long timer Supporter
    Oct 12, 2010
    2,200
    Virginia
    Some earlier posts implied there is something wrong with using the kill switch. What would that be?
    #20
