Moab Spring 2014
Discussion in 'Ride Reports - Day Trippin'' started by simbaboy, Jan 24, 2014.
  1. Bungholio
    Bungholio Long timer
    Oct 9, 2008
    2,802
    Aberdeen, WA
    And balance, keep bike upright, weight a little forward and on your feet.
    Same as the other one, may have to let the front end get some air at the top and don't chop the throttle too soon.
    Moab would be fun but alas I don't have the free time then.
    #41
  2. Blakebird
    Blakebird r - u - n - n - o - f - t
    Feb 7, 2004
    31,527
    Las Cruces, NM
    you don't have a monopoly on the age thing... I'm 58 - my XR628 with it's big tank was no lightweight and covered all that stuff (the 525 was much more fun)
    You'll do fine.
    When it gets steep remember two words....momentum and commitment. :nod :D
    #42
  3. simbaboy
    simbaboy Lansing MBS Supporter
    Apr 22, 2012
    7,598
    Lansing, MI
    Thanks.
    Going uphill is freaky but I usually can manage. Going downhill with a major drop off cliff on one edge gives me pause. I guess a few practice runs on a short run will inspire confidence.
    "momentum and commitment" I like that and will remember it. When I hit a spot I usually say to myself "trust your bike, trust the suspension" and I am fine. When I am in doubt and slow down, I go down. In the picture below I laid the bike down: lost momentum because I lost the commitment. I am going to remember this phrase. Thank You.
    I am 50 years old, but have been dual sporting for only 2. Lots of catching up to do.
    Simba
    #43
  4. wayno
    wayno Long timer
    Mar 14, 2004
    7,850
    East of KCMO
    Im 65 been there done that. not so much anymore.....don't mind tipping over as long as it is not at speed and/or next to a cliff...lol
    Hope I can make it out to join in the fun.
    Wonder if reservations are needed for lodging (camping/room)
    Wonder if we can get an idea of where most are staying.
    Sorry if most of the questions have been already answered.
    #44
  5. simbaboy
    Apr 22, 2012
    7,598
    Lansing, MI
    Yes reservations are needed. Some in our small group have rooms, some in RVs and some camping. Send me an email/PM and I will include you in the discussions.
    Slow tip overs are educational--I like the phrase I have learned today: 'momentum and commitment'. I can really hear myself saying this on some nasty fear inspiring stretches of trail.
    Simba
    #45
  6. MountainsandRivers
    MountainsandRivers loves dirty things!
    Jun 28, 2010
    8,737
    To Hell U Ride
    Confidence. Usually I just stand and lean forward over the bars when climbing. Steady throttle application, not heavy throttle, just increase a little as the bike starts to bog. Lower air pressure in the rear tire really helps, but don't go super low unless you want to worry about pinch flats and smacking your rim when you wick it up a bit.
    The first place you can get on Fins N Things is after you pass the Slickrock parking lot, you will get up on the mesa, pass a few campsites, and look for the road on the left. It will go through some sandy curves, then fork. The left fork is mostly slickrock type short loops. Great intro and none of the climbs are very bad. Great way to get oriented!
    #46
  7. simbaboy
    Apr 22, 2012
    7,598
    Lansing, MI
    Thanks for the tip. I think that I will start off in Fins.
    How about riding down a steep hill? Turn the bike off and keep in 1st gear and use clutch and brakes to slowly come down? i hate the feeling of 'free fall'.
    Simba
    #47
  8. ChromeSux
    ChromeSux Un-plated and Unscrewed
    Sep 1, 2008
    2,635
    Lenoir City TN.
    Those sandy curves at Finns and things can be fun fun. The first time i went there i was on my KLR. That bike was a bit of a pig in there but i learned to use the banks of the curves in my favor. 2013 when i was on the DRZ it was a hoot. I would go high on the banks and use that for momentum coming down, just stayed on the throttle. Being down in the bottom trying to snake thru did not work as well for me, i liked the banks.
    #48
  9. ChromeSux
    Sep 1, 2008
    2,635
    Lenoir City TN.
    Simbaboy here is a tag for you to get while you are there.
    #49
  10. vraesch
    vraesch Adventurer
    Jul 23, 2012
    46
    Atlanta, Ga
    Simba - I'm not sure about the "killing the engine technique" although I did use this last time on the "steps" at Black Bear Pass Co. It was raining and that made me pretty nervous. There is a cliff there that scares the heck out of me.
    Anyway if it is that steep I assume you are already in 1st gear, engine idling with the clutch out. If you are geared low enough let the engine compression hold you back and use just enough rear brake to keep the rear wheel from locking. If you just pull in the clutch and use the brakes only it is too easy to lock the rear wheel. Locking the rear wheel usually means a loss of control. if it is really steep you may not be able to stop from sliding so given the terrain and what is ahead you might just have to accept that you are going to going downhill a little faster than might be comfortable. That said, my primary speed control on downhill is the front brake. Most of the weight is on the front wheel so you can use more front brake than you think. This is esp true on the Moab slickrock where the traction is incredible
    #50
  11. simbaboy
    Apr 22, 2012
    7,598
    Lansing, MI
    Hmmm, Initially I thought Dewey Bridge, but I know its not that. If I see it, I will grab it.
    Thanks,
    Simba
    Thanks.
    Sounds like I am going to need to do a lot of practice runs on safe slick rock before attempting long runs. I think I can 'pucker up' going uphill, but going downhill---will need a lot of practice. But I will up my DS game this year.
    Thanks,
    Simba
    #51
  12. vraesch
    vraesch Adventurer
    Jul 23, 2012
    46
    Atlanta, Ga
    "MountainsAndRivers" - great pics. I want to get up on the Poison Spider Mesa, but I don't think I'll be jumping the "Golden Crack". I've spoken to my friend "RideFreak" that has been to Moab many times he suggests the following:
    Top of the world loop (epic views) leave from the Dewey bridge, ride to the top, then down Rose Garden hill (tough but easily doable esp if you walk it down), out Onion Creek then back to the Dewey bridge.
    Another is ride out to Chicken Corners and back or even do Lockhart Basin, you'd have to gas up at the needles outpost before the ride back to town. It's got about 40mi of pavement on the way home though.
    There's some nice riding into the LaSalle's but there'll probably be snow up there still. The 7 Mile Rim is also a nice ride.
    In any case, I suggest going to youtube and searching for videos that can give you some idea of what to expect on these rides.
    #52
  13. FTL900
    FTL900 White and nerdy
    Oct 3, 2005
    1,312
    Las Vegas
    I can't imagine ever pulling the clutch in on a steep downhill. The engine turning the rear wheel is what keeps it from locking up. Or at least that's the plan.
    #53
  14. simbaboy
    Apr 22, 2012
    7,598
    Lansing, MI
    When I was going down a very steep hill on The WRT I was using the front and rear brakes and also using the clutch. I went down that hill WAY TOO HOT. For me that was the scariest moment I have had in my two years of dual sporting. There was such a drop off on my Right side I was too afraid too let out the clutch thinking I would lock up and lose control of the bike. My 'Coach' at the bottom kept yelling for me to slow down, and I kept yelling at him (in my head) to get out of the way before I run into him!:eek1
    So I need practice going down steep hills.
    Please I need continued hints.
    Simba
    #54
  15. MountainsandRivers
    Jun 28, 2010
    8,737
    To Hell U Ride
    Slow, technical drops I am usually in 1st or 2nd, and fairly even between the brakes, weight toward back. Long steep hills I run a higher gear so the engine compression doesn't fuck with me. Really just depends what the bottom of the hill looks like, smooth run out, turn, ledge drop?
    The ride suggestion involving Onion Creek is a good one, but try some of the other mellower suggestions and cut your teeth on Fins N Things before going down Rose Garden. I rode up it 3/4 of the way last fall, and even after I turned around, going down was not exactly easy.
    #55
  16. vraesch
    vraesch Adventurer
    Jul 23, 2012
    46
    Atlanta, Ga
    All,
    Has anyone in done Onion Creek or Top of the World trails? If so could you give us an idea of the difficulty of each? It was suggested to me to do a loop starting at Dewey Bridge consisting of Top of the World then down Rose Garden Hill (may involve walking the bike down some ledges) then out Onion Creek to Rt 128. It has been suggested that Rose Garden Hill might not be a good idea, so an alternative might be to do the out and back on Onion Creek, followed by an out and back on Top of the World for those wanting more challenge.
    I understand that Onion Creek is fairly easy (if it hasn't rained a lot) but very scenic. I don't know the difficulty level of Top of the World. Your thoughts?
    #56
  17. Wentjo
    Wentjo Been here awhile
    Aug 9, 2012
    423
    Lakewood, CO
    Rose Garden Hill will be difficult for someone with not much experience in the rocks. There are a bunch of smaller ledges leading up to the hill itself. I've seen some larger bikes go down it but they needed to be helped in a few spots. Top of the world isn't hard, just rough.
    #57
  18. vraesch
    vraesch Adventurer
    Jul 23, 2012
    46
    Atlanta, Ga
    I found this Moab trail ride video on youtube:
    https://www.youtube.com/watch?v=S03hZ4nlUPw
    It jumps back and forth between various trails, but a worth while view of most of the trails we have been taking about. (Slickrock, Fins&Things, Hells Revenge, 7 Mile Rim, Monitor&Merrimac, Soverign, Top of the World, Gemini Bridges). It ends with hilites of various crashes & mishaps. It was comforting to see that the spot that ended my initial slickrock trail ride (with a bent shifter), was also problematic for others as well. I'll make sure I point out that spot in advance to anyone riding with me.
    #58
  19. ChromeSux
    Sep 1, 2008
    2,635
    Lenoir City TN.
    More pics for ya Simbaboy.
    #59
  20. simbaboy
    Apr 22, 2012
    7,598
    Lansing, MI
    Hello Friend,
    I have done Onion Creek Trail several times---very easy but quite scenic. You get to the trail after 22 Miles of pavement on SR128. Yes you do cross Dewey Bridge.
    Imu (Simba)
    #60
