Lost the it in the garage
Discussion in 'The Garage' started by maxjett, Dec 4, 2011.
  1. maxjett
    maxjett Ride with Rocko
    Aug 7, 2007
    2,016
    Raleigh, NC
    FOUND IT at it at LAST, and the bike runs just fine. tnx for all the help and I did try the a few of them.
    I picked up a nice little TTR50 for the niece and it needed the carb clean. So couldn't wait so I pulled off, wasn't to bad, So while putting everything back together I dropped the needle valve on the garage floor which by the way has commercial carpet.
    So on the hands and knees even with a flashlight can't find it! No its not in my shoe either. So I was wondering before I call the shop tomorrow are most needle valves the same? I assume they have come in different lengths but never measured one or looked that close.
    I swear I had not even opened the second beer.
  2. concours
    concours WFO for 50 years
    Dec 2, 2008
    9,696
    USA
    Carpeting in the garage? Surrender your man card.:lol3
  3. maxjett
    Aug 7, 2007
    2,016
    Raleigh, NC
    I've found it soaks up all the spills! And its really showing it after two years.
  4. Gale B.T.
    Gale B.T. Long timer
    Jun 14, 2005
    1,857
    Pagosa Springs, CO.
    Try a good metal detector, borrow from friend/neighbor, rent ?
  5. mouthfulloflake
    mouthfulloflake Not afraid
    Aug 21, 2008
    37,174
    The Berkeley of Arkansas
    a few years back I did the same thing with my daughters PW50.
    I looked for days, finally ordered a new needle.
    about a week later found the original one.
    it happens.
  6. concours
    Dec 2, 2008
    9,696
    USA
    We're talkin' hops and barley, right? not 20-50? :freaky
  7. maxjett
    Aug 7, 2007
    2,016
    Raleigh, NC
    Black and Tan was the afternoon beverage.
    Metal detector could work and I do h ave one but could be some rebar in the concrete
  8. Disston
    Disston ShadeTreeExpert
    Aug 31, 2009
    22,038
    Silver Spring, Md
    Put a new bag on the vacuum cleaner. Vac area where needle is supposed to be. Look in debris in bag for needle.
    Charlie
    #8
  9. P B G
    P B G Long timer
    Mar 7, 2008
    10,004
    Greater Chicago
    Long ago I bought a rolling magnetic "sweeper" the type you use to pick up nails on job sites.
    Run that around, under benches and such.
    Does a good job.
    #9
  10. maxjett
    Aug 7, 2007
    2,016
    Raleigh, NC
    May try the vac in the morning . Is that thing brass ?
    #10
  11. RunLongVT
    RunLongVT Been here awhile
    Jun 23, 2008
    103
    Vermont
    Check in your pants cuffs, too, if applicable. You'd be amazed...
    #11
  12. Disston
    Aug 31, 2009
    22,038
    Silver Spring, Md
    It might be steel. You say it was the needle? If you have a large magnet wouldn't hurt to wave it around the floor.
    Charlie
    #12
  13. GreaseMonkey
    GreaseMonkey Preshrunk & Cottony
    Jun 16, 2006
    6,001
    The only county in Illinois with no train tracks
    If it might be steel then try the magnet, but the best way finding this stuff like this is to use a vacuum and ask your wife for an old pair of pantyhose and put that over the end of the vacuum.
    #13
  14. grizzzly
    grizzzly The Pre-Banned Version
    Apr 29, 2007
    4,768
    socorro NM 505-five five zero-2583
    if you know how and where you were holding the part, try to drop a similar item and watch where it lands<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
    I have found several things this way :wink:
    (I have also lost stuff this way):lol3<o:p></o:p>
    <o:p></o:p>
    #14
  15. ontic
    ontic
    Jul 14, 2008
    1,385
    Melbourne
    this should really be a picture thread.
    here is the top reb/comp adjuster on my WP50 forks.
    Nice little thing isn't it. In removing it from the forks I just carelessly pulled it out and of course the spring and the two ball bearings shot out in three different directions. I managed to keep my eyes on all three at once, somehow, and even more miraculously (in my messy garage) found a bearing and the spring. The third bearing proved harder to find, and the only logical explanation was that it had disappeared down the 'great crack' in the garage floor. No amount of probing and digging and magnet poking into the crack located the bearing.
    A while later, I found it.:D
    #15
  16. mike-s
    mike-s 2 squeaky wheels
    Jun 15, 2007
    605
    Sydney, Aus
    Bahahahaha no half measures taken I see.
    #16
  17. Flydog
    Flydog Flydog
    Jan 26, 2006
    105
    North Georgia to Smyrna
    I lost a valve keeper for an O200 aircraft engine in the hem of my jeans for a while once, the end was turned up in one spot just enough to catch it.
    #17
  18. tgeliot
    tgeliot Topher
    Jun 22, 2010
    1,580
    Denver, CO
    This just might work. I was married to a goldsmith for 16 years, and when they dropped a diamond, they'd turn off all the lights and get a bright flashlight and sweep it around and look for the glints of light.
    #18
  19. francs
    francs Been here awhile
    Jul 1, 2008
    427
    Ljubljana Slovenija
    :rofl:rofl:rofl:rofl
    I like your attitude.
    #19
  20. dtysdalx2
    dtysdalx2 The only easy day was yesterday...
    Aug 1, 2004
    36,766
    Moneyapolis, MN
    :D
    The thing about carpeting is it should not have rolled or bounced out of view. Kinda hard to clean up oil spills though..:huh
    I'm down with the magnet trick, unless parts are brass or stainless steel.
    #20
